NVCleanstall - Clean installer for NVIDIA drivers (Alpha)
Status
Not open for further replies.
W1zzard
Administrator
28,268 (3.72/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
This thread is for the beta version of NVCleanstall that was in development between 2018 and 2019.
For the final release go
here.
NVCleanstall lets you remove individual components from the NVIDIA driver, to only install what you actually want.
Supports Windows 7, 8, 8.1, 10, 32 & 64-bit
It will download only the selected components, which should lead to faster install times, especially on slower connections.
Feedback please!
NVCleanstall v1.0.0 has finally been released, you can download it here: https://www.techpowerup.com/download/techpowerup-nvcleanstall/
Please direct all future discussion to the following subforum: https://www.techpowerup.com/forums/forums/nvcleanstall.91/
dorsetknob
9,106 (1.25/day)
:) Now People cannot complain about the :) Crap :) they install from the Driver package
43,774 (6.79/day)
Any work for red?
W1zzard
Administrator
28,268 (3.72/day)
Memory 48 GB
1,277 (0.29/day)
Motherboard MXI APEX
Storage 660P 1TB, 860 QVO 2TB
Case Open Benchtable V2
Audio Device(s) SB X-Fi
Power Supply MSI A1000G
Mouse G502
Keyboard G815
Software Gentoo/Windows 10
Nice work Wizzard and thanks!
Did you use NVAPI?
W1zzard
Administrator
28,268 (3.72/day)
Memory 48 GB
1,277 (0.29/day)
Mouse G502
Keyboard G815
There's a section under NVAPI called driver management. I thought NVAPI was available outside of the driver as an SDK. Anyway, if it's not, you must be using some kind of web API to access the driver components. I'm quite curious as to the design ;)
Easy Rhino
Linux Advocate
15,655 (2.34/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software Fedora KDE Spin
How is this different than ticking the "Clean Install" box when executing the driver install?
19,378 (3.50/day)
The clean install box is only for settings in the NVCP, not to clean driver bits and registry entries.
So, what does this offer over DDU which works for both AMD and NVIDIA?
EDIT: I see, the ability to individually select things. Cool... for advanced users!
W1zzard
Administrator
28,268 (3.72/day)
Memory 48 GB
Clean install _removes_ everything before installing, but won't let you select all those individual components, like Telemetry
Edit: maybe a better name could be found? I'm open to suggestions
Edit: Updated build in first post to fix some bugs
95 (0.03/day)
System Name Front Room PC
Processor Ryzen 7 1800x @ 4.05Ghz
Motherboard MSI X370 XPower Gaming Titanium
Cooling Noctua NH-U12S SE-AM4
Memory G Skill TridentZ 2x8GB @ 3133Mhz (14, 15, 16, 28)
Video Card(s) Gigabyte GeForce RTX 3070
Storage Samsung 960 Evo M.2 250GB, Crucial MX300 700GB plus couple of regular HDD's for storage.
Display(s) BenQ GW2765HT (main) or LG OLED55B6V (when missus is out)
Case FD R5 Black
Power Supply Seasonic Focus GX-650
Mouse Logitech MX 518
Keyboard Corsair K40
Just used it, seemed to work a treat. Good stuff!!!
Edit: Tried it on the main PC and it fails prompting me to install GFE.
Edit 2: Several attempts later with different drivers yields the same result. @W1zzard Twas a clean install of the drivers each time on the system shown in my specs, Windows fully up to date.
Regeneration
NGOHQ.COM
3,139 (0.44/day)
Nvidia Customizer, Nvidia Condomizer, Nvidia Dietitian, NVLite.
Would be nice if the tool perform a little cleanup before installing.
I normally delete all Nvidia files, folders, and the following registry entries before installing a new driver:
HKCU\Software\NVIDIA Corporation
HKLM\Software\NVIDIA Corporation
HKLM\Software\Wow6432Node\NVIDIA Corporation
HKLM\System\CurrentControlSet\Control\GraphicsDrivers\Configuration\*
HKLM\System\CurrentControlSet\Control\GraphicsDrivers\Connectivity\*
HKLM\System\CurrentControlSet\services\NVDisplay.ContainerLocalSystem
HKLM\System\CurrentControlSet\services\NVHDA
HKLM\System\CurrentControlSet\services\nvlddmkm
HKLM\System\CurrentControlSet\services\NvTelemetryContainer
HKLM\System\CurrentControlSet\Control\Video\* except of {42cf9257-1d96-4c9d-87f3-0d8e74595f78}, {42cf9257-1d96-4c9d-87f3-0d8e74595f78}, {DEB039CC-B704-4F53-B43E-9DD4432FA2E9}
HKLM\System\CurrentControlSet\Control\Class\{0475BB51-5A02-4EE0-B36C-29040FAD2650}
HKLM\System\CurrentControlSet\Control\Class\{6FAE73B7-B735-4B50-A0DA-0DC2484B1F1A}
HKLM\System\CurrentControlSet\Control\Class\{A73C93F1-9727-4D1D-ACE1-0E333BA4E7DB}
HKLM\System\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\000*
C:\Program Files\NVIDIA Corporation
C:\Program Files (x86)\NVIDIA Corporation
C:\ProgramData\NVIDIA
C:\ProgramData\NVIDIA Corporation
C:\Users\Profile\AppData\Local\NVIDIA
C:\Users\Profile\AppData\Local\NVIDIA Corporation
C:\Users\Profile\AppData\Roaming\NVIDIA
520MB for a graphics driver. Ridiculous. There are several Linux distros that take less disk space.
W1zzard
Administrator
28,268 (3.72/day)
Memory 48 GB
Clean install option in drivers does all that I think
Mindweaver
Moderato®™
8,357 (1.44/day)
Charleston, SC
System Name Tower of Power / Delliverance
Processor i7 14700K / i9-14900K
Motherboard ASUS ROG Strix Z790-A Gaming WiFi II / Z690
Cooling CM MasterLiquid ML360 Mirror ARGB Close-Loop AIO / Air
Memory CORSAIR - VENGEANCE RGB 32GB (2x16GB) DDR5 7200MHz / DDR5 2x 16gb
Video Card(s) ASUS TUF Gaming GeForce RTX 4070 Ti / GeForce RTX 4080
Storage 4x Samsung 980 Pro 1TB M.2, 2x Crucial 1TB SSD / NVM3 PC801 SK hynix 1TB
Display(s) Samsung 32" Odyssy G5 Gaming 144hz 1440p, 2x LG HDR 32" 60hz 4k / 2x LG HDR 32" 60hz 4k
Case Phantek "400A" / Dell XPS 8960
Audio Device(s) Realtek ALC4080 / Sound Blaster X1
Power Supply Corsair RM Series RM750 / 750w
Mouse Razer Deathadder V3 Hyperspeed Wireless / Glorious Gaming Model O 2 Wireless
Keyboard Glorious GMMK with box-white switches / Keychron K6 pro with blue swithes
VR HMD Quest 3 (512gb) + Rift S + HTC Vive + DK1
Software Windows 11 Pro x64 / Windows 11 Pro x64
Benchmark Scores Yes
Nice! Do you plan to add Tooltips? It would also be cool to add pre-sets for streamers, 3d vision, etc; along with the current All, Recommended, and Minimum pre-sets. :toast:
qubit
Overclocked quantum bit
17,865 (2.84/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Interesting utility, very nice.
@W1zzard I'm just wondering though, wouldn't the utility potentially have to be updated at every driver release, since NVIDIA could change things unexpectedly that could break the utility?
W1zzard
Administrator
28,268 (3.72/day)
Memory 48 GB
Not every driver release, but yes, sometimes breaking changes happen, like everywhere else.
I just got tired of removing all those driver components by hand, every time I install a new graphics drivers, so I wrote this utility
339 (0.14/day)
On my old laptop first start was kinda slow for some reason, maybe there was some background process. Second launch was okay.
I have GT330M, latest driver is from 2016. Still offers the last 5 nv driver. I will check later with another pc.
Is your program offer the last 5 nv driver only?
bug
14,125 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Wth, I didn't know NodeJS has crept its way into Nvidia drivers.
W1zzard
Administrator
28,268 (3.72/day)
Memory 48 GB
I think the slowdown is due to .net compiling the assembly on first run, or could just be the time it takes for .net framework to start
Right now it only has the last 5 drivers, yes. I'll add more, and show the correct driver for your hardware, too
bug
14,125 (3.96/day)
Nvidia tends to keep a legacy line of drivers that includes support for products long forgotten. Are you including or planning to include drivers versions from that branch, too?
I.e. the mainline drivers currently sit at 416.xx, while support for 9000 series is still offered in 342.xx drivers.
Mussels
Freshwater Moderator
58,412 (7.84/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
'get more info by clicking' doesnt seem to work yet
i like the concept, thought this was a driver cleaner first, instead of a tweaked installer
edit: it keeps stalling out while downloading the drivers with no option to restart/pause/resume the download. testing now with a local driver file.
edit 2: wasnt clear it needed an unzipped copy of local files to work, should try and make it work with the original nvidia .exe installers if possible
online and local keeps sticking in the same spot:
Status
