What do you call the derbauer video then? Clearly another user error...
I already posted this guide for installing a computer cable:
but like you say... should come with the connectors on the gpu then. Or in this case, it could be done on a pin per pin basis, like in the 3090ti (with like almost zero melted cable issues). Ofc. the thermal limit is a bit too close to comfort on a single 12pin and having more heat dissipation...
www.techpowerup.com
- Make sure that the cable you are using is in good condition, especially the plugs. In case of brand new cables from reputable producers you may skip this step, but of course you could look in the plugs to see, if any foreign object did not fall in the plugs during packing and shipping.
- In case the wires are bent from the packing of the cable, straighten the cable fully.
- According to the planned location of the wires, bend or form the wires in advance to make mounting the wires on the chassis and inserting the plug easier.
- Support the object into which you insert in the moment of insertion, so that the object does not deform, or move, to avoid any damage.
- Insert the plug straight and fully, make sure that the latching mechanism secures the plug in place.
- Mount the cable leading to the plug on the computer chassis so that there is a slack of wire at the plug and the wire does not exert any unnecessary force on the plug.
- Make sure that after closing the PC case or placing other components in the case the condition in point 6 does not change
And yes, I believe the original user made some errors according to this guide, and DerBauser used his own trash cable for the video.
There in another aspect in this: Notice, how the original cable resembles a thick sausage instead of a cable. It has
enormous amount of sleeving put on the wires, which prevents the wires to slide on each other and which adds so much bulk on the cable, that when you bend the cables close to the plug, the
individual wires would be leveraging on each other and pulling themselves out of the socket. The outer cables have the most leverage on them. It is not a coincidence that the corner connector in the plug heated up. Most likely it was yanked out of the plug and it had a poor contact with the pin.
So the producer of the cable here is to blame too. They transformed the cable into a plug destroyer with all that dumb unnecessary sleeving on the cables.
