NVIDIA GeForce RTX 4060 Ti to Feature Shorter PCB, 220 Watt TDP, and 16-Pin 12VHPWR Power Connector
3,966 (0.60/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
When will the non-ti be widely available?
393 (0.19/day)
System Name Cyberdyne Systems Core
Processor AMD Sceptre 9 3950x Quantum neural processor (384 nodes)
Motherboard Cyberdyne X1470
Memory 128TB QRAM
Video Card(s) CDS Render Accelerator 4TB
Storage SK 16EB NVMe PCI-E 9.0 x8
Display(s) LG C19 3D Environment Projection System
Power Supply Compact Fusion Cell
Software Skysoft Skynet
Poor evil nvidia :kookoo:
RTX 3060 Ti - 4864 shaders, 8 GB, 200 watts
RTX 4060 Ti - 4352 shaders, 8 GB, 220 watts
So, 4060 Ti will be slower and yet more power hungry? :kookoo:
No way will the 4060 Ti be slower than the 3060 Ti. Will probably be similar perf to a 3080, just with 2GB less ram, and DLSS3 support.
544 (0.08/day)
System Name Ed-PC
Processor Intel i5-12600k
Motherboard Asus TUF Z690 PLUS Wifi D4
Cooling Noctua NH-14S
Memory Crucial Ballistix DDR4 C16@3600 16GB
Video Card(s) Nvidia MSI 970
Storage Samsung 980, 860evo
Case Lian Li Lancool II mesh Perf
Power Supply Corsair RM750x
Software Win10 Pro 64bit
The 4080 has slightly fewer shaders then the 3090 and a narrower memory interface. It still ends up ~20% faster.
The 4080 has 736 GB/s BW, thats good, this 4060ti only uses DDR6 at 18gbps with a 128 bit bus and BW of 288 GB/s, way down from 448 GB/s of 3060ti
This seems more what a 4060 should be.
ARF
4,670 (2.52/day)
Ex-usa | slava the trolls
3070 or 3070 Ti max.
bug
14,107 (3.96/day)
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
The original 3060Ti which the 4060Ti compares to also uses GDDR6. So it's apples-to-apples.
214 (0.15/day)
GDDR6X is pricey... :rolleyes:
But they're already selling RTX 3060Ti with GDDR6X memory (which, according to a report, should replace the vanilla GDDR6 SKUs)... All in all these GPUs look weird, even more so if the previous rumours about the 128bit memory interface are confirmed, bandwidth would be halved when compared to the RTX 3060Ti GDDR6X (288GB/s vs 608GB/s), I wonder if the larger L2 cache would be enough to compensate.
183 (0.05/day)
It won't be anywhere near a 3080 if these specs are accurate. More like somewhere around the 3070 or 3070 Ti, with Nvidia shilling it hard through DLSS 3 benchmarks. Keep in mind that we still have the regular 4070 to come yet. That'll be the card that slots in at 3080-ish performance.
539 (0.35/day)
Processor Ryzen 5 7600X
Motherboard ASRock B650M PG Riptide
Memory DDR5 6000Mhz CL28 32GB
Video Card(s) Nvidia Geforce RTX 3070 Palit GamingPro OC
Storage Corsair MP600 Force Series Gen.4 1TB
Calling it now: 3070ti performance for 3070ti money but 2 years after and with a crap power connector. Now with fake interpolated frames! It's safe to upgrade.
4060ti will be slower than 3070 non TI
393 (0.19/day)
Memory 128TB QRAM
Maybe, but I'd say these specs are inaccurate. Memory bandwidth seems way too low. 2060 was about the same as a 1080, there was no 2060 Ti. 3060 Ti is faster than a 2080 Super though. So I hope this isn't a step back, surely they'd go for 3070 Ti perf as a bare minimum.
ARF
4,670 (2.52/day)
They won't go back - it's profiteering, they will simply rebadge the RTX 3060 Ti and call it a day. They don't even need a new chip, just new stickers on the boxes, 10% overclock and it's ready.
1,771 (0.88/day)
Processor 7800X3D 2x16GB CO
Motherboard Asrock B650m HDV
Cooling Peerless Assassin SE
Memory 2x16GB DR A-die@6000c30 tuned
Video Card(s) Asus 4070 dual OC 2610@915mv
Storage WD blue 1TB nvme
Case Corsair D4000 Airflow
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Benchmark Scores Superposition 8k 5267 Aida64 58.5ns
It will clock about 1000MHz higher so I bet we get about 40% higher performance or about 3080 performance :)
393 (0.19/day)
Memory 128TB QRAM
Probably more like 700MHz higher. But the memory bandwidth needs to be wrong in this "leak". It's too restricting.
bug
14,107 (3.96/day)
It depends. QHD has half as many pixels as UHD, so you need half the bandwidth to push the same frame rate.
Personally, I was already avoiding 128bit memory buses 10 years ago, I'm not going to jump all over them now.
139 (0.06/day)
Finland
System Name No name, yet..
Processor AMD 1800X at stock settings.
Motherboard AsRock X370 itx/ac, /diy vrm heatsink.
Cooling Alphacool Eisbaer 240LT.
Memory 2 x 8gb G.Skill Flare 3200/CL14.
Video Card(s) Gigabyte RTX 2060 oc rev2.
Storage Samsung 960 Evo 500GB m.2, Crucial MX500 2TB sata.
Display(s) HP ZR24W.
Case DIY ITX.
Power Supply Be Quiet 500W sfx-l
Software Win10 home, Ubuntu linux.
There are 12 memory chips in that picture. Something is wrong, be it 8Gb or that picture.
Seems to be old picture, my bad.
8,800 (4.01/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Oh dear, 8GB for a card that's lauching Q2 of 2023 and expected to be relevant until 2026?
At 1440p I'm using 7GB+ VRAM on my 3070 in a number of 2021/2022 games. Hell, even Doom Eternal from 2020 is 7GB. Let's just hope they repeat the 3060's 12GB configuration for the 4060.
ARF
4,670 (2.52/day)
Performance doesn't scale in this way. Many tests in the most recent reviews show very negligible performance decreases with improved resolution.
For example, Forza Horizon:
2160p - 103.7 FPS
1440p - 136.9 FPS
1080p - 149.3 FPS
AMD Radeon RX 7900 XT Review - Forza Horizon 5 | TechPowerUp
Bits are irrelevant, what is important is the type of memory - GDDR7, GGDR7+, etc will be very wide even with 128-bit link.
7,608 (5.01/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
Let's compare RTX 3090 Ti and RTX 4090.
RTX 3090 Ti - 10752 shaders at 1860 MHz
RTX 4090 - 16384 (52% more) shaders at 2520 MHz (35% higher)
Net performance increase: 45%.
So, RTX 4090 has 52% more shaders at 35% higher clocks and yet manages to return only 45% higher performance.
Not the same architecture as stated earlier. Not comparable. Scaling also isn't linear with more cores: the maximum examples of this are Radeon Fiji and Vega 10, both 56 CU and 64 CU variants performed exceedingly close to each other.
135 (0.11/day)
USA
System Name Star Killer
Processor Intel 13700K
Motherboard ASUS RO STRIX Z790-H
Cooling Corsair 360mm H150 LCD Radiator
Memory 64GB Corsair Vengence DDR5 5600mhz
Video Card(s) MSI RTX 3080 12GB Gaming Trio
Storage 1TB Samsung 980 x 1 | 1TB Crucial Gen 4 SSD x 1 | 2TB Samsung 990 Pro x 1
Display(s) 32inch ASUS ROG STRIX 1440p 170hz WQHD x 1, 24inch ASUS 165hz 1080p x 1
Case Lian Li O11D White
Audio Device(s) Creative T100 Speakers , Razer Blackshark V2 Pro wireless
Power Supply EVGA 1000watt G6 Gold
Mouse Razer Viper V2 Wireless with dock
Keyboard ASUS ROG AZOTH
Software Windows 11 pro
My Old 2080 Super had a 250 watt TDP.
1,164 (0.77/day)
System Name Dust Collector Mower 50
Processor E5-4627 v4
Motherboard VEINEDA X99
Memory 32 GB
Video Card(s) 2080 Ti
Storage NE-512
Display(s) G27Q
Case MATREXX 50
Power Supply SF450
I believe that 4070 is 5% slower than 3080, so 4060Ti 128 bit is nowhere near.
Oh noooos
As long as one can buy the cable separately and has a modular PSU no biggie. But in all remaining systems this is forcing people to use the ugly version.
311 (0.21/day)
System Name Office,Home and Game PC
Processor Intel Core i5 12600k Up to 4.9 GHz
Motherboard Z690 Gaming X Gigabyte DDR4 Version
Cooling Fuma 2 Air Cooler
Memory 32GB DDR4 2x16 3600 MHz Patriot Viper Steel RAM
Video Card(s) NVIDIA GeForce GTX 1080 and RTX 3070
Storage 512 GB M2 PCI Ex 3.0 NVMe SX6000 Pro, 1TB NV2 Kingston M2 PCI Ex 4.0 and 4TB WD Blue SATA 3.0 HDD
Display(s) 27 inç 75 Hz LG
Case Cooler Master MB511
Audio Device(s) Creative 2+1
Power Supply 750W 80+ Bronze PSU High Power Element
Mouse Logitech Wireless
Keyboard Microsoft
VR HMD N/A
Software Windows 10-11
With these values, even counting the 3080's insurmountable high clock speed advantage, the classic performance will be equal to that of the RTX 3070 or 3070 Ti.
632 (0.18/day)
Processor AMD Ryzen 3800X / AMD 8350
Motherboard ASRock X570 Phantom Gaming X / Gigabyte 990FXA-UD5 Revision 3.0
Cooling Stock / Corsair H100
Memory 32GB / 24GB
Video Card(s) Sapphire RX 6800 / AMD Radeon 290X (Toggling until 6950XT)
Storage C:\ 1TB SSD, D:\ RAID-1 1TB SSD, 2x4TB-RAID-1
Display(s) Samsung U32E850R
Case be quiet! Dark Base Pro 900 Black rev. 2 / Fractal Design
Audio Device(s) Creative Sound Blaster X-Fi
Power Supply EVGA Supernova 1300G2 / EVGA Supernova 850G+
Mouse Logitech M-U0007
Keyboard Logitech G110 / Logitech G110
Not a single comment about 4GB less of video memory, hm. Sniper Elite 5 uses up to 15.7GB of video memory, is the 4060 supposed to be a 720p card?
2,219 (0.43/day)
That power connector is eventually adding to additional ewaste as well.
214 (0.15/day)
Unlikely, both AD106 and AD107 are rumoured to have a 128bit memory bus configuration, if this is confirmed Nvidia is seriously cheaping out on this popular segment. I hope that at least this will translate in better prices compared to the Ampere generation, but I'm sceptical...
3,038 (0.78/day)
Mouse Razer Abyssus
Software Ubuntu
Why are you hung up in specs? Isn't real world performance what matters regardless of how it's achieved?
If someone released a fast GPU with 128-bit memory bus with a very high speed, wouldn't you consider it?
Or if someone released a quad core CPU which kicked the a** of 8-cores, wouldn't you buy it?
We are likely to see faster GDDR6X/7 soon, perhaps even with this generation.
