Radeon R9 and Radeon R7 Graphics Cards Pictured Some More
1,682 (0.32/day)
State College, PA, US
System Name My Surround PC
Processor AMD Ryzen 9 7950X3D
Motherboard ASUS STRIX X670E-F
Cooling Swiftech MCP35X / EK Quantum CPU / Alphacool GPU / XSPC 480mm w/ Corsair Fans
Memory 96GB (2 x 48 GB) G.Skill DDR5-6000 CL30
Video Card(s) MSI NVIDIA GeForce RTX 4090 Suprim X 24GB
Storage WD SN850 2TB, Samsung PM981a 1TB, 4 x 4TB + 1 x 10TB HGST NAS HDD for Windows Storage Spaces
Display(s) 2 x Viotek GFI27QXA 27" 4K 120Hz + LG UH850 4K 60Hz + HMD
Case NZXT Source 530
Audio Device(s) Sony MDR-7506 / Logitech Z-5500 5.1
Power Supply Corsair RM1000x 1 kW
Mouse Patriot Viper V560
VR HMD HP Reverb G2
Software Windows 11 Pro x64
Benchmark Scores Mellanox ConnectX-3 10 Gb/s Fiber Network Card
From what AMD told us, the two feature 4 GB of memory, over 5,000 TFLOP/s compute power, and over 300 GB/s memory bandwidth.
With these specs you need only 6 of these cards to beat the Titan supercomputer.
2,198 (0.43/day)
So. Cal.
This seems to make no business sense since any chips with defects can't be sold.
There's nothing positive these are the only models they intend to release or just a sprinkling of some spots. That said it pretty hard to fill in when they have such tight price steps... Idk. Just saying these might not be the only one to release, or as Nvidia did you hold back binned part and release them 6 month from now as R8's? Nvidia has shown the two derivative models per wafer is no longer and that they can to appropriated to completely different segments. Not says it a bad thing, but that the common way of looking at this may well be no more.
Either the charts AMD posted are correct- in which case information can be extrapolated from them OR they are incorrect.
Or AMD just maded that R9 290X bar to fade out... After you used that chart to arrive at the 17-18% above comment, I noticed that the others all seem to end, while that one fades... IMO. It perhaps could be AMD trickery, that slide is not a clear measurement of data indicating performance. If it was AMD would have to stipulate the system spec’s and other parameters to make relevant engineering data... It's a P-R slide, as such not something we should deem as gospel.
1,682 (0.32/day)
VR HMD HP Reverb G2
Nvidia makes a mind-boggling number of OEM card variations to efficiently allocate defective chips. Only the best chips get used for retail cards. This results in a lot of complaints from enthusiasts because an Nvidia OEM card with the same model number as a retail card might have a completely different core, clock speeds, and memory configuration from the retail card with the only similarity between the two being an approximate performance. Maybe AMD is going this same route with its defective chips?
11,880 (2.17/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Wow. That was a chore to read. Ever heard of punctuation and grammar, or English your second language?
Please let me simplify:
Either the charts AMD posted are correct- in which case information can be extrapolated from them OR they are incorrect and AMD is either lying or has some serious QC and/or internal communications problems.
It is either one or the other.
For someone who isn't "assed if the card blows a fart" you seem to be posting an awful lot. Personally I am interested in the new releases, both from an enthusiast standpoint, and as someone who advises and builds systems for others. If you don't like what is said please use, by all means use the ignore function in your CP.
YW
The reason i reply is because you post soooo much drivel.......:shadedshu
you are misguiding others with your myopic view of the world based on what most agree is a scant pr slide meant to churn the rumour mill.
but with you its allway's essentially,,
amd are lieing shit nobs ,OR they Are lieing shit nobs(cross out one or two from each side though each post) ,,, yeah your english makes it sound like more than that,, but it is'nt
1,029 (0.22/day)
New Jersey, USA
System Name Current Rig
Processor AMD 7800X3D
Motherboard MSI x670e Tomahawk wifi
Cooling Artic Freezer II 360
Memory G.Skill 32gb ddr5 6000mhz
Video Card(s) AMD 7900XTX 24 GB
Storage Samsung SSD 980 PRO 2TB
Display(s) Alienware AW3420DW 120 Freesync
Case LianLi Lancool III white non-rgb
Audio Device(s) Onboard ALC
Power Supply Corsair Shift 1000W
Mouse G502 Hero
Keyboard Ducky Shine 5
Software Win 11 64bit
Benchmark Scores The second best!
Thanks Hilux SSRG, you pulled a fanboy.
Not a fanboy comment. Just stating that both camps have put out rehashes and not new chips for the low to mid range for the last two generations. It's a shame really that both companies are unfortunately keeping prices artificially high on old product. And I bet Nvidia will pull a gtx 800 series rehash of the 600 series no doubt, for the low to mid range.
1,682 (0.32/day)
VR HMD HP Reverb G2
It all comes down to TSMC. They killed half-node processes and now are taking longer than 2 years for the full-node processes as well. Nvidia and AMD can only do so much without a process advancement. Without a process advancement, they can't increase performance without increasing die size and manufacturing cost; hence, no more performance in cards at the same price point.
Edit: this simplifies things a bit because they could reduce margins or design a new chip, but reducing margins would bring them back to the HD4000/GTX200 series price wars which are undesirable for them, and a redesigned low end chip would only be viable for a short time before 20nm came in and made it obsolete - they never would recoup their investment.
3,881 (0.83/day)
Holy ****
Someone with a brain. :respect:
3,881 (0.83/day)
Good point and might well be a reason for the model matrix, let it rain confusion.
More confusion...
If you go back and look at the presentation Raja when hes talking about "Over 5 TFLOPS Compute"
Hes talking about the series R9 290. Not specific to R9 290X.
GK110 - 780 to Titan there is a 517 differance
Tahiti - 7950 to 7970 GHZ there is a 1229 difference
Add that to the speculation...
1,029 (0.22/day)
New Jersey, USA
Mouse G502 Hero
True, but I got to wonder if in the process of designing chips both AMD and Nvidia have reduced performance in order to include low power. I do not know enough about die shrinks but anyone can see Intel has quit on performance and only seeks low power for their CPUs. I wonder if GPUs are/have gone that direction as well.
1,682 (0.32/day)
VR HMD HP Reverb G2
I'm not sure that low power is AMD and NVidia's primary concern, particularly in the present. Mainstream laptops have already gotten rid of the discrete GPU, and the remaining mobile GPUs aren't particularly optimized for low power consumption. Both manufacturers have realized that they can't beat integrated graphics power consumption no matter how well they design a GPU. The low-power consumption graphics segment is now solely filled by integrated graphics. Think of NVidia's Optimus - they've essentially admitted that it's simply not possible to beat the power consumption of integrated graphics even by downclocking or shutting off most of the shaders of a discrete GPU. The discrete GPU has been relegated to situations where performance is more of a concern than power consumption. I don't see that relationship between discrete and integrated graphics changing anytime soon.
3,881 (0.83/day)
Unless AMD's PowerPoint skills suck, R9 290X Firestrike is under 8000.
Notice the top block (which ends at 8000) is fading at the top. GTX TITAN's Firestrike score is ranging between 8,200 and 8,700.
They still suck at it because the R9 280X doesn't match up to the 7970 GHZ.
7970 @ Stock (925/1375)
Fire Strike
Score:6622
Graphic Score:7402
7970 @ 7970 GHZ/Boost (1050/1500)
Fire Strike
Score:7210
Graphic Score:8235
2,785 (0.56/day)
New Zealand
System Name MoneySink
Processor 2600K @ 4.8
Motherboard P8Z77-V
Case NZXT Switch 810
Power Supply Seasonic X-1050
Software Win8.1 Pro
Yes, quite possible. Maybe the 18% is invalid....so the only other metric AMD released was the "over 5TFlop" FP32 figure. Presumably if the number was closer to 6 then that is what they would have used, no? Assuming a 5.1-5.5 range conveniently gives you an 18.6% increase over Tahiti's 4.313 TF number up to a maximum of ~27%
Again, quite possible. It's not as though AMD hasn't got a prior record in this regard. BUT in the absence of any other data what would YOU suggest be used as a comparison and speculation point? (This is not a rhetorical question)
Or is it verboten to speculate ? I seem to recall that many people here have speculated and hypothesised on much less information than that. Allow me to refresh your memory on your speculation for what is now called the 290X:
We're not going to see anything like 39% in just a re-spin on 28Nm. I figure 25% in hardware, what they find in new release driver who knows. If they gave us 7990 performance which is 22% more than a Titan @2650x, while holding to the alleged 250W... in a $550 card.
As far as performance I speculated upon, I worked on the given information and came up with ~18% over the HD 7970GE based on the Firestrike slide with preliminary driver support, and and the FP32 numbers.The fact that the GTX 780 scores around the same:
Led me to conclude that the cards were likely evenly matched....as other sources have intimated:
The other speculation I indulged in was price, and the GPU under the various cards skirts.
None of the speculation has been shown inordinately out of the likely expected parameters so far.
1,682 (0.32/day)
VR HMD HP Reverb G2
I want to make sure that everyone knows that Firestrike is both a GPU and CPU benchmark. You can sway the scores by +/-1000 with the same GPU just by changing the CPU. These AMD scores are worthless for comparing to competing cards unless they were both run on the same platform. But since AMD won't divulge this information, then we just have to accept that any graphics card card scoring within about 20% could be equal in performance to AMD's new graphics cards. It could swing either way.
97 (0.02/day)
Processor Intel i7 4960x Ivy-Bridge E @ 4.6 Ghz @ 1.42V
Motherboard x79 AsRock Extreme 11.0
Cooling EK Supremacy Copper Waterblock
Memory 65.5 GBs Corsair Platinum Kit @ 666.7Mhz
Video Card(s) PCIe 3.0 x16 -- Asus GTX Titan Maxwell
Storage Samsung 840 500GBs + OCZ Vertex 4 500GBs 2x 1TB Samsung 850
Audio Device(s) Soundblaster ZXR
Power Supply Corsair 1000W
Mouse Razer Naga
Keyboard Corsair K95
Software Zbrush, 3Dmax, Maya, Softimage, Vue, Sony Vegas Pro, Acid, Soundforge, Adobe Aftereffects, Photoshop
From 6990 to 7990, and including the 7970, they all average around a 25% to 35% increase in core frequency when they are overclocked. Let's assume this is true.
2816 Streaming Processors (2) (1000 MHz boost) = 5.632 GFLOPs.
If you consider the OC potential of the previous generations. The average is at around 30%,
Single 6990 base clock is 830 Mhz. It's max OC is roughly around 1060 to 1120 Mhz. 27.71%
Single 7970 base clock is 900 Mhz. 1050 Mhz boost. It's max OC is roughly 1321 Mhz w/ LN2. 46.78%
Single 7990 base clock is 950 Mhz. 1000 Mhz boost. It's max OC is roughly 1100 Mhz. 10.00%; this may actually be higher...
Average all together from up above = 28.16%...
What's my point.
10% OC headroom: 1.1 x 5.632 GFLOPs = 6.19852 GFLOPs.
20% OC headroom: 1.2 x 5.632 GFLOPs = 6.7584 GFLOPs.
28.16% OC Headroom: 1.2816 x 5.632 GFLOPs = 7.21813 GFLOPs.
30.00% OC Headroom: 1.3 x 5.632 GFLOPs = 7.3216 GFLOPs.
So, if plausible, it may not be that difficult or impossible to surpass the 5.0 to 6.0 GFLOPs boundaries with the up coming R9-990... Sadly, only time will tell...
2,750 (0.44/day)
Minnesota
Anyone else notice the DVI ports on the R9 280X, 290, and 290X are DVI-D instead of DVI-I?
2,198 (0.43/day)
So. Cal.
Oh no, speculation is all we have, either in late July as in my words or as of you working from a new slide. Just don't get all "all-uppie" when someone points out an alternate estimation. I just said it fades...
As to what you bolded in my words you need to revival the context of the question:
I would love to see the 9970 having the same performance level as two 7970 cards.
We're not going to see anything like 39% in just a re-spin on 28Nm. I figure 25% in hardware, what they find in new release driver who knows. If they gave us 7990 performance which is 22% more than a Titan @2650x, while holding to the alleged 250W... in a $550 card. Then where's that leave Volcanic Island 4-5 months ?
I believe I used W1zzard reference GTX780 review and that could've skewed the percentages a little.
http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_780/26.html
All I was saying if they could deliver such performance (of a 7990), it would be much more than I could envision... I didn't say I was expecting. While I wrote Volcanic... meant what does that means for 20Nm process in a couple of month most still though Q1 '14, even in July it was thought Volcanic Island was 20Nm.
I exhaled a while back... take a breath and wait for the 15th. ;)
19,378 (3.49/day)
And...that means it can't output to VGA. It's just an interesting fact.
Who the hell is buying a $400+ card to run on a monitor with only VGA inputs? If you can afford such a card, you better have a monitor with DVI on it, LOL!
1,682 (0.32/day)
VR HMD HP Reverb G2
I can see two (small) groups of people having problems with this:
1) The few die-hards still using 1600/1920x1200 CRTs
2) Reviewers who test monitors for latency by comparing an LCD with a CRT.
1,682 (0.32/day)
VR HMD HP Reverb G2
Forget the voiceless minority. :p
I like compatibility but if there is no longer a large enough userbase to justify the legacy features then by all means remove them and use the savings toward features that more people will use. Right now DVI-D to VGA converters cost around $200 but if you want to mix legacy hardware with new hardware then you need to be willing to pay for adapters.
3,688 (0.58/day)
Ohio
System Name Felix777
Processor Core i5-3570k@stock
Motherboard Biostar H61
Memory 8gb
Video Card(s) XFX RX 470
Storage WD 500GB BLK
Display(s) Acer p236h bd
Case Haf 912
Power Supply Rosewill CAPSTONE 450watt
Software Win 10 x64
Where did you get they cost $200? i simple adapter would work wouldn't it? those are only $5-15. and converter boxes are $45-90. all this with a simple google search.
Also i use a VGA monitor with my GTX 560 because of budget i couldn't get a new monitor. Just because people can get great hardware to go in the case doesn't mean they aren't stretching their limit. Hell i don't plan to replace my current monitor until it breaks so i may be part of that voiceless userbase ;) lol
