Need help identifying this problem with my GPU please help!!
2,983 (2.05/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
NVIDIA > Control panel > Manage 3D settings > Power management mode = SET HIGH performance ... re-test
this only disables 2D Mode.
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
Display(s) DELL U2311H
Keyboard Microsoft Wired 600
2,983 (2.05/day)
Germany
I do disagree, and even NVIDIA disagree with your thought.
Prefer High performance (former "Maximum Performance") locks the card into 3D Mode. that's it. (since over 10 years now)
9,340 (5.16/day)
Louisiana
Keyboard G710+x3
monkeymanagers
17 (0.02/day)
thats your problem - yeah back to the power pin :p the card is power throttling because pin#2 isn't doing anything.
why? good question.
i doubt its the PSU, if you want to, try run prime95 while running heaven, if the PSU doesn't shut down, you're fine. could have a connector/cable problem, try another cable - i am assuming that TT 850 has a few(?).
but i've not seen this before, it like half the vrms/power planes wanna don't work. and that a no fix kinda th
why? good question.
but i've not seen this before, it like half the vrms/power planes wanna don't work. and that a no fix kinda thing.
btw, adjusting voltage in AB won't show idling, its adding to the boost clocks (P0 power state) but using Kboost (via evga PX not AB!) should have locked you to 1.212v.
So this is the exact model of the PSU I have
Can't find replacement cables for this exact model but I found this
would these work?
also did what you said and ran prime95 while running heaven benchmark and my PSU did not shut down
Only reason not to change paste and pads is you don't feel comfortable doing it.
That and I wanna see if I put a new power cable it will fix it without taking my GPU apart and messing up something more
1,065 (0.29/day)
System Name loon v4.0
Processor i7-11700K
Motherboard asus Z590TUF+wifi
Cooling Custom Loop
Memory ballistix 3600 cl16
Video Card(s) eVga 3060 xc
Storage WD sn570 1tb(nvme) SanDisk ultra 2tb(sata)
Display(s) cheap 1080&4K 60hz
Case Roswell Stryker
Power Supply eVGA supernova 750 G6
Mouse eats cheese
Keyboard warrior!
Benchmark Scores https://www.3dmark.com/spy/21765182 https://www.3dmark.com/pr/1114767
would these work?
that psu should have 2 cables with 2 - 6+2 pci-e power connectors on each cable. or did you lose it? :p
its not a big deal, i thought maybe that one connector is flanky but it is a goose chase. but NO DO NOT buy any cables that aren't for that specific model! that ebay isn't.
since the PSU did not trip, its looking good, not exactly confirmed but not looking like thats a problem. the swapping the connector thingy is a shot in the dark. sure the card, as mentioned by a few, is giving up the ghost, sorry.
monkeymanagers
17 (0.02/day)
At this point i should buy a new GPU huh perfect timing since GPU prices are also crashing thanks for the help
