Recommended "Clean" W11 reinstall method? (Trying to fix Latency)
145 (0.29/day)
Motherboard Asus Strix B550-A
Cooling Be Quiet! Dark Rock 4
Memory Gskill Trident Z DDR4-3200 (16GB x 2)
Video Card(s) Sapphire Pulse RX 7900 XT 20GB
Storage Samsung 970 Evo Plus NVME 1TB (Boot), Samsung 970 Evo Plus NVME 2TB, Samsung QVO Sata 2Tb
Display(s) Aoc 31.5" 1440p 75hz; Asus 24" 1080p 75hz (secondary)
Case Be Quiet! Silent Base 802 White
Power Supply Corsair RM750X 2021 w/ Corsair Type 4 Sleeved Red Cables
At this point I'm at my wit's end trying to fix the fact that LatencyMon constantly flags problems as soon as I run any games.
The games themselves work totally fine and perform great, although RDR2 has the odd pop in some of the audio sound effects, but to be honest I'm starting to hear that the game is known for that issue with a lot of people so IDK if that has anything to do with it.
I have seen it suggested on another forum that part of my problem might be the fact that back in 2020 I bought a microsoft store version of Windows 10 Home, and last year accepted the upgrade to Windows 11. A few weeks ago I ran the in-built factory reset function including wiping all my files, but this was done internally, without an external flash drive for the boot media. It's been suggested that me doing the reinstall this way may have allowed any corruption from the upgrade process to persist into my new OS install.
What I was recommended to do was reinstall W11 from external USB boot media (which I'm more than capable of doing), but to do it strictly in offline mode, and to download "all drivers relevant to my system" prior, installing them via admin command prompt before even connecting to the internet and letting Windows do the rest.
This isn't something I've ever done, nor do I know how to do it.
For instance:
1. I don't know how to even do the installation offline, because I'm going to be asked for my MS login anyway
2. Having the "relevant drivers" installed prior means I'm going to have to grab another USB drive separate to the one I use for the boot media, which brings me to my third point:
3. I don't know what "all relevant drivers to my system" actually encompasses. Obviously I'm going to want to have GPU drivers ready, and maybe chipset driver package from AMD as well, but I don't know which other drivers are relevant and need installing prior to connecting to the internet.
The way I always did things (except for most recently) was installing windows from a boot media, in Online mode, and simply installing GPU and chipset drivers manually from AMD's installers found on their website once the OS itself had got up and running.
For reference, this is my latest LatencyMon result after running RDR2 for about 5 minutes. Everyone else seems to have it much, much lower once they fix everything up. And this is with most of the fixes I've seen listed on forums etc. (disabling core parking, disabling fTPM, unlocking the extra power management options and setting everything to 100%, turning off XPM / DOCP, those kind of things. If it's on a "reduce system latency" list, there's a good chance I've already tried it).
Or, should I just find some way to downgrade back to Windows 10?
2,350 (6.40/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
Download a clean iso. Configure via Rufus for offline install. Install. You’re done. There isn’t much in it. No, drivers aren’t an issue, the offline install is recommended to skip MS shenanigans. You can just install them when OS is up. Alternatively, after installation you can configure your Group Policies to prevent Windows Update from retrieving drivers before going online with that PC.
Oh, and I wouldn’t really chase after lowering LatMon numbers. They are mostly meaningless in practice unless you are actually experiencing issues.
145 (0.29/day)
Gotcha.
I might hold off on the whole process for now unless I encounter actual issues. RDR2's problems seem to be more to do with the game itself (as the issue is very widely reported), and I otherwise don't have problems with my games at all.
5,847 (0.81/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Razer Pro Type Ultra
Yeah, you're doing it wrong. If you're having latency issues then you use LatMon to try to get an idea of what exactly may be causing them; you don't turn to LatMon first, especially if your system is working okay. And honestly with the lack of quality of today's console ports, I'm more likely to blame them than bad drivers.
126 (0.14/day)
Yeah, i think you´ve tried it all!
And what does that tell us?
"When you eliminate the impossible, whatever remains, however improbable, must be the truth"
I would start mentioning hardware!
Like one wonky m.2 transistor on a ssd could not do the same.
*bad-970evo-batch-cough*
Or these latency (and headache) inducing ssd installations:
3,121 (2.48/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
I don't know anything about LatencyMon but I do keep an archive of relevant drivers for each of my desktop system. Most of them actually come from the motherboard manufacturer's support pages; all of my AM4 motherboards shipped with a CD-ROM with drivers.
There are a handful of other things I'll install (I have a long checklist of things to do on a new machine) including Visual C++ and Microsoft .NET redistributables.
One thing early in my checklist (before I connect the system to the Internet) is to disable Windows Update downloading over metered connections. Then I just flag my broadband connection as a metered connection: no automatic Windows updates. I'll also disable Windows Updates for five weeks even if I plan on updating in a day or two.
OP's system specs show a well appointed system. There shouldn't be any issue running RDR2 at 1440p and certainly not at 1080p. RDR2 on PC is mature software, it's not in desperate need of performance tuning. The recommended PC hardware was GeForce GTX 1060 or Radeon RX 480 per PCGamingWiki
The 4070 is three generations newer, plenty of performance there.
10,766 (1.73/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 CL30-36-36-76
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
"At this point I'm at my wit's end trying to fix the fact that LatencyMon constantly flags problems as soon as I run any games."
When you run games... the windows scheduler de-prioritizes latency mon and runs the game. So you're getting max power to the game. If you're gonna run latency mon while doing other stuff you have to lock it at high or realtime priority -- then measure.
Otherwise windows is liable to park it and give a 3:1 quantum and it's going to think your system is not responding. Your system is responding- just not to latency mon.
If you were really having latency issues you would know - game would stutter, audio would pop etc. If everything is running great except latency mon when it's in the background then you should be fine.
145 (0.29/day)
Otherwise windows is 100% going to park it and give a 3:1 quantum and it's going to think your system is not responding. Your system is responding- just not to latency mon.
RDR2 has the odd pop, sometimes YouTube shorts. But everything runs really well. I don't have pop issues in other games as far as I'm aware, and other than the odd poorly optimized game (looking at you, Darktide), performance is excellent.
I need to update my system specs, I'm actually on a 7900XT now. Got it on clearance. RDR2 runs fantastically well, it's just the odd faint pop in the game audio. Especially with the mission notifications or while riding a horse, otherwise I never hear it.
10,766 (1.73/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
Im going to install RDR2 and run latency mon with it a bit later - this is a 2 day old clean install of W11 on an 9800x3d - if it lags this system it's 100% the game.
54 (4.15/day)
Oooh. This thread gets my interest.
I'll be installing Win11Pro. But I don't want any bloatware.
2,853 (0.65/day)
System Name BoX-Server | 775PC
Processor I3 3.5GHZ (3150) | Modded Xeon E5450 (OC @3.60)
Motherboard ASRock B85M-ITX | ASUS P5Q-EM
Cooling OEZM HSK | 120MM Heatsink (2-FANs)
Memory 8GB DDR3 (2x4GB) | 8GB DDR2 (4x2GB)
Video Card(s) Onboard | NVIDIA Quadro K2200 4GB
Storage 120GB SSD 1TB WD | 120GB SSD 1TB Seagate 500GB HDD <<
Display(s) DELL 17" LCD 1280x1024 | ASUS 24" LCD IPS
Case CoolerMaster 110 | DIYPC N1e-SPORT
Power Supply EVGA 550WATT | Rosewill 530WATT
Mouse Input-Director| RoseWill FUSION C40
Keyboard Input-Director | RoseWill FUSION
Software WiN1124H2/WiN11ET
54 (4.15/day)
I've noted about 80+ steps to building a new build, installing physical parts etc, all the way through to updating versions - including installing a debloated version of Win11Pro on a partitioned SSD.
Nothing beats a CLEAN system, running what you want it to run; not running what you don't want it to run - even if some of those things are 'nice - but not what I asked for'.
6,770 (4.72/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Generic PS/2
"Debloat" and "optimization" scripts may very well be the culprit. My Raptor Lake system exhibits the same symptoms if I change clock source, sync policy, core parking or HPET settings from default. My sincere advice - if the original setting was working, leave it well alone.
Solaris17
Super Dainty Moderator
26,967 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
Lets not thread hijack, keep it on topic please.
6,770 (4.72/day)
São Paulo, Brazil
Choose you're method carefully.
It's quite involved, so is well worth thinking about in advance!
I don't believe that request was aimed specifically at us, but yeah - it seems Windows 11 is very particular about some popular low-level tweaks, more so than Windows 10 used to be. Whether it's due to a kernel bug or just changes with how it interfaces with the underlying hardware, changing some of these popular tweak settings can cause your system latency readings from LatencyMon to go pretty insane. If LatencyMon shows what are essentially just spikes - depending on the magnitude or frequency that's ok, you just need to be concerned if you're actually running into delays, skips, lags, or weird behavior while using the system. This will occur even on a freshly installed system.
Regarding tweaked or "debloated" settings: if something offers you a "vast improvement" over the original and it sounds too good to be true for such a "simple fix", then you better believe that it is too good to be true. The prudent approach is not to apply such tweaks, or do so with a full backup ready - or at least a thorough note on how to reverse the process if necessary.
AsRock
TPU addict
19,086 (3.00/day)
UK\USA
WOW, that PCB is really bent :(.
10,766 (1.73/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
Sitting dorking around on the internet:
4k no DLSS
After RDR2
I am unconvinced that this is a tool that has aged well. This is a brand new install where I havent changed anything at all on the OS. I don't have any audio popping or stutter or power saving features or whatever -- fairly certain just about any system will fail latency mon running in the background while running a stressful game.
145 (0.29/day)
4k no DLSS
After RDR2
yeah I think I'll just stop using the damn thing to be honest. Unless I have specific issues that require me to isolate a specific thing, I'll give it a hard pass I reckon.
7,061 (1.01/day)
USA
Cooling Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active
Storage 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data), ASUS BW-16D1HT (BluRay)
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
I did a fresh reformat last night on my office computer, nothing to it. Win10 LTSC 21H2, get ISO, put it on a thumbdrive with Rufus, boot the computer to the usb, turn off all tracking options, select offline option in window. Took about 5 minutes.
13,171 (1.97/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Right. Key point is "IF" you are having latency issues.
I personally am not a big fan of LatencyMon. It causes some to panic needlessly thinking there is something wrong, sometimes, seriously wrong with their systems - leading them to start replacing parts, reinstalling Windows, and yanking their hair out.
It is also important to note that some of the steps used to reduce DPC latency issues with some games may actually be counterproductive to lower latency goals with other games and some non-gaming tasks. Yet the program does not explain this.
Note those graphs showing a tiny bit of pink are for the "highest" reported this and "highest" measured that. But was that just 1 single high peak in that 5 minute time period? Or one of 1000s? We don't know. What is the average? We don't know. Did that high peak result in an audible interruption in the sound or audible noise (static, crackle or pop) at that instant? We don't know.
I have run this on many systems and when problems were reported, LatencyMon almost always provides the exact same error report, reading as follows,
Your system seems to be having difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
One exception. If you connect to your network by wifi, the report will include the additional line (highlighted in bold),
Your system seems to be having difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. At least one detected problem appears to be network related. In case you are using a WLAN adapter, try disabling it to get better results. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
Reviews claim it provides a detailed report on system latency. I feel it is sadly lacking detail and too generalized. One size [report] does NOT fit all.
I like how it shows the "current" status. That is valuable information. But I want more. Average would be good. And especially needed is more detail on those peak values. One event above average peak does NOT suggest a problem.
That said, I agree with the reviewer of this XbitLabs article, LatencyMon – Obsession in the PC Tweaking Community, where he says,
Overall it seems like LatencyMon is a decent tool for your testing but the problem is that a lot of people on the internet assume that the results the utility gives you are the ultimate truth. In the end, this tool is not a specialized hardware tool ... and the results should be taken with a grain of salt.
A wise choice, IMO. :)
962 (0.63/day)
System Name ASUS TUF F15
Processor Intel Core i7-11800H
Motherboard ASUS FX506HC
Cooling Laptop built-in cooling lol
Memory 24 GB @ 3200
Video Card(s) Intel UHD & Nvidia RTX 3050 Mobile
Storage Adata XPG SX8200 Pro 512 GB
Display(s) Laptop built-in 144 Hz FHD screen
Audio Device(s) LOGITECH 2.1-channel
Power Supply ASUS 180W PSU
Mouse Logitech G604
Keyboard SteelSeries Apex 7 TKL
Software Windows 10 Enterprise 21H2 LTSC
if you install 24H2 LTSC, there is option to install without MS Account. (or, I have disabled requirement in rufus?)
anyway, you can disable requirement for account in rufus, also, the method of "OOBE" trick in command prompt still works, search for it.
yes, I advise you to get fresh drivers for what you could get, install them, and only after that go online and let windows update download it's bullsh*t.
dgianstefani
TPU Proofreader
5,033 (1.99/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front, LINKUP Ultra PCIe 4.0 x16 white
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Benchmark Scores Legendary
Use 24H2 LTSC for no bloat and less spyware by default.
962 (0.63/day)
Memory 24 GB @ 3200
Mouse Logitech G604
and don't forget to disable "AI Recall" cr*p that sends random screenshots somewhere:
ADMIN CMD/POWERSHELL:
DISM /Online /Disable-Feature /Featurename:Recall
