NVIDIA GeForce RTX 4060 Ti to Feature Shorter PCB, 220 Watt TDP, and 16-Pin 12VHPWR Power Connector
14,440 (6.48/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
I wonder why Nvidia is so determined to use the new power connector on every single card. I bet the 30 W GT 4010 will have it too (unless there won't be a 4010 because Nvidia can't be asked to make a card that doesn't cost your liver and a kidney anymore).
214 (0.15/day)
This is pretty easy to understand, they're trying to make it a standard connector. It's the same reason people used SATA connectors for optical disc drives even though they offered no real advantage over PATA. And the same reason Seagate recently introduced NVMe equipped HDDs.
3,544 (2.58/day)
Processor Ryzen 5 5700x
Motherboard B550 Elite
Power Supply MSI 750w
Mouse G502
The new connector is really a stupid idea, if it worked out so badly with the more tech savvy crowd, i can only imagine how bad it will go with cheaper models and less tech inclined buyers. Stupid decision. But then again there's pricing and no of it really matters. This things won't sell, they can't, or humanity is lost to idiocy.
1,237 (0.28/day)
California, unfortunately.
System Name Sierra
Processor Core i5-11600K
Motherboard Asus Prime B560M-A AC
Cooling CM 212 Black RGB Edition
Memory 64GB (2x 32GB) DDR4-3600
Video Card(s) MSI GeForce RTX 3080 10GB
Storage 4TB Samsung 990 Pro with Heatsink NVMe SSD
Display(s) 2x Dell S2721QS 4K 60Hz
Case Asus Prime AP201
Power Supply Thermaltake GF1 850W
True, although the lower power levels of the more mainstream oriented cards are less likely to be a problem in terms of the connector.
3,506 (1.12/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
Nvidia was not kidding when it said it wanted to be like Apple and that includes forcing unnecessary adapters on customers.
1,292 (0.27/day)
South-Africa
Processor AMD Ryzen 9 5900X
Cooling Noctua NH-D15 G2
Video Card(s) ASUS GTX 1650 TUF
Storage SAMSUNG 990 PRO 2TB
Display(s) Dell S3220DGF
Case Corsair iCUE 4000X
Those specs sound pretty bad considering the 3060ti had 4864 shader, 8gig DDR6, 256bit bus and 448 GB/s bandwidth. I would of thought 10 gig of memory and at least same BW.
These specs claim 128bit bus with 288 GB/s BW.
Seems Nvidia is shifting the whole product stack down, which is bad for price they are asking now.
Yes, people keep paying more for less, and they keep asking more for lower-tier cards and people happily fork out the cash.
This is what happens when people don't listen to those that call out their marketing bs. If we are extremely lucky, we might see normalized prices again two generations from now. Otherwise, I suggest, you start taking up another hobby.
bug
14,107 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Why are you hung up in specs? Isn't real world performance what matters regardless of how it's achieved?
If someone released a fast GPU with 128-bit memory bus with a very high speed, wouldn't you consider it?
Or if someone released a quad core CPU which kicked the a** of 8-cores, wouldn't you buy it?
We are likely to see faster GDDR6X/7 soon, perhaps even with this generation.
I should have been most specific.
For my needs (mainstream gaming, not afraid to tone down some settings), cards having 128 bit memory buses typically didn't cut it. I tend not to have high hopes for them, but I will buy depending on what the benchmarks say, not the sticker on the box.
Mussels
Freshwater Moderator
58,412 (7.85/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
High end GPU's like GTX1080 used to have a power consumption of 180W, now even mainstream models are more power hungry.
Mine overclocked hit 220W
Now the 60 series is at that wattage, which is see as backwards progression
I'm gunna have to start paying attention to perfomance per watt as the true sign of a series of GPU's being an upgrade or not - it's like the geforce FX days all over again (high wattages, screaming fans, products worse than their previous gen counterparts)
14,440 (6.48/day)
Midlands, UK
Cooling Yes
Storage A lot
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
The two triple-P's (performance per power and performance per price) are the true indicators of progress, imo.
Frames don't mean anything on their own. One can always add more cores, and bam... behold a faster GPU!
396 (0.12/day)
System Name 06/2023
Processor R7 7800X3D
Motherboard ROG STRIX B650E-I GAMING WIFI
Cooling Custom 240mm cooling (for CPU) with noctua nfa12x25 and Phantek T30
Memory 32gb Gskill 6000 CL30
Video Card(s) RTX 4070 dual asus deshrouded with 120mm NF-A12x25
Storage 2tb samsung 990 pro + 4tb samsung 870 evo
Display(s) Asus 27" Oled PG27AQDM + Asus 27" IPS PG279QM
Case Ncase M1 v6.1
Audio Device(s) Steelseries arctis pro wireless + Shure SM7b with Steinberg UR
Mouse Corsair scimitar pro (this mouse need an overall guys pls) + Logitech G Pro wireless with powerplay
Keyboard Sharkoon purewriter
Software windows 11
Benchmark Scores Over 9000 !
Poor evil nvidia :kookoo:
RTX 3060 Ti - 4864 shaders, 8 GB, 200 watts
RTX 4060 Ti - 4352 shaders, 8 GB, 220 watts
So, 4060 Ti will be slower and yet more power hungry? :kookoo:
The 4060 ti is on TSMC node, so a good chunk higher frequency so it will be faster anyway, probably 15-20% faster.
1,036 (0.62/day)
System Name Dirt Sheep | Silent Sheep
Processor i5-2400 | 13900K (-0.02mV offset)
Motherboard Asus P8H67-M LE | Gigabyte AERO Z690-G, bios F29e Intel baseline
Cooling Scythe Katana Type 1 | Noctua NH-U12A chromax.black
Memory G-skill 2*8GB DDR3 | Corsair Vengeance 4*32GB DDR5 5200Mhz C40 @4000MHz
Video Card(s) Gigabyte 970GTX Mini | NV 1080TI FE (cap at 50%, 800mV)
Storage 2*SN850 1TB, 230S 4TB, 840EVO 128GB, WD green 2TB HDD, IronWolf 6TB, 2*HC550 18TB in RAID1
Display(s) LG 21` FHD W2261VP | Lenovo 27` 4K Qreator 27
Case Thermaltake V3 Black|Define 7 Solid, stock 3*14 fans+ 2*12 front&buttom+ out 1*8 (on expansion slot)
Audio Device(s) Beyerdynamic DT 990 (or the screen speakers when I'm too lazy)
Power Supply Enermax Pro82+ 525W | Corsair RM650x (2021)
Mouse Logitech Master 3
Keyboard Roccat Isku FX
VR HMD Nop.
Software WIN 10 | WIN 11
Benchmark Scores CB23 SC: i5-2400=641 | i9-13900k=2325-2281 MC: i5-2400=i9 13900k SC | i9-13900k=37240-35500
Apply DLSS3.
Fix.
#sarcasm
23,317 (6.12/day)
In the end, yeah I do that too. Thing is also, memory was always a juggle with regards to memory bus width. Its a cost and an energy budget aspect there too. If they can make more efficient (use of) memory, that's a win, in the end. As long as there are no painful sacrifices.
And that's Ampere's first line up, for sure in a nutshell. With Ada it seems memory is in a better place, but the bandwidth similarities between two cards with very different core power is an interesting one. How good is that cache and where will it fall short...
3,038 (0.78/day)
Mouse Razer Abyssus
Software Ubuntu
Also remember standards are usually used in workstations and server racks too. I'm sure those customers will be super enthusiastic for a bad standard nobody needed.
On the positive side, RTX 40 series cards will probably be very valuable to collectors 20 years from now… :rolleyes:
(sarcasm)
I hope at least some RTX 40 series AIB cards have standard 8-bit plugs.
And BTW, where did all the new PSUs with ATX 3.0 go? It's been awfully quiet for a while. I wonder if they holding them back, revising the standard, or something else is going on?
214 (0.15/day)
Actually adaptation is probably going to be faster in those segments, Intel has already shown that their Data Center GPU Max 1100 will use the 16pin connector in its PCIe form factor version, despite the fact that it's a 300W GPU.
Sooner or later even AMD will adopt it, unless they're expecting people to use four 8pin connectors in the RX 8900 XTX OC...
Mussels
58,412 (7.85/day)
Oystralia
price i care less about because i can always wait and buy year old or second hand hardware (as can anybody, simply wait for a sale)
No amount of waiting makes high wattage cards any more efficient, and historically the most loathed cards are the highest wattage ones (especially above 250W) - always remembered as hot, noisy and failing early (as the cooling weakened, general users rarely even replace thermal paste let alone thermal pads on VRM's and VRAM)
310 (0.06/day)
System Name Uzuki Toune
Processor AMD RYZEN 7 7700X (ASUS PBO 90C Mode)
Motherboard Asus ROG Strix X670E-E Gaming WIFI
Cooling Thermalright Frostspirit 140 White V3 ARGB
Memory 32GB DDR6000 CL36 Kingston (EXPO)(16GBx2)
Video Card(s) Zotac GTX 1050TI
Storage 2TB Kingston KC3000 + 1TB Crucial P2 + 480GB Samsung Evo 850 + 480GB Kingston A400
Display(s) Dell U2723QE + Philips 221V8 (Portrait)
Case NZXT H510
Audio Device(s) Auzen X-FI Forte + Onboard Realtek 4080 -> Creative Gigaworks T40II
Power Supply EVGA G+ 650W
Mouse Logitech MX Master 3 (Work) & G103 (Play)
Keyboard iRocks K71M
807 (0.18/day)
Poland
System Name THU
Processor Intel Core i5-13600KF
Motherboard ASUS PRIME Z790-P D4
Cooling SilentiumPC Fortis 3 v2 + Arctic Cooling MX-2
Memory Crucial Ballistix 2x16 GB DDR4-3600 CL16 (dual rank)
Video Card(s) MSI GeForce RTX 4070 Ventus 3X OC 12 GB GDDR6X (2610/21000 @ 0.91 V)
Storage Lexar NM790 2 TB + Corsair MP510 960 GB + PNY XLR8 CS3030 500 GB + Toshiba E300 3 TB
Display(s) LG OLED C8 55" + ASUS VP229Q
Case Fractal Design Define R6
Audio Device(s) Yamaha RX-V381 + Monitor Audio Bronze 6 + Bronze FX | FiiO E10K-TC + Sony MDR-7506
Power Supply Corsair RM650
Mouse Logitech M705 Marathon
Keyboard Corsair K55 RGB PRO
Software Windows 10 Home
Benchmark Scores Benchmarks in 2024?
This generation is turning into a joke. 8 GB with a 128-bit bus? For how much, $500? And this is supposed to last 2 years with truly next-gen games not existing yet?
This is what we should be seeing at these super high prices:
4080 Ti - cut down AD102, 320-bit, 20 GB
4080 - full AD103, 256-bit, 16 GB (G6X)
4070 + Ti - cut down AD103, 256-bit, 16 GB (G6 non-X)
4060 + Ti - AD104, 192-bit, 12 GB (G6 for 4060, G6X for Ti)
4050 - AD106, 128-bit, 8 GB
While the L2 cache might help with the narrow memory buses, the VRAM capacity will be a huge problem in the coming years, especially with ray tracing.
People should really buy the RTX 30 series and the RX 6000 series while they are still available at good prices. Ignore this new garbage and wait 2 years for the next generation.
2,367 (0.50/day)
System Name msdos
Processor 8086
Motherboard mainboard
Cooling passive
Memory 640KB + 384KB extended
Video Card(s) EGA
Storage 5.25"
Display(s) 80x25
Case plastic
Audio Device(s) modchip
Power Supply 45 watts
Mouse serial
Keyboard yes
Software disk commander
8GB is a joke, unbalanced specs. Fast card, too little vram.
3,038 (0.78/day)
Mouse Razer Abyssus
Software Ubuntu
Didn't many people say the same thing about the 20 and the 30 series too? It seems like there is a lot of complaining ahead of every Nvidia launch these days.
But I don't believe Nvidia will launch "bad" cards in the RTX 4060 / 4060 Ti segments.
807 (0.18/day)
Poland
System Name THU
The 20 series was expensive, but it introduced RT and tensor cores. Those chips were huge, but raster performance was not that much better than Pascal.
I do not remember people complaining about the 30 series, at least the 3080 and 3070. I mean I pre-ordered the 3080 on day 1. For $700 it gave me 80% more performance (100% in RT) over my 2070 Super that I paid $500 for a year before. It is one of NVIDIA's best cards ever, incredible value.
The lower tier cards were not as impressive, though. But the bigger problem was that you could not buy them at MSRP. And now that you can, Radeon cards are sooo much cheaper.
If you look at the GTX 1060, you can realize how badly NVIDIA is screwing over the mid-range segment these days. That was 980 performance with more VRAM for just $250.
Even the 2060 offered 1080 performance on average at $350. But the 3060 only offered 2070 (non-Super) performance at "$330". And the 4060 is supposed to offer 3070 performance at $400 according to leaks. Not only is the price going up (which can be understandable), but the performance gains are going down (which is not). It should be one or the other.
14,440 (6.48/day)
Midlands, UK
Cooling Yes
Storage A lot
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
The 960 and 1060 are legendary cards, imo. They represent everything Nvidia should be. They're high-tech, innovative, energy-conscious mid-range cards with no over-the-edge requirement for cooling. "The way it's meant to be played" as they say. A lot of people complained about Turing, but I had no issue with it - it was all about introducing ray tracing to an architecture that is otherwise similar to Pascal. It was with Ampere that all went downhill. First with blaming covid, then the chip shortage (yeah, right...), crypto miners, scalpers, etc. And now with Ada, Nvidia is doing the scalping themselves. They seem to think that mining is still a thing and they can do whatever they want, and as long as sales justify it, they will.
3,038 (0.78/day)
Mouse Razer Abyssus
Software Ubuntu
The 960 and 1060 are legendary cards, imo. They represent everything Nvidia should be…
GTX 960 was great, but GTX 970 was an even greater deal. Despite all the misconceptions and FUD about the slower 0.5 GB VRAM, it was really a card which performed very close to GTX 980, thanks to striking a better resource balance achieving higher performance per GFLOP than the rest of the series.
While I agree that prices these days are too high, this mostly applies to the high-end models. The mid-range models, albeit being a little pricey, is nowhere that bad. (This is also where there is some competition)
But my bigger point to what THU31, xorbe and many others said; they basically are hung up on specs. It's very common that people prejudge products this way based on specs, even though none of us knows the final spec or performance level. And I'm pretty sure many of people like this will change their tune once the products arrive, realizing they are "better than expected", etc. I've followed this too long not to notice this pattern.
So to restate what I said in #70, I don't think Nvidia will launch "bad" cards in this segment, they can afford to do that. These cards will make up a good share of their revenue.
43,700 (6.78/day)
Force us into it like the intel 12vo deal
807 (0.18/day)
Poland
System Name THU
The specs seem worse than they actually are (because of L2 cache and very high clocks), but the point is that we are getting smaller performance gains while prices are increasing. It would be very different if the 4060 was supposed to offer 3080 performance at $400, instead of 3070 performance.
And VRAM capacity is an actual problem. 8 GB was already problematic on the 3070.
660 -> 960 - 37% performance increase with a 15% price decrease (I am ignoring the 760 because it was a refresh)
960 -> 1060 - 100% performance increase with a 25% price increase (there was also a slightly slower model with 3 GB at just $200, same as 960)
1060 -> 2060 - 56% performance increase with a 40% price increase
2060 -> 3060 - 21% performance increase with a 6% price decrease
3060 -> 4060 - ~45% performance increase with a 21% price increase (if leaks are true)
It seems pretty clear why the 1060 was the number 1 card on Steam for almost 6 years. And it is beyond my comprehension why they do not want to achieve the same success with any card after that. Corporations' obsession with margins instead of overall profits is incredible (I experienced that myself working for one).
