PSU power cables.....
4,849 (1.49/day)
Processor Core i7-13700
Cooling Cooler Master RGB Tower cooler
Memory Crucial Pro 5600 32GB kit OCed to 6600
Storage 970 EVO NVMe M.2 500GB,,WD850N 2TB
Case Phantek Eclipse P400S
Audio Device(s) EVGA NU Audio, Edifier Bookshelf Speakers R1280
Power Supply EVGA 850 BQ
Software Windows 11 Professional v24H2
The more important point if not wanting to do length math is the amperage andor wattage, usually found on the end. Here is my 13Amp that came with my EVGA T2 850W, can't really see it but you get the idea:
Some put it on the other end.
Because of your post I was curious so I checked on it.
13A 125V 1025W
622 (0.09/day)
Oak Ridge, TN
System Name BorgX79
Processor i7-3930k 6/12cores@4.4GHz
Motherboard Sabertoothx79
Cooling Capitan 360
Memory Muhskin DDR3-1866
Video Card(s) Sapphire R480 8GB
Storage Chronos SSD
Display(s) 3x VW266H
Case Ching Mien 600
Audio Device(s) Realtek
Power Supply Cooler Master 1000W Silent Pro
Mouse Logitech G900
Keyboard Rosewill RK-1000
Software Win7x64
Guys, if you're ever wondering about amp capacity for a AC wire, check the local building codes.
Our cabling is flexible, as a feature, which adds a few amps to the ratings.
This is for copper, aluminum has a different set of problems.
BTW, over 15A IEC plugs have a different configuration, that won't plug into the standard ones.
Our common plugs are 13A rated (C13), as per the 13A rating on the cord shown.
Sorry to post the silver cord, but there are some people here who believe in silver speaker wire; who am I to judge?
phill
17,160 (3.43/day)
Somerset, UK
Power Supply EVGA 1600W T2
Mouse Corsair thingy
VR HMD No headset yet
13A 125V 1025W
Thanks for the pic, I was just curious if anyone else bothered looking, it seems curiosity got the better of some of you in the end :) :D
And if you look on the cable itself, you'll see a temperature rating, along with cable thickness and all sorts :) I'll try and find a cable that I use tonight when I'm home from work :)
Thanks for the post :)
From some of the cables I've got, there are also different rated fuses in the plugs, some I've seen as low as 3 amps, but then some plugs use a 13 amp fuse as well. I think the majority of fuses I've seen are 5 amps.. :)
4,849 (1.49/day)
It's in a earlier post: 16AWGX3C, and rated for 105°C
21,731 (3.40/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 64GB (2x 32GB) G.Skill Flare X5 @ DDR5-6200 CL30
Case Thermaltake Core X31
6,400 (1.55/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
Go away silverman. Platinum is where it's at! You can tell by the pricing!
Nope, gold-pressed latinum studded with dilithium crystals is da bomb here, hehehe :peace:
And fyi, it only cost 1 arm, both legs, a kidney & your dog's left testicle.. per mm !
phill
17,160 (3.43/day)
Somerset, UK
I was just blind and looked right past it!! :(
Well if all else fails, at least we'll be able to boil some water for a cuppa if the cable gets warm enough :D
Ruru
S.T.A.R.S.
13,323 (3.00/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
Never actually thought about it, just used the same cable since the dinosaurs were around. :D
I guess it wouldn't hurt to use the cable bundled with my PSU.
1,212 (0.62/day)
Canada
System Name New compy
Processor AMD Ryzen 5800x3D
Case Thermaltake Core v71
Was curious so I checked my psu 3ft cable and only data is printed on the cable itself. Also my surge protector has these specs - Electrical Rating: 15A, 120 VAC, 60Hz, 1800 Watts, ups just list NEMA 5-15P which is 15amp 125v, ups has a slightly thinner cable than the others so I'm guessing it's 18gauge.
phill
17,160 (3.43/day)
Somerset, UK
Interesting size of cable, 1.3mm2.... Must be something to do wit the 125v instead of the 240v we run in the UK I guess??
773 (0.32/day)
Germany
System Name FATTYDOVE-R-SPEC
Processor Intel i9 10980XE
Motherboard EVGA X299 Dark
Cooling Water (1x 240mm, 1x 280mm, 1x 420mm + 2x Mo-Ra 360 external radiator)
Memory 64GB DDR4
Video Card(s) RTX 2080 Super / RTX 3090
Storage Crucial MX500
Display(s) 24", 1440p, freesync, 144hz
Case Open Benchtable (OBT)
Audio Device(s) beyerdynamic MMX 300
Power Supply EVGA Supernova T2 1600W
Mouse OG steelseries Sensei
Keyboard steelseries 6Gv2
I never really thought about this topic, as cables are all rated rather high here on the 230V outlets. My monitor-cable has 10A / 250V = 2500W rating. On the PSU side and all the extension cables and power-strips are rated to the point of the circuit breaker tripping before anything can happen. It is usually 16A / 230V = 3680W.
As for the internal wires from PSU to components I leave it to reviews telling me a PSU is good or not.
AsRock
TPU addict
19,173 (2.98/day)
UK\USA
Cooling D15
If it it'sa trusted brand it be a none issue, how ever you do decide to get a better one check the pins 1st as there is a lot of Chinese crap going around switching the Neutral and earth.
622 (0.09/day)
Oak Ridge, TN
System Name BorgX79
Cooling Capitan 360
Storage Chronos SSD
Case Ching Mien 600
Mouse Logitech G900
Software Win7x64
For electrical stuff, any cable exposed to the user/planet is going to be 18AWG minimum.
That's why I posted the table I did above, it set 18 awg as a minimum.
mm2, awg, sq mils; all of these are in use.
250mcm (million circular mills) is standard in the "wires run to your house" sizes. :)
(A mil is a thousandth of an inch)
I have some nice 350mcm shielded cables I saved from the dumpster I'm going to use for a car stereo project, just 'cause.
That's a 50 cent piece.
phill
17,160 (3.43/day)
Somerset, UK
Now I need some of that for my SR-2!! :D :D @Dinnercore , with your power draw, that might be enough to calm the beast wouldn't it?? :D :D ;) ;)
622 (0.09/day)
Oak Ridge, TN
System Name BorgX79
Cooling Capitan 360
Storage Chronos SSD
Case Ching Mien 600
Mouse Logitech G900
Software Win7x64
That cable ran a 3.3V 120A power supply 30 feet, with less than .1V drop. :)
Crazy shit I've had to do... :D
