PCI-Express 4.0 Pushes 16 GT/s per Lane, 300W Slot Power
iO
531 (0.12/day)
Germany
Processor R7 5700x
Motherboard MSI B450i Gaming
Cooling Accelero Mono CPU Edition
Memory 16 GB VLP
Video Card(s) RX 7900 GRE Dual
Storage P34A80 512GB
Display(s) LG 27UM67 UHD
Case none
Power Supply Fractal Ion 650 SFX
I really doubt we will see this in consumer boards. It looks more like an optional feature specifically aimed at server applications with new connectors and stuff..
3,992 (0.61/day)
Maryland
System Name HAL
Processor Core i9 14900ks @5.9-6.3
Motherboard Z790 Dark Hero
Cooling Bitspower Summit SE & (2) 360 Corsair XR7 Rads push/pull
Memory 2x 32GB (64GB) Gskill trident 6000 CL30
Video Card(s) RTX 4090 Gigagbyte gaming OC @ +200/1300
Storage (M2's) 2x Samsung 980 pro 2TB, 1xWD Black 2TB, 1x SK Hynix Platinum P41 2TB
Display(s) 65" LG OLED 120HZ
Case Lian Li dyanmic Evo11 with distro plate
Audio Device(s) Klipsh 7.1 through Sony DH790 EARC.
Power Supply Thermaltake 1350
Software Microsoft Windows 11 x64
Not sure if I like this.. Why push all the power through the mobo and add more potential component degradation,
when you can just run it through a plug, that has already accounted for the additional power flow and been tested to handle it for years on end?
Does this at all transfer into better gpu performance?
6,145 (0.84/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
I'm inclined to agree with you there, especially considering the recent pictures of the AMD Zen server board that supposedly has four PCIe 4.0 slots. Perhaps un-coincidentally, that board also has quad PCIe power connectors.
18,145 (2.45/day)
not sure if i worded it badly, i meant new cards incompatible with older boards.
Sorry, my bad, I wasn't reading your post properly... :oops:
4,201 (0.95/day)
System Name Skunkworks 3.0
Processor 5800x3d
Motherboard x570 unify
Cooling Noctua NH-U12A
Memory 32GB 3600 mhz
Display(s) Asus 1440p144 27"
Mouse *squeak*
Software Manjaro
Aye, which makes it kinda moot IMO. The only benefit this has is cable management. And you break back backwards compatibility and looking at how little improvement there is in CPU performance it makes it downright bad.
Unless they make traces that really can do 300W, which is a lot.
OTOH, having the plugs go into the mobo makes cable management much easier for some cases then having the plugs come out of the GPU. Also good for small size builds where the GPU plugs coming out the top of the GPU instead of the back heavily limits your choice of GPU.
550 (0.12/day)
Processor Intel Core 2 QX6850
Motherboard ABIT AB9 Pro
Cooling Zalman CNPS-9900 MAX-R
Memory Patriot PDC24G6400LLK (4x 2 GB)
Video Card(s) Palit GeForce GTX 560 Ti Twin Light Turbo
Storage Not Enough!
Display(s) Samsung T240HD
Case NZXT Zero
Audio Device(s) Creative Labs Sound Blaster X-Fi Elite Pro
Power Supply Thortech Thunderbolt Plus TTBPK00G 1000W
Mouse Elecom M-DUX70BK
Keyboard CM Storm Trigger (Cherry MX Brown)
Software NOT Windows 10
I think we're getting pretty far ahead. Has anything managed to saturate PCI-E 2.0 16x / PCI-E 3.0 8x yet?
140 (0.04/day)
At least manufacturers will have to show something for those absurdly high motherboard prices.
They could set it a little lower, like 200W to encourage better power efficiency.
cdawall
where the hell are my stars
27,683 (4.08/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
Why would it make older card incompatible? The Voltage won't change, so there's nothing here to make older stuff incompatible, it's an increase in Amperage. A card will never draw more power than it was designed for, so this is a non-issue.
Time to learn some basics before making statements like that me thinks...
You read that completely backwards. New cards incompatible with older boards. Read a thing or two before posting.
76 (0.02/day)
Processor AMD R7 3800X EKWB
Motherboard Asus Tuf B450M-Pro µATX +MosfetWB (x2)
Cooling EKWB on CPU + GPU / Heatkiller 60/80 on Mosfets / Black Ice SR-1 240mm
Memory 2x8GB G.Skill DDR4 3200C14 @ ----
Video Card(s) Vega64 EKWB
Storage Samsung 512GB NVMe 3.0 x4 / Crucial P1 1TB NVMe 3.0 x2
Display(s) Asus ProArt 23" 1080p / Acer 27" 144Hz FreeSync IPS
Case Fractal Design Arc Mini R2
Power Supply SeaSonic 850W
Keyboard Ducky One TKL / MX Brown
I think the guy at Tom's has just misunderstood what the guy said.
You will never get 300W through the slot.
I think he was saying that the official power allowed for a single card will go up, from a minumum of 300W.
ie. We will be seeing 300W+ cards, officially, and with PCI-SIG blessings.
They will still have 8-pin or 6-pin connectors though, just more of them.
5,966 (0.94/day)
New York
Processor AMD Ryzen 9 9900x, Ryzen 9 5980HX
Motherboard Gigabyte B850 Gaming X
Cooling Be Quiet Dark Rock Pro 4(With Noctua Fans)
Memory 128GB Crucial Pro 6400
Video Card(s) Gigabyte RTX 3080, Asus 6800M
Storage Adata SX8200 1TB NVME/WD Black 1TB NVME
Display(s) Dell 27 Inch 165Hz
Case Lian Li A3 Mini
Audio Device(s) IFI Zen Dac/JDS Labs Atom+/SMSL Amp+Rivers Audio
Mouse Logitech G502 SE Hero
Keyboard Corsair K70 RGB Mk.2
VR HMD Samsung Odyssey Plus/ Quest 3
Well the key should definitely have changed then like how AGP's did but since they are allowing manufacturers to keep their current additional power connectors thats nice though..
455 (0.12/day)
System Name Marmo / Kanon
Processor Intel Core i7 9700K / AMD Ryzen 7 5800X
Motherboard Gigabyte Z390 Aorus Pro WiFi / X570S Aorus Pro AX
Cooling Noctua NH-U12S x 2
Memory Corsair Vengeance 32GB 2666-C16 / 32GB 3200-C16
Video Card(s) KFA2 RTX3070 Ti / Asus TUF RX 6800XT OC
Storage Samsung 970 EVO+ 1TB, 860 EVO 1TB / Samsung 970 Pro 1TB, 970 EVO+ 1TB
Display(s) Dell AW2521HFA / U2715H
Case Fractal Design Focus G / Pop Air RGB
Audio Device(s) Onboard / Creative SB ZxR
Power Supply SeaSonic Focus GX 650W / PX 750W
Mouse Logitech MX310 / G1
Keyboard Logitech G413 / G513
Software Win 11 Ent
Jeez... 300W from the slot alone?
I bet new motherboards are going to implement at least 8 phases of VRM just for the 1st x16 slot.
5,147 (0.74/day)
AZ
System Name Thought I'd be done with this by now
Processor i7 11700k 8/16
Motherboard MSI Z590 Pro Wifi
Cooling Be Quiet Dark Rock Pro 4, 9x aigo AR12
Memory 32GB GSkill TridentZ Neo DDR4-4000 CL18-22-22-42
Video Card(s) MSI Ventus 2x Geforce RTX 3070
Storage 1TB MX300 M.2 OS + Games, + cloud mostly
Display(s) Samsung 40" 4k (TV)
Case Lian Li PC-011 Dynamic EVO Black
Audio Device(s) onboard HD -> Yamaha 5.1
Power Supply EVGA 850 GQ
Mouse Logitech wireless
Keyboard same
VR HMD nah
Benchmark Scores no one cares anymore lols
because when I was installing my new psu a few weeks back it really felt like I was dealing with ancient tech compared to the server or nuc markets where everything just slots, no additional cabling needed.
The mainboards will handle it just fine 4 socket server boards push much more power than that to all 4 cpu's all 64 memory slots, and all6 pcie slots. There will be no degradation that's just a silly line of thinking. Again servers have been pushing this amount of power for decades and the video cards are already receiving that amount of power, changing the how isn't going to suddenly degrade them faster.
What this will do is bring enthusiasts into the modern era and get away from cable redundancies. They really should have done this 10 years ago.
76 (0.02/day)
Modern sockets have the CPU power right next to the socket.
they don't have it wandering throughout the motherboard.
Any PCie "add-on" connector, is always right next to the slots.
They won't be running 300W to a single x16 slot, or every x16 slot thorugh the motherboard.
5,147 (0.74/day)
AZ
Keyboard same
VR HMD nah
6,889 (1.40/day)
Case NZXT PHANTOM410-BK
Power Supply Corsair 850W
Mouse Logitech Hero G502 SE
Only Dual GPU cards like the latest AMD one...
newtekie1
Semi-Retired Folder
28,473 (4.05/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
I guess they'll need some kind of physical key system to prevent those cards going into older slots.
AGP Style!
Or they can just make the cards to they can detect a PCI-E 4.0 slot and pull all their power from it, or if the card detects a 3.0 or lower slot it requires the 6 or 8-pin external power connector to be installed. So the card has an external power connector, but you don't have to use it if you plug the card into a PCI-E 4.0 slot.
I'm more interested in how they are going to get the small pins in the slot itself to carry that much current.
cdawall
27,683 (4.08/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
5,502 (1.04/day)
For those wondering where would be the space to power the PCI-E slots.
Think about where the so-called chipsets would be in a year to three from now.
huh? got it? yeah.
18,145 (2.45/day)
Hence why I appologised above...
193 (0.05/day)
Denmark
System Name NorthBlackGoldDream
Processor Ryzen 7600X
Motherboard Gigabyte B650M-DS3H
Cooling Arctic Freezer II 240
Memory 16 GB DDR5-5200C40
Video Card(s) GTX 1080 Ti 11 GB
Storage 1 TB NVMe PCIe 3.0
Display(s) 24.5" 240 Hz TN
Case Fractal North Black Mesh
Power Supply 650W
I foresee some pretty beefy PCIe extenders on the rise..
491 (0.13/day)
System Name Diablo | Baal | Mephisto
Processor Ryzen 9800X3D | 2x Xeon E5-2697v4 | i7-13900H
Motherboard ASRockRack B650D4U-2L2T/BCM | Supermicro X10DRH-iT | Lenovo Thinkpad P1 Gen 6
Cooling Custom loop | SC846 Chassis cooled| dual-fanned heatpipes with LM
Memory 64GiB DDR5-5600 ECC | 256GiB DDR4-3200 ECC RDIMM | 64GiB DDR5-5600
Video Card(s) RTX 3090 Ti Founder's Edition | Embedded ASPEED2400 | RTX 5000 Ada Mobile (80W)
Storage many, many SSDs and HDDs....
Display(s) Dell U3014 + Dell U3011 | SMCI IPMI KVMoIP | 3840×2400 Samsung OLED
Case Caselabs TH10A | Supermicro SC846 | Lenovo Thinkpad P1 Gen 6
Audio Device(s) Creative SoundBlaster X4 | None | On-board + Moondriver2 Ti + Bluetooth
Power Supply Corsair AX1600 | 1200W PSU (Delta) | Lenovo 230W or 300W
Mouse Logitech G604
Keyboard 1985 IBM Model F 122-key, Lenovo integrated
VR HMD The wait for 4K per eye is long and winding....
Software FAAAR too much to list
So I'm late to the party.. thus, QUOTE EVERYONE, answer ALL the questions and ramble ALL the opinions!
300W slot power will be interesting, it'll make cards incompatible with old slots - and really heavy power draw from mobos.
AGP Style!
Covered by PCIe link negotiation already (currently all PCIe cards start with a 10W max, then request more). If it can't do PCIe 4.0 with the full supplemental power, the card should just clamp down to 75W or 25W mode.. or stay at minimal init power levels.
300W. The boards should have safety trips beyond that point, because you're delivering that power through traces, and not thick metal plugs. I imagine PCIe 4.0 motherboards with have PCIe power input connectors on the board.
4x the power flowing through the slots, and you will also have 4x the heat produced too :)
So it looks like the mobo makers are really gonna have to step up their game in terms of trace and slot design, to accommodate this change, cause if they dont, there's gonna be hell to pay from mutli-mega billion $$ lawsuits over melted mobos and anything and everything attached to them, not to mention desks and houses burned down etc...........
Ok, if 75W PCIe power delivery is such huge problem where people go batshit insane over RX480 issues, how are they planning to deliver PCB power traces to the PCIe slot without spontaneously combusting the board at 300W? Are they going to run external wires on the back of the boards? You can't make PCB traces that thick (well, you could, but it would be highly impractical), so, how?
Based on the past 10 or so years of server pushing >1000W at 12V in a single edge connector for PSU purposes, and a good many of those servers have lasted the full 10 years of 24/7 use as well, we'll be fine..
These days, we're pushing well over 3000W through smaller surface areas, like the 3000W PSU in a Dell M1000e (60mm fan). (For those wondering, that PSU only carries power over the 4 thick connectors, 2 +12V, 2 GND. 1/10th of that is about the same amount of area that the PCIe power pins have combined)
Another example would be MXM modules, where the big 1080 and it's 180W of power is supplied through less than half the area available in a PCIe slot, or even crazier, the GK110 chips used in the TITAN supercomputer's MXM modules pushing over 200W over the MXM3.0 edge-connector.
In conclusion: the 300W will go over the existing pins, perfectly reliably and safely.. at most they'll replace a few of the currently unused/reserved/ground pins with +12V pins.
ok external PCI-E cables that deliver 300W to an external box, THAT makes sense.
bring on the external GPU's that dont need their own PSU!
External cabling has been around since the Tesla generation of GPUs (GeForce 8800 series), particularly used in external Tesla GPU boxes that you'd attach to beefy 1U dual-CPU boxes or workstations with limited GPU space.
In external situations, you only do I/O to the main box, with the external box providing it's own power for the cards, nice and easy, and a massive compatibility improvement.
The same way some companies have been for years, 12V cables to somewhere close to the connectors on the motherboards. In other words, this won't help with the cable clutter...
Check out an NVLink Pascal server sometime. There's no cables in most of them, just big edge-connectors to carry huge currents over, or really short power cables to jump from the CPU end to the PCIe/NVLink daughterboard.
Tell me about it... Hell, I'm annoyed that all the higher-end cases faff around with 3 billion fans and LEDs everywhere and yet not a single one of them is willing to putout tool-less, hot-swappable drive cages as a standard feature... Even the massive 900D only does it for 3 of it's 9 bays.. fucking WHY?!
Clearly, yes, else NVLink simply wouldn't exist. In HPC land at least. For home use, 3.0 x8 is plenty for now.
Cards are pulling 300W right now, so there's no point in setting it any lower. Unless you want massive backlash from AMD, nVidia and Intel.. owait, all 3 are major members of the PCI-SIG, and essentially the driving force of the high-power end.
Unlikely. There's been a lot of bitching already from the server (and some desktop) people that cabling is a mess for PCIe add-in cards - in 1U form factors, due to the location of the connector and which bit of the chassis fan a passive card gets, that cuts out 1/6-1/3 of the airflow over the card, resulting in a hotter running card needing to be throttled down.
Let's not even get into top-mounted power like most consumer cards.. those instantly drop you from 4 GPU to 3GPU in riser-equipped 1U, and out of 3U and into 4U for vertically mounted, non-riser setups., and that in turns means 25% more cost in terms of CPUs, mobos, chassis, racks, extra power for the extra systems, etc. top-mounted power is shit, and it's a damn shame it's the common setup now.
They already do in 4GPU 1U servers like Dell's C4130 (1200 W goes from the rear PSUs, through the mobo and then out some 8-pin cables at the other end of the mobo into the 4GPUs) or Supermicro's 1028GQ-TRT.
On the big blade systems, they move even more power through the backplanes to the PSU (think in 9000W over 10U range, right next to 100gbit network interfaces)
76 (0.02/day)
From the pics I saw, the 1080 mobile, had a separate connector for extra power.
Server boards, and NVLink are not the things of us mere enthusiast mortals.
They can have stuff that we can't because they will pay through the nose for it.
I still believe that this is a misunderstanding, and its more than 300W per-slot (Card), rather than through-the-slot.
edit : I think they are currently stuffed for dual gpu cards, and would both like to do them, and intel with KNL sucessors (maybe).
At least they would have the option to go mad :)
edit2 : If they really wanted power thru a slot for the card, it would be much easier to go the E-ISA way, and add a connector off the back end of the card for that, leaving the current slot untouched, and fully compliant..
491 (0.13/day)
Mouse Logitech G604
The other half of that argument is the AMD Naples board they showed off. With at least 750W going in, the PCIe slots are pretty much guaranteed to be getting at least 500W all up. If they're "overloading" the connections (at full tilt, each pin in a PCIe, EPS/CPU and ATX power connector is rated up to something like 9A, so a 6-pin PCIe is safe for 200W on it's own, at 8-pin safe for 300W, with current server cards using only a single 8-pin for 300W cards), pulling in the 1500W for 2 150W CPUs and 4 300W cards is entirely within the realm of possibility. It may not be PCIe 4.0 on Zen, but power support may well trickle down into a revision of 3.x.
I'm personally not too worried about the safety of pushing 300W through the PCIe slot: 300W is only 25A at 12V. Compare that to the literal hundreds of amps (150+W at less than 1V) CPUs have to be fed over very similar surface areas
