NVIDIA Shares Details About Ampere Founders Edition Cooling & Power Design - 12-pin Confirmed
109 (0.06/day)
Lets see. On the one hand, there's Chrispy_, a dude who has been discussing things reasonably with over at TechReport for over a decade and has proven himself to me (multiple times) to have a sharp mind.
On the other hand, there's Jinxed, with ~50 posts in history. And literally every single one of them is about Nvidia vs AMD bullshit I don't give a care about. Someone who gets flustered over the simple mention of ambient occlusion and... floating point numbers.
Clean up your posting history Jinxed. Start posting about other topics, and prove yourself to me if you expect me to take yourself seriously.
Says the guy who was trying to make a point comparing light propagation in corners of rooms with completely different materials on walls. Yeah right. I take you sooooo seriously after that.
2,838 (1.60/day)
These are repeating chunks of ordered noise, tiles - as I have called them - that cannot be true raytracing. It doesn't match gaussian/quantization noise that you'd get from a non-infinite number of rays and it has no place being there.
I've actually looked at lots of RNG patterns before. A repeating pattern like that could be explained by a PRNG, like XORShift. Honestly, to me, it looks like its "well randomized", but with a relatively small tile.
Most GPUs these days are only fast with 32-bit numbers. I'm going to guess that they just have a small PRNG state, so the "tiles" will be small. They're using something higher quality than your typical Unix LCGRNG for sure (see here for LCGRNG patterns: http://www.reedbeta.com/blog/quick-and-easy-gpu-random-numbers-in-d3d11/).
32-bit cycles go fast (4-billion is pretty small, all else considered), and many PRNGs fail at actually randomizing their bit differences... so you'll get repeating patterns over the 32-bit cycles. Especially if you're seeing the same pattern over and over again? Seems like the seed has just "cycled over" like an odometer.
EDIT: 1920 x 1080 x 8000 samples == 16-Billion samples. Enough to overflow a 32-bit PRNG four times. Just for some napkin math (and each sample may use more than one RNG value in the raytracing). Throw down some low-quality lower bits, and a "pattern" could very well emerge.
Just my opinion on that matter though.
109 (0.06/day)
Patterns can even be intentional, like here, for example:
"Ray tracing has two quality settings: high and ultra. Ultra setting traces up to one ray per pixel, with all the denoising and accumulation running in full. The high setting traces up to 0.5 rays per pixel, essentially in a checkerboard pattern, and one of the denoising passes runs as checkerboard. We recommend high for the best balance between image quality and performance, but please note that we are still experimenting a lot, so this information is valid only at the time of writing."
Interview on Metro Exodus with the developer's CTO and rendering programmer
But the pattern is about where the rays are cast, not about replacing or faking something with some kind of artificial tiles that Crispy is making up. It's not some made up fake thing. They rays still go to those locations, do their thing as normal. They devs are just reducing the number of rays to improve performance.
697 (0.40/day)
France
System Name Home
Processor Ryzen 3600X
Motherboard MSI Tomahawk 450 MAX
Cooling Noctua NH-U14S
Memory 16GB Crucial Ballistix 3600 MHz DDR4 CAS 16
Video Card(s) MSI RX 5700XT EVOKE OC
Storage Samsung 970 PRO 512 GB
Display(s) ASUS VA326HR + MSI Optix G24C4
Case MSI - MAG Forge 100M
Power Supply Aerocool Lux RGB M 650W
Those are no patterns. You are trying to conjure things where there are none.
There's obvious weird banding in those noise patterns, you just seem to like living within the Matrix :) .
I'm confused now, I thought there were no patterns.
2,715 (0.57/day)
System Name MSI GP76
Processor intel i7 11800h
Cooling 2 laptop fans
Memory 32gb of 3000mhz DDR4
Video Card(s) Nvidia 3070
Mouse Logitech m705
Keyboard laptop keyboard
I'm gonna sell my 2080Ti on Ebay and get as much as possible for it.
Definitely going for the 3090, as my PSU can handle it.
Gonna buy it on my card, get the Rewards Flyer points for it and then write the whole thing off as a business expense.
I do the same thing with a new or used laptop almost every year.
8,850 (4.02/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Yeah, those tiles as I called them could easily be pseudorandom repetition from an interpolation algorithm too. I only said tiles because they looked like tiles, but I'm just saying what they look like. There's all sorts of ways that repeating pattern could be generated and PRNG is as good a hypothesis as any, probably better than tiles because that wouldn't require any additional VRAM to store the tile library, it'd be generated rapidly on the fly.
I'm familiar with pure CPU and GPU raytracers from a career perspective. Whilst I don't actively model and render myself, I'm responsible for budgeting and buying hardware farms for the teams that do, and in 20 years of doing this I've never seen repeating patterns like this, so I'm reasonably certain they're not generated by true raycasts. The various videos by devs on how they implemented DXR are all pretty cool, but I suspect the real secret sauce of what generates these patterns is another Nvidia black box that contains proprietary methods that Nvidia don't want to divulge to the competition. Unless someone finds more official detail, we're left to speculate with the evidence we can gather from the end result.
109 (0.06/day)
You are seeing things.
The pictures taken are from Quake II RTX. The interview is about Metro Exodus. Two different games, two different implementations.
So now they are no longer tiles. Hmm. And it only took a few pages of debunking your "facts".
2,592 (0.79/day)
Look at all that innovation:
My old XFX Fury (2015???) had a triple fan cooler with a short PCB like that so the third fan blew upwards, it resulted in lower CPU temperatures under combined load vs just CPU load in some situation.
I suspect a similar approach will be taken on may AIBs, does this mean the 3090 is going with HMB, surely you can't squash 20+ GB of GDDR6 into a short PCB like that?
Got a triple slot cooler on your new top end card? Welcome to 2008, you're going to love it!
Got a vapour chamber on your GPU? Welcome to 2006, you're going to love it.
That's kind of along the lines of why I think a section of the PCB being cutout as a air passage inlet/outlet between the top and bottom of the PCB with a twin blower setup would work well in principle just push pull push and the natural heat rising element will even do some of the work for you at the same time. The way it's been with GPU's for years is all the heat rises and any heat that doesn't get pushed out the rear of the case which even with a blower fan is probably relatively limited gets fairly stuck in place sure can kind of trickle out the sides, but I bet you a lot still remains overly stagnant and adversely impacts the PCB temps a fair bit. Really even if they had some holes like they use to mount M.2 drives like four to eight spaced out on the PCB to let some of heat escape upward it wouldn't hurt at all. They could do that and have two blowers on the top of the card with a heavily perforated hexagonal backplate to let air escape that pulls heat upward and pushes all that heat out the rear of the case perhaps with a pair of top down coolers down bottom. Basically four fans the card won't bend all the heat pretty much gets expelled out the rear of the case efficiently and could be run at low and quiet RPM's trivially they could even dynamically heat cycle between the top two fans and bottom fans.
1,491 (0.20/day)
66 feet from the ground
System Name 2nd AMD puppy
Processor FX-8350 vishera
Motherboard Gigabyte GA-970A-UD3
Cooling Cooler Master Hyper TX2
Memory 16 Gb DDR3:8GB Kingston HyperX Beast + 8Gb G.Skill Sniper(by courtesy of tabascosauz &TPU)
Video Card(s) Sapphire RX 580 Nitro+;1450/2000 Mhz
Storage SSD :840 pro 128 Gb;Iridium pro 240Gb ; HDD 2xWD-1Tb
Display(s) Benq XL2730Z 144 Hz freesync
Case NZXT 820 PHANTOM
Audio Device(s) Audigy SE with Logitech Z-5500
Power Supply Riotoro Enigma G2 850W
Mouse Razer copperhead / Gamdias zeus (by courtesy of sneekypeet & TPU)
Keyboard MS Sidewinder x4
Software win10 64bit ltsc
Benchmark Scores irrelevant for me
Your 2x8-pin cable connects to the PSU with one 8-pin connector, not two.
nope two cables & two connectors one for each in psu...i don't know what psu you have but didn't saw yet the combination you mentioned...
2,135 (0.80/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
@DuxCro
last time i checked, "you" aim for 1st, not second place..
so you want Nv to do less, just so amd can have something close in performance?
what other product on this planet gets artificially castrated, so competition can catch up?
funny how many ppl here "know" with how good one brand will be, and the other will be doing so bad, on cards that havent seen light of day yet,
nor been reviewed.
please make a sign and put it on your fridge:
it could/should/would..
the good thing? it will work for ANY future release of any hw. :D
752 (0.43/day)
System Name Main PC
Processor AMD Ryzen 9 5950X
Motherboard ASUS X570 Crosshair VIII Hero (Wi-Fi)
Cooling EKWB X570 VIII Hero Monoblock, 2x XD5, Heatkiller IV SB block for chipset,Alphacool 3090 Strix block
Memory 4x16GB 3200-14-14-14-34 G.Skill Trident RGB (OC: 3600-14-14-14-28)
Video Card(s) ASUS RTX 3090 Strix OC
Storage 500GB+500GB SSD RAID0, Fusion IoDrive2 1.2TB, Huawei HSSD 2TB, 11TB on server used for steam
Display(s) Dell LG CX48 (custom res: 3840x1620@120Hz) + Acer XB271HU 2560x1440@144Hz
Case Corsair 1000D
Audio Device(s) Sennheiser HD599, Blue Yeti
Power Supply Corsair RM1000i
Keyboard Corsair Strafe RGB MK2
Software Windows 10 Pro 20H2
I've seen both implementations. My prior EVGA PSU had a single 8-pin cable that then split into two 6+2 pins at the end. My current Corsair unit is 1 to 1 where the PSU end is 8pin and the other is 6+2pin. Both have their pros and cons, the pros of having the split is you only need to run one cable to the PSU to power a dual 8pin card, but the con is if you're using only one of them you've got a chonky 8pin dangling off to the side.
1,491 (0.20/day)
this could explain why he insisted on his variant which i never saw but it seems that depend on manufacturer than ; thx for confirming!
235 (0.06/day)
Doubtless a nice piece of design, but necessitated by high power consumption. 8 layer PCB, back drilled VIAs, high compoent density/quality -> high BOM. They're explicit in the video that the way to get higher performance is through higher power use. Will be telling for efficiency.
From page 1. Correction, 12 layer PCB as per design guide. How do you like BOM now?
Dux
511 (0.16/day)
You know what frightens me the most? That those ridiculous prices are the new standard for graphics cards. Won't go down, and can only go up. :(
42 (0.02/day)
A company so rich cannot make a more polished video? This looks so amateurish, with meaningless graphics and horrible photography. There are million home produced channels on YouTube that have higher production values.
697 (0.40/day)
France
System Name Home
Well, if sales are going great (while prices are high), how can prices go down? All computer hardware sales in the last 6 months did awesomely. Prices might come down only when and if people buy less, but unfortunately that doesn't seem to be the trend.
8,850 (4.02/day)
Case Veddha T2
Mouse MX Anywhere 2
if the consoles are priced at $500, the PC gaming market won't be able to maintain the ridiculous increasing Nvidia tax for too much longer. Despite the vocal DIY PC market, your average gamer is just going to be swayed towards one of the new consoles instead. The games are heavily optimised for the console hardware and controllers, they get earlier game releases and addtional exclusives and the online community for consoles is usually larger when it comes to matchmaking purposes and keeping servers alive.
3,481 (0.99/day)
System Name M3401 notebook
Processor 5600H
Motherboard NA
Memory 16GB
Video Card(s) 3050
Storage 500GB SSD
Consoles going from 7850/7870 GPU to 2080/2080s levels, beating 95/98% of the PC market at GPU power and now targeting 4k resolutions will only make it worse for the PC market.
2,358 (0.45/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
So a single 12-pin will pull power from a single 8-pin pci-e cable?
2 x 8-pin, same way when 8-pin connectors were new and weren't on psu's yet, people had to get by with 2 x 6-pin to 8-pin adapters.
