System Name | Still not a thread ripper but pretty good. |
Processor | Ryzen 9 7950x, Thermal Grizzly AM5 Offset Mounting Kit, Thermal Grizzly Extreme Paste |
Motherboard | ASRock B650 LiveMixer (BIOS/UEFI version P3.08, AGESA 1.2.0.2) |
Cooling | EK-Quantum Velocity, EK-Quantum Reflection PC-O11, D5 PWM, EK-CoolStream PE 360, XSPC TX360 |
Memory | Micron DDR5-5600 ECC Unbuffered Memory (2 sticks, 64GB, MTC20C2085S1EC56BD1) + JONSBO NF-1 |
Video Card(s) | XFX Radeon RX 5700 & EK-Quantum Vector Radeon RX 5700 +XT & Backplate |
Storage | Samsung 4TB 980 PRO, 2 x Optane 905p 1.5TB (striped), AMD Radeon RAMDisk |
Display(s) | 2 x 4K LG 27UL600-W (and HUANUO Dual Monitor Mount) |
Case | Lian Li PC-O11 Dynamic Black (original model) |
Audio Device(s) | Corsair Commander Pro for Fans, RGB, & Temp Sensors (x4) |
Power Supply | Corsair RM750x |
Mouse | Logitech M575 |
Keyboard | Corsair Strafe RGB MK.2 |
Software | Windows 10 Professional (64bit) |
Benchmark Scores | RIP Ryzen 9 5950x, ASRock X570 Taichi (v1.06), 128GB Micron DDR4-3200 ECC UDIMM (18ASF4G72AZ-3G2F1) |
System Name | Best AMD Computer |
Processor | AMD 7900X3D |
Motherboard | Asus X670E E Strix |
Cooling | In Win SR36 |
Memory | GSKILL DDR5 32GB 5200 30 |
Video Card(s) | Sapphire Pulse 7900XT (Watercooled) |
Storage | Corsair MP 700, Seagate 530 2Tb, Adata SX8200 2TBx2, Kingston 2 TBx2, Micron 8 TB, WD AN 1500 |
Display(s) | GIGABYTE FV43U |
Case | Corsair 7000D Airflow |
Audio Device(s) | Corsair Void Pro, Logitch Z523 5.1 |
Power Supply | Deepcool 1000M |
Mouse | Logitech g7 gaming mouse |
Keyboard | Logitech G510 |
Software | Windows 11 Pro 64 Steam. GOG, Uplay, Origin |
Benchmark Scores | Firestrike: 46183 Time Spy: 25121 |
What difference does the MB make? As long as it has a PCIe slot?We probably need to know more about the motherboard. Does the iBuypower have a model number? If you still have the box it should be on there somewhere.
Can you see any brand and model number on the motherboard?
MSI?(b460 pro-vdh wifi) is the mother board
Doesn't hurt to look and make sure there isn't any issues with the layout. Looks like it will support a dual slot card before it blocks a PCIe x1 slot.If you want to stay with Nvidia a 3060 would be a good card for the money. If you want AMD a 6600 or 7600 will be just as fast and cheaper. A 6700XT is about the best price/performance card but that is usually a little more expensive. Your CPU is fine for 1080P Gaming. The 10400F was one of the most popular CPUs in prebuilt PCs around the time you reference.
i belive so i dont see any markings on itMSI?
hold on picture coming in 1 secDoesn't hurt to look and make sure there isn't any issues with the layout. Looks like it will support a dual slot card before it blocks a PCIe x1 slot.
(edit)
err google might have given me the wrong image.
That sounds like an MSI model that went into plenty of OEMs. It should be a Micro Atx boardi belive so i dont see any markings on it
You stole some of my brain waves lol.Looks like there might be two different revisions of this board.
B460M PRO-VDH WIFI
Best Intel Socket 1200 B460 mATX PRO motherboard, two turbo M.2, gigabit LAN, WiFi AC, USB 3.2 Gen 1 and Mystic Light extension, MSI PROwww.msi.com
The only thing to watch out for is GPU length.
What kind of PSU is included? Wattage and how many PCIe power connectors does it provide?so would everything else be able to support a new gpu long as the length is fine?
your asking things above my pay grade lol if you could explain i can tell youWhat kind of PSU is included? Wattage and how many PCIe power connectors does it provide?
Sorry should have been more clear. What brand / model number of the power supply was included for your PC?your asking things above my pay grade lol if you could explain i can tell you
hold on i found on the board its say pcie 3 so if i had to guess 3What kind of PSU is included? Wattage and how many PCIe power connectors does it provide?
It looks like the case is big enough. The board only has a 2nd M2 as a desirable slot below the GPU. You already have a dual slot card so you could get a bigger card if you wanted. Something like As Rock Challenger cards.so would everything else be able to support a new gpu long as the length is fine?
i cant tell as of right now since in on the computer as we speak and i cant see any markingsThe power supply (PSU) is at the other end of this power connector.
The reason for the question is to get some idea of the quality of the PSU and how many PCIe power connectors (and types: 6pin, 8pin etc...) it provides for GPU's. We just want to make sure you won't have a problem with your existing PSU and any GPU recommendation.i cant tell as of right now since in on the computer as we speak and i cant see any markings
thank you imma be honest im ahigh voltage electrician and this shit is a different languageThe reason for the question is to get some idea of the quality of the PSU and how many PCIe power connectors it provides for GPU's. We just want to make sure you won't have a problem with your existing PSU and any GPU recommendation.
If you don't have a spec sheet that came with your iBuyPower you might have to take out the PSU from your case to identify it. If your iBuyPower has a model number there is a chance we might find the specs for it online. Here is a sample picture of a power supply so you know what you are looking for. In this example you can see the vendor Corsair and the Model RM850x.thank you imma be honest im ahigh voltage electrician and this shit is a different language
Looks like problem solved as long as that is an 8 pin power connector. It is the plug inserted into the top of the GPU. It should be a pigtail.View attachment 326438
on pc part picker it show that the motherboard would work with this gpu
