System Name | AM5 |
Processor | AMD Ryzen R9 7950X |
Motherboard | Asrock X670E Taichi |
Cooling | EK AIO Basic 360 |
Memory | Corsair Vengeance DDR5 5600 64 Gb - XMP1 Profile |
Video Card(s) | AMD Reference 7900 XTX 24 Gb |
Storage | Crucial Gen 5 1 TB, Samsung Gen 4 980 1 TB / Samsung 8TB SSD |
Display(s) | Samsung 34" 240hz 4K |
Case | Fractal Define R7 |
Power Supply | Seasonic PRIME PX-1300, 1300W 80+ Platinum, Full Modular |
System Name | Fractal |
Processor | Intel Core i5 13600K |
Motherboard | Asus ProArt Z790 Creator WiFi |
Cooling | Arctic Cooling Liquid Freezer II 360 |
Memory | 16GBx2 G.SKILL Ripjaws S5 DDR5 6000 CL30-40-40-96 (F5-6000J3040F16GX2-RS5K) |
Video Card(s) | PNY RTX A2000 6GB |
Storage | SK Hynix Platinum P41 2TB |
Display(s) | LG 34GK950F-B (34"/IPS/1440p/21:9/144Hz/FreeSync) |
Case | Fractal Design R6 Gunmetal Blackout w/ USB-C |
Audio Device(s) | Steelseries Arctis 7 Wireless/Klipsch Pro-Media 2.1BT |
Power Supply | Seasonic Prime 850w 80+ Titanium |
Mouse | Logitech G700S |
Keyboard | Corsair K68 |
Software | Windows 11 Pro |
but I'm no electrical engineer
System Name | Incomplete thing 1.0 |
Processor | Ryzen 2600 |
Motherboard | B450 Aorus Elite |
Cooling | Gelid Phantom Black |
Memory | HyperX Fury RGB 3200 CL16 16GB |
Video Card(s) | Gigabyte 2060 Gaming OC PRO |
Storage | Dual 1TB 970evo |
Display(s) | AOC G2U 1440p 144hz, HP e232 |
Case | CM mb511 RGB |
Audio Device(s) | Reloop ADM-4 |
Power Supply | Sharkoon WPM-600 |
Mouse | G502 Hero |
Keyboard | Sharkoon SGK3 Blue |
Software | W10 Pro |
Benchmark Scores | 2-5% over stock scores |
All depends on the extensions used, most cheap ones totally aren't good enough for any load, even under the official 150W. My extensions on my 250W GPU from CM (also 2x 8pin) has had zero problems with melting or heat at all.This all greatly reminds me of why i tell everyone not to use any adaptors or extensions on modern GPUs
These melted on an undervolted 3090, locked to under 250W
Native direct cables or risk a fire. Nvidia was dumb to force this new connector so early, they just didnt want the stigma of 4x 8 pin connectors on these GPUs
lol AMD should do marketing on top of the problem, "Unfortunately, our GPUs still don't have the flamethrower / self-destruct function, guys"
System Name | HTC's System |
Processor | Ryzen 5 5800X3D |
Motherboard | Asrock Taichi X370 |
Cooling | NH-C14, with the AM4 mounting kit |
Memory | G.Skill Kit 16GB DDR4 F4 - 3200 C16D - 16 GTZB |
Video Card(s) | Sapphire Pulse 6600 8 GB |
Storage | 1 Samsung NVMe 960 EVO 250 GB + 1 3.5" Seagate IronWolf Pro 6TB 7200RPM 256MB SATA III |
Display(s) | LG 27UD58 |
Case | Fractal Design Define R6 USB-C |
Audio Device(s) | Onboard |
Power Supply | Corsair TX 850M 80+ Gold |
Mouse | Razer Deathadder Elite |
Software | Ubuntu 20.04.6 LTS |
System Name | Starlifter :: Dragonfly |
Processor | i7 2600k 4.4GHz :: i5 10400 |
Motherboard | ASUS P8P67 Pro :: ASUS Prime H570-Plus |
Cooling | Cryorig M9 :: Stock |
Memory | 4x4GB DDR3 2133 :: 2x8GB DDR4 2400 |
Video Card(s) | PNY GTX1070 :: Integrated UHD 630 |
Storage | Crucial MX500 1TB, 2x1TB Seagate RAID 0 :: Mushkin Enhanced 60GB SSD, 3x4TB Seagate HDD RAID5 |
Display(s) | Onn 165hz 1080p :: Acer 1080p |
Case | Antec SOHO 1030B :: Old White Full Tower |
Audio Device(s) | Creative X-Fi Titanium Fatal1ty Pro - Bose Companion 2 Series III :: None |
Power Supply | FSP Hydro GE 550w :: EVGA Supernova 550 |
Software | Windows 10 Pro - Plex Server on Dragonfly |
Benchmark Scores | >9000 |
I can see a number of problems with this. First, you are correct that it would make the design more expensive. There may also be some challenges stacking multiple PCI-E ports to a single card, even if they're only there for power. That would make the card a fair bit more prone to breaking somewhere along all those PCI-E pins, and getting power to the main PCB would be a challenge in itself. Beyond that, you would need to ensure that your motherboard actually has 4 PCI-E slots all lined up in a row to fit such a card. And then you run into the problem of supplying up to 300w of power from the slots alone, something that burned up 24-pin ATX connectors in the past. We've had a few mentions of exactly that happening here on these forums when people were jamming many cards into a single machine for Foldind@Home. You would need motherboards to be specifically designed for this. Take a look at the cryptocurrency mining motherboards that had asstons of PCI-E slots for jamming as many cards in a single machine as possible... they all had tons of extra power connectors to feed the slots.Now I'm a Design Engineer, CAD Tech, Machinist, CAM Programmer, etc etc...but I'm no electrical engineer, yet I see a simple SIMPLE solution staring them right in the face.
Update the PCIe slots and mainboard layouts. Quit trying to fit the large square peg in the small round hole. The card is already taking up 4 PCIe slots in most designs, so have it pop into 4 rigid PCIe slots and get yourself 4x 75w of power right off the top without changing much of anything.
And I know some of you will reply "but that will make it too expensive!"
System Name | Apollo |
Processor | Intel Core i9 9880H |
Motherboard | Some proprietary Apple thing. |
Memory | 64GB DDR4-2667 |
Video Card(s) | AMD Radeon Pro 5600M, 8GB HBM2 |
Storage | 1TB Apple NVMe, 4TB External |
Display(s) | Laptop @ 3072x1920 + 2x LG 5k Ultrafine TB3 displays |
Case | MacBook Pro (16", 2019) |
Audio Device(s) | AirPods Pro, Sennheiser HD 380s w/ FIIO Alpen 2, or Logitech 2.1 Speakers |
Power Supply | 96w Power Adapter |
Mouse | Logitech MX Master 3 |
Keyboard | Logitech G915, GL Clicky |
Software | MacOS 12.1 |
Now they have the stigma of melting power connectors instead. Well played, nVidia.they just didnt want the stigma of 4x 8 pin connectors on these GPUs
The horror has a face - NVIDIA’s hot 12VHPWR adapter for the GeForce RTX 4090 with a built-in breaking point | igor´sLAB
Those who are now beating up on the new 12VHPWR (although I don’t really like the part either) may generate nice traffic with it, but they simply haven’t recognized the actual problem with the…www.igorslab.de
Igor just confirmed the Built by Nvidia adaptor has such a high quality, that the wires are held (only) by soldering onto a very very thin piece of metal , and can be broken with very little force.
The card doesn't even know one of the soldering is broken, cause all the pins are joint inside the adaptor so the pin didn't "disconnected" , the load just spread to other wires and pump up the Amps (and wire temps) , it just keeps going until it melts.
What a wonderful design !
All companies have the "stigma" of some disappointed users.Now they have the stigma of melting power connectors instead. Well played, nVidia.
Yes, 4090 is constantly sold out.Nvidia high quality overengineering!!
System Name | CyberMania |
Processor | AMD RYZEN 7 5800X |
Motherboard | GB AORUS PRO AC B550 |
Cooling | CM HYPER212 TURBO ARGB |
Memory | XPG D50 DDR4-3600 16X 2 |
Video Card(s) | SAPPHIRE AMD RX580 |
Storage | XPG M.2 NVME SPECTRIX D40 512GB 2TB |
Display(s) | SAMSUNG 32" T55 Curved Monitor |
Case | CM ELITE 430 |
Audio Device(s) | REALTEK HD |
Power Supply | CM WME GOLD 650WATT |
Software | Windows 10 21H2 LTSC 2021 |
Who buys a 4090 should invest 200-400$ more for a new power supply with proper cables/plugs and a midi/big tower with enough space, no adapters. Simple as that.I think the main problem here is the card, Yes its fast, but horrible design, its the size of a xbox and draws way to much power which causes other problems like heat, and now failed power connector. As an electrician, you can do the math, and this card will pull 60 amps, normally for this type of connection we use #6 copper and lugs to connect. I would be surprised that this power connection meets UL safety standards.
Update Oct 30th: Jon Gerow, aka Jonny Guru, has posted a write-up about the 12VHPWR connector on his website. It's an interesting read with great technical info.
Processor | i5-6600K |
Motherboard | Asus Z170A |
Cooling | some cheap Cooler Master Hyper 103 or similar |
Memory | 16GB DDR4-2400 |
Video Card(s) | IGP |
Storage | Samsung 850 EVO 250GB |
Display(s) | 2x Oldell 24" 1920x1200 |
Case | Bitfenix Nova white windowless non-mesh |
Audio Device(s) | E-mu 1212m PCI |
Power Supply | Seasonic G-360 |
Mouse | Logitech Marble trackball, never had a mouse |
Keyboard | Key Tronic KT2000, no Win key because 1994 |
Software | Oldwin |
That's how we've always been taught. May I suggest a better version, more clear to noobs and more adequate to professionals: [all] the paths of least resistance.which increases resistance on that terminal forcing the current to take the path of least resistance instead
Looking a bit farther into the future: It's the technical transition to 24 or 48 volts, which seems inevitable in the longer term. 12VHPWR is already obsolete. 12VO for motherboards can carry 288 W and so it is equally obsolete. But the transition hasn't been done yet, and hasn't even started yet, because it would break compatibility with any existing PSUs.Technical transition problem. Power consumption has reached the limit of existing connection structure.
System Name | Planet Espresso |
Processor | 13700KF @ 5.4GHZ UV - 220W cap |
Motherboard | MSI 690-I PRO |
Cooling | Thermalright Phantom Spirit EVO |
Memory | 48 GB DDR5 7600 MHZ CL36 |
Video Card(s) | RTX 4090 FE |
Storage | 2TB WD SN850, 4TB WD SN850X |
Display(s) | Alienware 32" 4k 240hz OLED |
Case | Jonsbo Z20 |
Audio Device(s) | Yes |
Power Supply | Corsair SF750 |
Mouse | Xlite V2 |
Keyboard | 65% HE Keyboard |
Software | Windows 11 |
Benchmark Scores | They're pretty good, nothing crazy. |
Higher voltage or thicker cables/plugs. I am fine with both. 2-3 8 pin plugs will soon be gone for high-end GPUs. Even MB and case design will change, if 3-4 pci-slot GPUs become normal. But don't overdo it either, the problem only affects consumers who think they need a high-end GPU, that's at best 1-2% of all PCs. It is therefore quite possible that an isolated solution will be developed here.[...]
Without the statistical data, complete error analysis, such conclusions are not possible. Always these dramatizations. Apart from that: Thanks to all early adopters.This is just a complete garbage card design. Card is unnecessarily bulky; the absolutely unnecessary dongle connector is unnecessarily intrusive and protruding at 90 degrees. And now it's lighting on fire if you bend the cable incorrectly. What a waste of a phenomenal GPU.
