PSA: Don't Just Arm-wrestle with 16-pin 12VHPWR for Cable-Management, It Will Burn Up
2,096 (0.46/day)
Netherlands
System Name TheDeeGee's PC
Processor Intel Core i7-11700
Cooling Noctua NH-D15S
Display(s) EIZO CX240
Mouse Logitech G500S
Keyboard Keychron Q6
Seems there are 3 different adapters in the wild now.
- 300V with 4 solder joints (Nvidia reddit user)
- 150V with 4 solder joints (IgorsLab)
- 300V with 2 solder joints (GamersNexus)
10,989 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 1:1 CL30-36-36-96 FCLK 2000
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply RIP Corsair SF750... Waiting for SF1000
Keyboard 65% HE Keyboard
Without the statistical data, complete error analysis, such conclusions are not possible. Always these dramatizations. Apart from that: Thanks to all early adopters.
How much statistical analysis do you need to look at that design and realize it’s bad? Always these apologists trying to defend obviously bad ideas by downplaying.
arsh666
3 (0.00/day)
Do you own a RTX 4090? Doesn't sound like it. Because if you did, you would know that the RTX 4090 is a very cool running card. With some exceptions (ASUS ROG STRIX OC) it is also not *that* huge. I own the MSI Suprim X and it's a big card, alright, but by far not as crazy as the stupid clickbait YouTubers would like people to believe. It easily fit in my beQuiet DarkBase 900 (non-Pro) and there was also zero issue putting the side panel back on. I never had to bend the adapter or anything.
The card is a powerhouse but it remains cool exactly *because* of its sizable cooling solution. That is not the issue at all. We will have to wait and see what the official investigations by nVidia, the AIC partners and the maker of the adapter(s) turn up. The YouTubers are poking around in the dark for the clicks. They can not be taken serious. Let's wait and see for the results of the official investigation...
Well I don't own one but I did own a 3dfx voodoo 5500, and I remember how that all turned out. I would also like to see Nvidia do it own investigation into it. I'm sure they will be blaming everyone but them self. They will come up with a solution, and it will probably be like a water cooler that will spray water on the power connector one it detects fire.
571 (0.12/day)
Processor i5 4670K - @ 4.8GHZ core
Motherboard MSI Z87 G43
Cooling Thermalright Ultra-120 *(Modded to fit on this motherboard)
Memory 16GB 2400MHZ
Video Card(s) HD7970 GHZ edition Sapphire
Storage Samsung 120GB 850 EVO & 4X 2TB HDD (Seagate)
Display(s) 42" Panasonice LED TV @120Hz
Case Corsair 200R
Audio Device(s) Xfi Xtreme Music with Hyper X Core
Power Supply Cooler Master 700 Watts
That's alright, if they burn up their card, they're rich, they can just buy another...
This is such a wrong notion, not everyone is rich who purchases RTX 4090, some people literally use their savings to buy high end products once in a decade and losing a product like this due to bad design is sad.
Never encourage bad engineering, its outright sad.
Mussels
Freshwater Moderator
58,413 (7.86/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Now I'm a Design Engineer, CAD Tech, Machinist, CAM Programmer, etc etc...but I'm no electrical engineer, yet I see a simple SIMPLE solution staring them right in the face.
Update the PCIe slots and mainboard layouts. Quit trying to fit the large square peg in the small round hole. The card is already taking up 4 PCIe slots in most designs, so have it pop into 4 rigid PCIe slots and get yourself 4x 75w of power right off the top without changing much of anything.
And I know some of you will reply "but that will make it too expensive!"
:wtf:
That'd be useless?
It'd need entirely new motherboards, CPU's and PCI-E standards
The slots are 75W, so even making it physically use two slots you're still far short of the 500W these cards can use
100 (0.07/day)
Processor Ryzen 7950X3D
Motherboard Asus ROG Crosshair X670E Hero
Cooling Corsair iCUE H150i ELITE LCD
Memory 64GB (2X 32GB) Corsair Dominator Platinum RGB DDR4 60000Mhz CL30
Video Card(s) Zotac GeForce RTX 4090 AMP Extreme AIRO 24GB
Storage WD SN850X 4TB NVMe / Samsung 870 QVO 8TB
Display(s) Asus PG43UQ / Samsung 32" UJ590
Case Phanteks Evolv X
Power Supply Corsair AX1600i
Mouse Logitech MX Master 3
Keyboard Corsair K95 RGB Platinum
Software Windows 11 Pro 24H2
For the 600 Watt adapter it's the difference between pulling 300 Watt through a cable if daisy chained, or 150 with 4.
Sure PCI-E 8-Pin is rated for little over 300 Watt, but would you be comfortable with that?
But i guess some people like to live on the edge.
Corsair and Seasonic are certainly fine with it as their official 600w 12VHPWR adapters uses just two connectors from the PSU so 300w per cable. While 150w maybe the official limit the connector is just overbuilt if your using a PSU from a good company.
86 (0.07/day)
Statistical data are reasonable. "apologists trying to defend obviously bad ideas by downplaying" is emotional and personal. That says more about you than about the product.
10,989 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
Why is it emotional -- it's a fact, and don't take it personally, it's not against you, I'm sure you're a fine person I don't know nor do I have anything against you. I do have an issue with the idea that we need mountains of data to identify a mistake -- we really don't.
Sometimes --a badly designed product is obvious, especially when it immediately introduces a failure mode that wasn't an issue in virtually the same design from last generation. It's not personal or emotional -- it's just a regression. The fact that you're obtusely needing more "statistical data (because it's reasonable, and not emotional)" on a clearly failing mechanical design is grossly disingenuous. How many need to light on fire before we reach your failure threshold? 1? 5? 5,000? 50,000? all of them? When is a clear design failure clear enough in the historical data?
I'm a data scientist and process engineer by trade. And I love the scientific process as much as the next guy, but if you know anything about industrial design and process engineering, that when you see any process or product that can fail catastrophically in the regular course of it's usage - that is a 100% fail guarantee -- that's something you fix right away. It's not a matter of if, it's just a matter of when. In this case, like when you see a dongle that the wires can only be bent a certain way or solder points can break and cause it to melt - Nvidia is reacting quickly to this because their guys know this, and they know a lawsuit is coming.
2,265 (1.23/day)
System Name GrandadsBadAss
Display(s) Acer XG270HU
Keyboard Roccat Vulcan Aimo
Software Win 10/11pro
The real question at this point is how are they going to respond?
They're taking their sweetass time imo.
My take on the latest internal memo at Ngreedia. :D
"We really did engineer a great product...honest! Our design just wasn't followed to our specifications due to a slight oversight. The manufacturing facility is in China but our QC staff is in Taiwan."
"So what your saying is, communication wires got crossed and things went a bit haywire?"
:p
OneMoar
There is Always Moar
8,803 (1.62/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
if you are going to use the word ngreedia please don't post at all you are just thread crapping (and it makes you sound like 15)
which is my job and you may not have it
86 (0.07/day)
[/QUOTE]
[...]I do have an issue with the idea that we need mountains of data to identify a mistake -- we really don't.
1) A few tech blogs are talking about a technical defect. In order to record how serious this is, the RMA caused is required as a minimum. If it is above average, measures are taken to reduce the failure rate. If not, no further measures are necessary. The test field/repair/guarantee is there for that with its precalculated costs. Failure rates of zero are impossible.
2) Technical products must meet technical specifications. Whether these are met or not is the only objective assessment.
3) Economic criteria such as profit margin.
What caused the error? There are dozens of possibilities. An incorrectly produced batch from a subcontractor that was overlooked during the incoming goods inspection is the most common reason for errors in the mass production of complex goods. Bad plug design could be, but is unlikely, as the plugs have to fulfill the technical specifications. It is not possible to make a qualified judgment before doing some research here and without facts/data.
10,989 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
This is true for regular modes of failure - i.e. power delivery causing card to crash. IMO melting is in a 'catastrophic' category since it presents a fire hazard and poses a danger to the user. As far as rates go, typical failure rates of cables are generally in the 'several per million' ratio, especially if they are burn in tested at the mfg plant, there are far less than a million cards and already 5 reports of cables and ports melting 3 weeks from launch -- as such it's very likely far beyond the typical rate of cable failure.
Correct but the technical specification of a power delivery cable to not melt when used in it's intended system is always present. The point of these cables is to deliver power without melting or lighting on fire.
This is a catastrophic failure which with it carries risk of lawsuit, damages far beyond the costs of recalling the products, and risk of regulatory intervention. If this was a card crashing or card malfunctioning and requiring an RMA then yes an economic analysis can be made. If however, there is any risk of physical danger to the end user (such as things lighting on fire which should not be on fire) then the economic criteria and profit margins are generally secondary concerns.
2,674 (0.48/day)
System Name Old Gateway
Processor i5 4440 3.1ghz
Motherboard Gateway
Cooling Eh it doesn't thermal throttle
Memory 2x 8GB JEDEC 1600mhz DDR3
Video Card(s) RX 560D 4GB
Storage 240gb 2.5 SSD 3TB 7.2k Seagate
Display(s) Dell @ 1280*1024 75hz
Case Gateway
Audio Device(s) Gateway Diamond Audio EMC2.0-USB 5375U ($15 a long ass time ago)
Power Supply 380w oem
Mouse Purple Walmart special, 1600dpi. Black desk mat
Keyboard SteelSeries Apex 100
VR HMD Lmao
Benchmark Scores It can run Crysis (Original), Doom 2016, and Halo MCC
Is it too early to call this Bend Gate 2.0?
86 (0.07/day)
We don't know the reason of the failure, we can only speculate. From my point of view, the connection is subjected to mechanical stress, due to short power supply cables or narrow pc cases. A sentence should be found in every installation manual: The plug connections must be installed in such a way that they are not exposed to mechanical stress. But I might be wrong, as the law is different from nation to nation. In a modular system environment with components from many independent companies, connected by ordinary consumers, it's not that clear, who is responsible. The plugs/cables may simply not be connected as intended. In the article, nVidia asked the board partners, to send the damaged cards in for further analysis. The issue will be solved, once the analysis is done. It could range from a charge of badly manufactured plugs, who are to be replaced, over more detailed manuals, with clear specifications about case dimensions/a list of certified power supplies for the rtx 4090, to a a complete overhaul of some PC standards or even new singular solutions, who are used in hpc/workstations with higher power demands.
You call this “bad design”, I call this early adopter problems. Who don't like to troubleshoot, should wait 4-6 month before purchasing the newest pc hardware components.
I have a technical education, but if I invest >1000 $ for new hardware, I prefer to have the PC built by a specialist retailer. It's much more convenient to just take the smoking PC back to where it was built.
153 (0.03/day)
Puerto Rico
RTX 4090 Woes Get Worse: Native 16-pin reportedly Melts as well ...
" By now, you may have read many horror stories about Nvidia's 16-pin power adapter melting on the GeForce RTX 4090. However, the terror doesn't stop there. A GeForce RTX 4090 owner has reported the first alleged case of a 12VHPWR power connector meltdown from a native ATX 3.0 power supply. " ...
Complete Story and Source - https://www.tomshardware.com/news/rtx-4090-native-16-pin-melting
3,951 (0.60/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
Bend radius is a thing when it comes to cables..............basically any and all cables..............
2,096 (0.46/day)
Netherlands
This video explains it all.
1,036 (0.62/day)
System Name Dirt Sheep | Silent Sheep
Processor i5-2400 | 13900K (-0.02mV offset)
Motherboard Asus P8H67-M LE | Gigabyte AERO Z690-G, bios F29e Intel baseline
Cooling Scythe Katana Type 1 | Noctua NH-U12A chromax.black
Memory G-skill 2*8GB DDR3 | Corsair Vengeance 4*32GB DDR5 5200Mhz C40 @4000MHz
Video Card(s) Gigabyte 970GTX Mini | NV 1080TI FE (cap at 50%, 800mV)
Storage 2*SN850 1TB, 230S 4TB, 840EVO 128GB, WD green 2TB HDD, IronWolf 6TB, 2*HC550 18TB in RAID1
Display(s) LG 21` FHD W2261VP | Lenovo 27` 4K Qreator 27
Case Thermaltake V3 Black|Define 7 Solid, stock 3*14 fans+ 2*12 front&buttom+ out 1*8 (on expansion slot)
Audio Device(s) Beyerdynamic DT 990 (or the screen speakers when I'm too lazy)
Power Supply Enermax Pro82+ 525W | Corsair RM650x (2021)
Mouse Logitech Master 3
Keyboard Roccat Isku FX
VR HMD Nop.
Software WIN 10 | WIN 11
Benchmark Scores CB23 SC: i5-2400=641 | i9-13900k=2325-2281 MC: i5-2400=i9 13900k SC | i9-13900k=37240-35500
Some new info (as of 3/11/22) by JhonnyGuru: It seems mostly a human error by not connecting the cable all the way in.
The design (problem) of the connector make it easy to think you pluged it right but with banding to the sides that happened more with the adaptor, but not only by it, you can have bad pin contact (mostly on the outermost pins).
To be continued...
169 (0.08/day)
This is the same industry-standard cycle as for many molex connectors. i.e., not an issue for the normal end-user.
Scare-mongering (or lack of due-diligence) isn't helpful when trying to remain a reliable tech site.
Molex was a total shitshow, i'm glad they are thing of the past. If you wanted to make a point, it's extremely bad point.
3,443 (2.52/day)
Processor Ryzen 5 5700x
Motherboard B550 Elite
Power Supply MSI 750w
Mouse G502
Not 8pins, that i can guarantee you
1,036 (0.62/day)
VR HMD Nop.
3,443 (2.52/day)
Mouse G502
TL;DW: Human error by not connecting it all the way in.
that's still bad design, people have been connecting pc power cables for decades without problems, it isn't human error if the design makes so many people do it wrong.
If that theory is even the right one, i've seen reddit posts and people clearly had it connected all the way
1,036 (0.62/day)
VR HMD Nop.
How many is "so many" in % of total users with this cable?
3,443 (2.52/day)
Mouse G502
There's people building pc's, newcomers and old timers, every day. The old 8 pin has none of this issues, and there should be millions of them in use at any time.
Versus a new product, with relatively few adopters (a drop of water in the ocean of 8 pin's) and with so many cases in so little time.
And i don't know what the total users mean, i see a lot of people that disconnected the cards, that bought 3rd party cables, others can be melted and they don't even know it... yet, we only know about the ones that post on the internet, not the ones that don't.
Clearly a design flaw it it's as the video say, not human error. You should not design things that so many can't even plug it in properly. Worst when not plug it in properly makes the product self destroy
