Radeon R9 and Radeon R7 Graphics Cards Pictured Some More
1,682 (0.32/day)
State College, PA, US
System Name My Surround PC
Processor AMD Ryzen 9 7950X3D
Motherboard ASUS STRIX X670E-F
Cooling Swiftech MCP35X / EK Quantum CPU / Alphacool GPU / XSPC 480mm w/ Corsair Fans
Memory 96GB (2 x 48 GB) G.Skill DDR5-6000 CL30
Video Card(s) MSI NVIDIA GeForce RTX 4090 Suprim X 24GB
Storage WD SN850 2TB, Samsung PM981a 1TB, 4 x 4TB + 1 x 10TB HGST NAS HDD for Windows Storage Spaces
Display(s) 2 x Viotek GFI27QXA 27" 4K 120Hz + LG UH850 4K 60Hz + HMD
Case NZXT Source 530
Audio Device(s) Sony MDR-7506 / Logitech Z-5500 5.1
Power Supply Corsair RM1000x 1 kW
Mouse Patriot Viper V560
VR HMD HP Reverb G2
Software Windows 11 Pro x64
Benchmark Scores Mellanox ConnectX-3 10 Gb/s Fiber Network Card
Where did you get they cost $200? i simple adapter would work wouldn't it? those are only $5-15. and converter boxes are $45-90. all this with a simple google search.
Also i use a VGA monitor with my GTX 560 because of budget i couldn't get a new monitor. Just because people can get great hardware to go in the case doesn't mean they aren't stretching their limit. Hell i don't plan to replace my current monitor until it breaks so i may be part of that voiceless userbase ;) lol
The simple adapters only work for DVI-I/DVI-A ports (which means they already have native analog output; the adapter just rearranges the pins); these cards have only DVI-D ports which means no native analog output. You are right; I overestimated the active adapters' cost; I did find a Startech adapter for $45.99.
VGA has a resolution limitation of about 3MP (QXGA 2048x1536) @60Hz; if you are using a VGA monitor, you can't have a resolution above that, but even those types of monitors are rare. These high end cards are overkill for a single 2MP or 3MP 60Hz monitor. Rest assured, the mid range and lower end cards have DVI-I ports so that you can still use cheap VGA adapters, and they are a much better performance match for the VGA resolutions.
EDIT: Interestingly enough, DisplayPort to VGA adapters are much cheaper than DVI-D to VGA adapters. You can get a DisplayPort to VGA adapter for $24.71, although it is limited to 1920x1200 @60Hz (not QXGA 2048x1536 @60Hz).
11,880 (2.17/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Who the hell is buying a $400+ card to run on a monitor with only VGA inputs? If you can afford such a card, you better have a monitor with DVI on it, LOL!
dunno i just realised my new card has no hdmi.. dohhh I got a 7970 as they are tooo cheap damn it:eek:,, R9 will be out in 3 mins to smash my new card in :laugh::roll::cry:
yes fine ive a dvi monitor but i didnt wanna watch the footy on that:shadedshu
in short choice is goood
154 (0.04/day)
System Name Trixeon
Processor Xeon E3-1230-V2
Motherboard Asrock Z77 Extreme 3
Cooling Coolmaster EVO
Memory Gskill 2133 8GB
Video Card(s) Sapphire R9-290 Tri-x o/c bios 1000/6000MHz
Storage 128GB SSD, 256GB SSD, 3TB HDD, 1TB HDD
Display(s) 3x 22" 1050 monitors 16:10
Case Xigmatec
Power Supply Xigmatec 800W centurio
Software Win7 64bit
Unless AMD's PowerPoint skills suck, R9 290X Firestrike is under 8000.
http://www.techpowerup.com/img/13-09-26/264a.jpg
Notice the top block (which ends at 8000) is fading at the top. GTX TITAN's Firestrike score is ranging between 8,200 and 8,700.
It's got me completely stumped too, but no-one else has even questioned it.
I can't understand it, how is a Firestrike score of 8000 good? My $200 7950 gets a graphics score of over 8000!!
http://www.3dmark.com/3dm/1299529
