NVIDIA Claims 16-Pin Power Connector Issues are Over, No More Melting
freeagent
10,206 (4.27/day)
Winnipeg, Canada
System Name Step_sis Rodeo
Processor AMD R9 9900X
Cooling Thermalright Aqua Elite 360 V3, 6x TL-B12 V2
Memory 2x16GB Lexar Ares @ 6000 30-36-36-68 1.35v
Storage WD SN850 1TB, SN850X 2TB, 3x SN770 1TB
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Yes because looks is the number one thing people care about in power delivery. Not safety, not reliability, not ease of use etc. Looks. /s
Yes, because it is really hard to plug something in. Difficulty. /s
838 (0.21/day)
Poland
System Name Proper
Processor 5900X + OC
Motherboard GB X570s Elite AX
Cooling WC Heatkiller 3.0 LT
Memory G.Skill 3600 CL16
Display(s) GB M32Q
Case Fractal Define R6 USB C
Mouse Log G502 X LS
Software Win10 Pro
Nvidia used Gamers Nexus' credibility to silence everyone that was saying that there was a problem with the connector and unfortunately Steve was insisting on the user error story for way too long after that initial video. Now Nvidia says that the user error problem wasn't a user error problem but something that was fixed with a new revision of the connector.
Gamers Nexus went with the user error claim since it worked in a test bench environment, but he made a video later on saying the 12v connector is a dumpster fire and wasn't fool proof enough
^THIS
It wasn't that the connector was faulty and caused fires - the failure rate is still few % at most - there are plenty of cards and cables running properly without any problems. The problem is that the connector can become unsafe with a moderate ease by the user.
What nV claims now is not that they fixed the defect, but that they made it more fool proof. Whether it's true or not... we shall see.
As for GN - his jokes may not be funny and videos are sometimes on the verge of being boring, but he is pretty throughrough with his testing and 'investigations'.
1,113 (0.32/day)
Latvija
Motherboard Asus
Memory 4GB Samsung
Video Card(s) rx 460 4gb
Storage 750 Evo 250 +2tb
Audio Device(s) Pioneer
Power Supply 430W
Mouse Acme
Keyboard Trust
You need solder on larger wires and connector.
544 (0.10/day)
System Name Very old, but all I've got ®
Processor So old, you don't wanna know... Really!
Its fine. And its better than looking at 3x 8 pins hanging out of the side of your card.
Imagine if there was 4? Man that would look even goofier.
Cover the side panel/glass, and problem solved. People supposed to look at the screen, not onto the connectors.
Besides, if they work without issues, there's no problem. At least the 8-pin ones do not have the required bending angle issue.
freeagent
10,206 (4.27/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
6,977 (1.41/day)
Case NZXT PHANTOM410-BK
Power Supply Corsair 850W
Mouse Logitech Hero G502 SE
3,655 (0.87/day)
Athens, Greece
Oh and there zero RGB in it or in any of my peripherals. Just the way i like it.
Big mistake
1,717 (0.77/day)
Motherboard MSI X670E Carbon
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
Display(s) Samsung G8 OLED
Case Silverstone FT04
When GN tried to recreate the connector melting they even cut most of the cables so that the load goes only through 1-2 of them and nothing happened. 20-30% more power going through it won't change anything - it's all about removing the risk of contact points barely touching each other, creating high resistance.
While GN also told us the connector design is a dumpstar fire, without audible clicks it is wide open for installation error, and without a physical lock( it is just a friction lock ) the connector could walk itself off just by the force from doing cable management.
its interesting Nvidia blames it on user error even though they quickly revised the connector.
true.
If it ain't broke , don't fix it.
If they fixed it, it was broken.
Every revision costs them millions of dollars, they won't fix it for no reason.
389 (0.44/day)
Los Angeles, CA
Processor AMD Ryzen 7 9800X3D (+PBO 5.4GHz)
Motherboard MSI MPG X870E Carbon Wifi
Cooling ARCTIC Liquid Freezer II 280 A-RGB
Memory 2x32GB (64GB) G.Skill Trident Z Royal @ 6200MHz 1:1 (30-38-38-30)
Video Card(s) MSI GeForce RTX 4090 SUPRIM Liquid X
Storage Crucial T705 4TB (PCIe 5.0) w/ Heatsink + Samsung 990 PRO 2TB (PCIe 4.0) w/ Heatsink
Display(s) AORUS FO32U2P 4K QD-OLED 240Hz (DP 2.1 UHBR20 80Gbps)
Case CoolerMaster H500M (Mesh)
Audio Device(s) AKG N90Q w/ AudioQuest DragonFly Red (USB DAC)
Power Supply Seasonic Prime TX-1600 Noctua Edition (1600W 80Plus Titanium) ATX 3.1 & PCIe 5.1
Mouse Logitech G PRO X SUPERLIGHT
Keyboard Razer BlackWidow V3 Pro
Software Windows 10 64-bit
Let's hope so because when I bought my 4090, I was definitely checking the cable pretty often... Even now I still check from time to time just to make sure!
I bought a Seasonic Prime TX-1600 Noctua Edition (ATX 3.1 / PCIe 5.1) and am waiting for the 5090 for that and DisplayPort 2.1 (UHBR20) so I can use DSR/DLDSR on my 4K@240Hz QD-OLED monitor.
2,727 (1.97/day)
Here I though there were never any power connector issues :rolleyes:
As broken as the class actions system is, the statements from this press event should be exhibit A on one against nvidia for both selling this and pushing partners to do the same.
102 (1.11/day)
There are many repair shops that do not share nv's opinion on this not happening for 2 years now, or shall we call it for what it is... an outright lie.
143 (0.13/day)
Simply switching good ol' 8-pin to mandatory AWG14 would've fixed this "issue." (by "issue" I mean having more than one power cable)
12AWG wire and a single XT60 connector should be enough, although voltage drop might be an issue. But then you'll have stupid users plugging in lithium batteries to power their GPUs.
3,841 (5.01/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Memory 32 GB DDR4-3200
Storage Yes.
Display(s) MSi G2712
Audio Device(s) Yes.
Software Windows 11 / 10 / 8
603 (0.71/day)
^THIS
Exactly , there isn't enough of a safety margin, even if the failure rate is 1-2% thats still too high for what is supposed to be a better connector. There are several tech repair youtubers I know of still repairing melted 4090 connectors, NorthridgeFix claims to get in 4090's with melted connectors every day. And I doubt people with the money to throw around buying $2k graphics cards are too dumb to plug them in correctly.
I'm not saying I don't like GN at all though, GN is one of my favorite tech youtubers, he doesn't hold back on companies and is willing to take a loss in the interest of helping the tech community.
2,727 (1.97/day)
I think you're joking but why not, be it XT60 or any of the dozens of established high power connectors why did they need to go with this shitty one!? :wtf:
This will never make sense to me
143 (0.13/day)
I'm semi joking. It's smaller than the 8 pin and doesn't need precise soldering. They will need 12 AWG fine stranded wire, otherwise you'd run into wire bending issues, and maybe stress on the PCB. There's plenty of other high current 2 pin connectors, even ones that lock with sense pins. I think we can all agree that moving to a connector with less surface area while increasing GPU power draw, was a terrible idea, and that there were way better options available to condense the power connectors.
3,901 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Some cables are to be fair. They can be made too tight, and with poor click mechanics.
The 4000 series connector and cable design was just idiotic, they literally could not have made it worse, lets put it all together.
New connector and cable that requires cable to not be bent for first 3cm.
Combined with, taller GPU that sits much nearer to edge of case meaning the majority of cases dont have 3cm clearance.
Combined with, right angled connector sticking straight out, even more of a shocker, is it was angled the previous gen, someone went out their way to make it right angled for 4000 series.
Combined with a stiff cable.
Its as if they only tested it on a bench or something.
Of course we then had the original design as well that used sense pins which were allowed to make contact with partially inserted cables.
The 5000 series after the bad PR from the issues, clearly had a thought process behind the design, but there is no excuse for how bad they got it wrong on the 4000 series.
1,192 (4.91/day)
Warning here comes a troll post.
NVIDIA Claims 16-Pin Power Connector Issues are Over, No More Melting​
There are no issues with it. Not worth discussing. There are only user errors. It's the buyers fault. It's the users fault. - End of troll post - I am sorry.
14,494 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
GN concluded it was user error, quickly washed their hands of it, and NVIDIA ran with it so they didn't have to honor repairs under warranty. Pretty sus move from GN imo. NorthRidgeFix deemed it a design issue with board power delivery and the connector itself. I just find it hard to believe that all of these people aren't insertting the connector properly after all of the buzz surrounding it and the high cost of these 4090s. But we'll see with the 5090 if they fixed it.
Why don't you just say you don't understand how the user error occurred.
Apparently it is from the number of connectors I've seen not seated correctly, or the cables pulled that tight, they place undue strain on those connectors.
2,727 (1.97/day)
Not only better options, but also very easy to find, they could have just used a 12 pin minifit instead of microfit. Even if they were already thinking of placing the connector vertically like it is on the 5090, a 12pin minifit would still be small enough to fit like that (it's around ~26.4mm, it's almost small enough to fit a 20.32mm single slot card!)
80 (0.05/day)
If the connectors are melting from an engineering failure, then it isn't the user's fault. If the engineers don't allow a sufficient margin of error or don't have sufficient protections in place to ensure reliability, then it is an engineering failure, not user error.
I think we can all agree that the 12VHPWR connector is a failed design. The 12V-2x6 has been used for a while now, and I haven't heard of any reports of those melting, so that indicates that they fixed the shortcomings of the connector. All that's really left is confirming that this connector can handle a 5090 in a variety of builds.
2,473 (2.69/day)
Braziguay
Processor AMD Ryzen 7 5700X3D
Case Lian Li Lancool 216
Mouse Razer Viper Ultimate
Especially as only the FE has the angled connector on the board so far, everyone else is putting the cable perpendicular against the case side.
