PSA: Don't Just Arm-wrestle with 16-pin 12VHPWR for Cable-Management, It Will Burn Up
2,881 (1.13/day)
Well done Huang, I hope this costs a bomb to reengineer. RDNA 7900XT looking better everyday. I don't reallt care about the numbers, I know it will destroy RDNA2 and Ampere and my 2080 Super and 1080 Ti, so that is all that matters to me. I don't need it to out do the 4090 at all. With RT being improved over 100% and with FSR it'll be fine for anything I can throw at it.
632 (0.17/day)
Processor AMD Ryzen 3800X / AMD 8350
Motherboard ASRock X570 Phantom Gaming X / Gigabyte 990FXA-UD5 Revision 3.0
Cooling Stock / Corsair H100
Memory 32GB / 24GB
Video Card(s) Sapphire RX 6800 / AMD Radeon 290X (Toggling until 6950XT)
Storage C:\ 1TB SSD, D:\ RAID-1 1TB SSD, 2x4TB-RAID-1
Display(s) Samsung U32E850R
Case be quiet! Dark Base Pro 900 Black rev. 2 / Fractal Design
Audio Device(s) Creative Sound Blaster X-Fi
Power Supply EVGA Supernova 1300G2 / EVGA Supernova 850G+
Mouse Logitech M-U0007
Keyboard Logitech G110 / Logitech G110
The comments count is accompanied by a fire emoji, how appropriate.
2,782 (1.27/day)
PNW, USA
System Name Metalia
Processor AMD Ryzen 7 5800X3D
Memory 2x32GB DDR4-3600
Pretty standard advice. But, you wouldn't know that unless you've wrangled a lot of SATA, coaxial, fibre, or other 'bend radius'-sensitive fine pitch cabling.
All the little oversights in moving to this new connector exemplify and confirm my 'feelings' on modern engineering at large. -practical considerations are set well below 'the book'.
Who cares, right? Not like they're liable for damages, that's on the manufacturer and end user...
4,114 (0.62/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
Proper 4090 cable and connectors
3,567 (1.00/day)
System Name M3401 notebook
Processor 5600H
Motherboard NA
Memory 16GB
Video Card(s) 3050
Storage 500GB SSD
1,724 (0.77/day)
Motherboard MSI X670E Carbon
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
Display(s) Samsung G8 OLED
Case Silverstone FT04
I think no one at the AMD side would think this would become a selling point.
299 (0.05/day)
Saigon city
System Name Kurise PC
Processor i7 5820k 4,7ghz / Ryzen 1700x 4ghz / 8700k
Motherboard Asus X99 deluxe / MSI x370 gaming pro carbon / z370i strix
Cooling EK evo, xspc slim 360 rad, D5 pump, dual alpha cool GPU mono block, dual xspc 240 radiator, DDC 18w
Memory Crucial sport white 16gb x 8 128gb 2666mhz/ Crucial sport white 16gb x 4 64gb 2933 / ddr4 chinese 32
Video Card(s) GTX 1080Ti SLI / HP gtx 1080 SLI 1850/1520 / 2080ti ref
Storage Lite on 512GB x 3 / Plextor m2 256gb / samsung 970 evo
Display(s) AOC I2769Vm, AOC U3477PQU, AOC I2769Vm / Koios 40''/ eizo EV2730QFX 1:1
Case Xigmatek Elysium / Corsair 750D / Bitfenix prodigy M
Audio Device(s) creative blaster ZX / Blaster ZXR / Blaster x7 lmt + burson v5i upgraded
Power Supply Be Quiet 1200 / Thermaltake toughpower 1200w / chinese 750w sfx PSU
Mouse Asus Echelon/ steelseries black ops II/ james donkey
Keyboard Cm storm quickfire pro / Fire rose steampunk kb/ corsair k70
I would like a 3 8 pin or 4 8 pin rather than the shitty nvidia 12 pin connektor
Deleted member 177333
Terrible design. Put out a card that is so huge that it will literally have issues fitting into a number of cases, and then design a power cable for it that is so unreliable it actually has a connect / disconnect limit, and furthermore is a fire hazard.
As some others said, great opportunity for AMD to potentially capitalize on.
438 (0.21/day)
System Name Cyberdyne Systems Core
Processor AMD Sceptre 9 3950x Quantum neural processor (384 nodes)
Motherboard Cyberdyne X1470
Memory 128TB QRAM
Video Card(s) CDS Render Accelerator 4TB
Storage SK 16EB NVMe PCI-E 9.0 x8
Display(s) LG C19 3D Environment Projection System
Power Supply Compact Fusion Cell
Software Skysoft Skynet
In the various batteries and EV rides I've built I use 5.5mm bullet plugs, they can handle pretty high currents. They should have done something like an XT120 connector with a sense pin as an optional extra for high powered PSUs and cards. Given the pins in these things are still pretty weak and not rated that high, there were bound to be issues on cards that can pull so much power. The connector should never have been rated for anything more than 450w constant.
I recall someone pointing out that the pins are rated for about 8 amps each or something similar, and at 600w would be more than that. So right off the bat having cards that can pull more than the connectors are rated for is just bad. They probably thought it would just be for spikes and for the rest of the time the card would be pulling no where near its limit, forgetting people playing with unlocked framerates, people rendering stuff for hours on end.
It's not Nvidia's connector, as has been pointed out many times.
So, it's NV f-up, top to bottom.
Intel doesn't deserve even part of the blame:
PCI SIG analysis (prior to meltdowns)
It's the same connector minus the sense pins, instead NV put a sense chip in the wire to tell the GPU how many cables are connected.
The connector was always gonna be fine for lower powered stuff, had no issues on my 3080FE roaring away for hours on end.
Yes it is NVs fault though, they're running too many amps through these pins so as the picture shows without a solid connection will fry. even with a solid connection they're going higher than the pins are rated for at full 600w. They're basically dupont connectors in the wire end of the port, and have never been rated that high compared to loads of different types of connectors. But they are cheap as chips compared to anything slightly more solid. 4080 should have no issues with it, it's the 4090s peak power draw that's the main issue and really NV should have had that card alone use a 16pin connector instead to spread the load more. Or 2 12 pins to ensure no issues. 600W is just beyond what's safe for those tiny pins to handle. That's 50 amps spread across those teeny tiny things.
1,577 (0.62/day)
A lot of prople place the blame solely on end user. Even though Ada cards are uncommonly wide, and most PC cases weren't made with consideration for them - and the new adapter cable even increases the problem by having a long stiff "strain relief".
2,349 (0.34/day)
Toronto, Ontario
System Name The Expanse
Processor AMD Ryzen 7 9800X3D
Motherboard Asus Prime X670E-Pro Wifi BIOS 3222 AGESA PI 1.2.0.3a
Cooling Corsair H150i Elite LCD XT
Memory 64GB G.SKILL Trident Z5 Neo RGB DDR5 6000 CL 30-40-40-96 1T
Benchmark Scores https://valid.x86.fr/0412jp https://browser.geekbench.com/v6/cpu/11073923
Yeah but you have to laugh at someone buying a 1600.us+ gpu and trying to put it in a midtower :laugh:
That would easily fit in my mid tower :)
306 (0.05/day)
Bay Area, CA
This is not NV idea, it`s a new general standard.
4*8pin is not better, I think it`s even worse.
Using the 12VHPWR to 4*8pin adapter makes life harder.
AMD need to also adopt the 12VHPWR but to better position it on the GPU.
Because when you need 2*12VHPWR to feed next gen GPU`s that's 4*whatever you suggested.
The heat is not the problem here, the bending force on the connector is.
Wasn't this a collaborative effort between Intel and PCI-SIG?
This wasn't an Intel idea. This was an Nvidia idea that was passed through the PCI-SIG consortium and got approval. Intel only added it to the ATX spec AFTER it was passed through PCI-SIG.
The connector works fine in most cases. But there are caveats (don't bend before 30mm, etc.).
Remember, this is the same connector as the 30 series FE. That was only 450W.
I think the problems started coming up when Nvidia said "hey look.. if you use a 600W cable you can clock the 4090 card higher", which is why I went on the profanity laden rant that got me exiled from GamersNexus (because he chose to quote me out of context instead of addressing the actual issues because he had Nvidia in house at the time).
I have personally used this connector upwards of 55A at 50°C. But you CAN NOT put a bend on the cable less than 30mm or higher than 50°C. This is shown in the PCI-SIG report that was leaked, but this only talked about the connector on the PSU side (which is why Corsair ATX 3.0 PSUs don't have the 12VHPWR connector on the PSU) and never talked about on the GPU side.
OneMoar
There is Always Moar
8,832 (1.61/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
if your connector has restrictions on how you plug in a connector then the connector is bad
example there is no possible way I could use a 12VHPWR connector in my case there isn't room there is barely room for the two 8 pin on my 3070ti and those make a hard bend to clear the side panel
to get a safe bend keeping the last 1.2Inchs strait the cable needs to make a massive ARC nobody wants that
nvidia needs to revise this connector asap maby use a longer pin or a different shaped pin T or + shaped
for right now right angle adapters seem to be the solution hopefully more psu vendors will make 90/L shaped adapters
edit:reddit has once again done nvidias job for them fixed
we can closed this thread now
684 (0.41/day)
Greece
System Name Office / HP Prodesk 490 G3 MT (ex-office)
Processor Intel 13700 (90° limit) / Intel i7-6700
Motherboard Asus TUF Gaming H770 Pro / HP 805F H170
Cooling Noctua NH-U14S / Stock
Memory G. Skill Trident XMP 2x16gb DDR5 6400MHz cl32 / Samsung 2x8gb 2133MHz DDR4
Video Card(s) Asus RTX 3060 Ti Dual OC GDDR6X / Zotac GTX 1650 GDDR6 OC
Storage Samsung 2tb 980 PRO MZ / Samsung SSD 1TB 860 EVO + WD blue HDD 1TB (WD10EZEX)
Display(s) Eizo FlexScan EV2455 - 1920x1200 / Panasonic TX-32LS490E 32'' LED 1920x1080
Case Nanoxia Deep Silence 8 Pro / HP microtower
Audio Device(s) On board
Power Supply Seasonic Prime PX750 / OEM 300W bronze
Mouse MS cheap wired / Logitech cheap wired m90
Keyboard MS cheap wired / HP cheap wired
Software W11 / W7 Pro ->10 Pro
Maybe it was designed in collaboration with NZXT:D...
Jock aside both sides are to blame. The user of the top GPU (at least for the moment) should avoid stressing a 600w cable or connector. On the other hand Nvidia knows that this huuuge card will be difficult to fit in many cases and must put the needed clearance as a red flag in the specs. It's another 20% added height on a 4 slot GPU, higher than most tower coolers...
95 (0.02/day)
Processor Ryzen 7 5800x3D
Motherboard Asus X570 ROG Crosshair VIII Dark Hero
Cooling Noctua NH-D15 LTT Edition
Memory 2 x 16 GB G.Skill Trident Z 3600MHz CL16-19-19-39
Video Card(s) Sapphire RX580 Nitro+
Storage 970Evo Plus 1TB + 850 EVO 500GB + WD Red 3TB + HGST 4TB + Seagate 6TB + 2x Seagate IronWolf Pro 20TB
Display(s) 2x Asus MG279Q
Case Cooler Master Haf 912 Plus
Power Supply Super Flower Leadex Gold SF-650F14MG
Mouse Logitech G703
Keyboard Razer Ornata Chroma
Why is the power connector on top of the card with these cards that are extremely tall? Putting the connector on the back at least would remove the need of a sharp bend. And I would like that even for cards with multiple 8 pins connectors.
41 (0.01/day)
System Name Raistlin
Processor Ryzen 5 5600X
Motherboard MSI X470 Gaming Pro
Cooling Noctua NH-D15S with dual fans
Memory 32GB G.Skill 3600MHz DDR4 CL16 (F4-3600C16-16GTZNC)
Video Card(s) Nvidia RTX 3090 (MSI Suprim X)
Storage 1 x 960GB SX8200, 1 x 1TB SX8200, 1 x 2TB Seagate HDD
Display(s) LG 34GP950G, 2x DELL S2721D, LG 48" C2 OLED (OLED48C2PUA), HiSense 75U78KM (75" Mini-LED 4K TV)
Case Thermaltake Core X9
Audio Device(s) Topping E30 + Drop O2 Amplifer + Sennheiser HD 600 / HIFIMAN HE4XX / Sound BlasterX Katana
Power Supply EVGA SuperNova 1300 G2
Mouse Razer Naga Pro wireless
Keyboard Ducky One 2 full size
VR HMD HP Reverb G2
Software Windows 10 Professional
Damn... polarized AC outlets are gonna screw up your worldview. What a stupid thing to say.
1,577 (0.62/day)
RTX 4090 cards are also extremely long, so having a connector with long stiff stress relief and cables that you shouldn'd bend too tightly on top of that also excludes a lot of cases.
I think all this mess wouldn't happen if they made the adapter with 90 degrees bend. I know it's not practical for those who mount their cards veryically - but they are a minority, and they already have to buy a riser cable - so they can invest on another unnecessary nice cable.
3,567 (1.00/day)
Processor 5600H
Motherboard NA
Memory 16GB
Video Card(s) 3050
Storage 500GB SSD
They:
1) Designed that shit (Intel designed the sensing pins only)
2) They have tested it and figured it is HIGHLY PROBLEMATIC (see PCI SIG report in my previous post)
3) They STILL found it OK to push it out to the market
Except it doesn't even per docs submitted to PCI SIG by NV itself.
1,050 (0.60/day)
System Name Dirt Sheep | Silent Sheep
Processor i5-2400 | 13900K (-0.02mV offset)
Motherboard Asus P8H67-M LE | Gigabyte AERO Z690-G, bios F29e Intel baseline
Cooling Scythe Katana Type 1 | Noctua NH-U12A chromax.black
Memory G-skill 2*8GB DDR3 | Corsair Vengeance 4*32GB DDR5 5200Mhz C40 @4000MHz
Video Card(s) Gigabyte 970GTX Mini | NV 1080TI FE (cap at 50%, 800mV)
Storage 2*SN850 1TB, 230S 4TB, 840EVO 128GB, WD green 2TB HDD, IronWolf 6TB, 2*HC550 18TB in RAID1
Display(s) LG 21` FHD W2261VP | Lenovo 27` 4K Qreator 27
Case Thermaltake V3 Black|Define 7 Solid, stock 3*14 fans+ 2*12 front&buttom+ out 1*8 (on expansion slot)
Audio Device(s) Beyerdynamic DT 990 (or the screen speakers when I'm too lazy)
Power Supply Enermax Pro82+ 525W | Corsair RM650x (2021)
Mouse Logitech Master 3
Keyboard Roccat Isku FX
VR HMD Nop.
Software WIN 10 | WIN 11
Benchmark Scores CB23 SC: i5-2400=641 | i9-13900k=2325-2281 MC: i5-2400=i9 13900k SC | i9-13900k=37240-35500
There is no "general standard" of "ship home made adapter that cannot fit properly in 93% of f the cases.
This issue is absolutely NV's creation and doesn't have anything to do with 12 pin socket.
IF NV was too greedy for a proper 90 degree angle adapter, it could have located the socket differently.
I mostly agree, nv implement the new power standard and the position plus adapter make it very space constraint.
But NV didn't invented anything, they just adopted it.
Not in the slightest.
Maybe not this gen but it's the way going forward for high end high wattage GPU at least. I just hope they will learn from NV (not so good) way of implamenting new this standard.
3,567 (1.00/day)
Processor 5600H
Motherboard NA
Memory 16GB
Video Card(s) 3050
Storage 500GB SSD
No. Per their own words (links have been shared several times) it was SPECIFICALLY NVIDIA that designed power delivery aspect of that socket. Intel only did sensing part.
1,116 (0.32/day)
Latvija
Motherboard Asus
Memory 4GB Samsung
Video Card(s) rx 460 4gb
Storage 750 Evo 250 +2tb
Audio Device(s) Pioneer
Power Supply 430W
Mouse Acme
Keyboard Trust
Looks like my home input power line connection.
438 (0.21/day)
Memory 128TB QRAM
They:
It's still perfectly fine for lower current cards. Again it's been in use for 2 years already. 3080, 3090, 3090Ti have had no problems with it. It's only now with the 4090 that it's an issue. If you look at PCI-SIGs test showing the failure that's when drawing 55A constant. That's 660W for it to fail in their test. And Nvidia may claim they made it, but it's just a Molex MicroFit 3.0 BMI Dual Row header.
3,567 (1.00/day)
Processor 5600H
Motherboard NA
Memory 16GB
Video Card(s) 3050
Storage 500GB SSD
Which need it as much as birds need pig tails
Yeah. Why do you think that could be:
let alone the size...
to bash Nvidia as though it's their fault.
How is "it" not NV's fault???
Who designed that thing? NV (no, not Intel, Intel designed only sensing pins)
Who KNEW from testing it was terrible? NV (yes, they've even submitted it to PCI-SIG)
Who cheaped out on 90 degree connectors for a GPU that cots 2000+ Euro and does not fit into 93% of cases?
I'm pretty sure it wasn't my grandma, nor was it Intel or AMD.
the54thvoid
Super Intoxicated Moderator
13,566 (2.42/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
Reading comprehension failure. Go and reread exactly what I posted about mating cycles (not being an Nvidia thing). Then read the part about shitty bending angles where I say it is a problem.
Then post in context.
