RTX 3080 power supply requirements - 850W?
19 (0.01/day)
Denmark
Processor Core i7 8700K
Motherboard Asus Strix Z370-E
Cooling Corsair Hydro H115i Pro
Memory 2x8 G.Skill 3600 MHz 16-16-16-36
Video Card(s) Asus Radeon RX 6800
Storage 1 TB Samsung Evo 970 Nvme
Display(s) LG UC88 34"
Case Fractal Design R6
Power Supply Corsair TX850
What would YOU pick if the choice was between a Corsair HX750 (80+ Plat) and a Seasonic Focus GX-850 (80+ Gold) if the prices were the same? I have a 8700K with a 3080, using it for video editing and gaming after hours. Outervision puts me about here. Used to run with a Tx850 since 2011, and its starting to show its age on the noise level mostly. And nephew has a need for a hand me down. I am asking because there are a couple of deals in town where I can get either of those for around 130 euro incl. VAT. And that is a bargain if you ask me.
14,227 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
The Seasonic Focus, the difference between Platinum and Gold is negligable but the extra 100W might make a difference in stability.
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
get the 850w Focus+
1,374 (0.35/day)
Processor 3900X 4.425
Motherboard X570 Tomahawk
Cooling Galahad 360 push-pull
Storage Optane 280gb PCI-E
Display(s) PG348Q
Case Core X71
Power Supply AX1500i
I'm not surprised to see an individual mention Igor (this guy never had an Ampere card and a scope in the first place) make up information out of thin air.
Now with that said out, you could try this:
Basically a juiced out Seasonic with the ability to run two PCs and whatnot.
19 (0.01/day)
Denmark
freeagent
9,521 (4.09/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
get the 850w Focus+
The Focus Plus and Prime Ultra were the units with 30 series problems were they not?
I was under the impression the new Focus and Prime no longer had the issue..
I would get the GX if the price is the same.
1,374 (0.35/day)
Display(s) PG348Q
Case Core X71
Not a whole lot much, if you could link to a site you're buying from, there might be some other Focus based units than Seasonic's own.
Check out Super Flower's stuff, they make some good units as well. EVGA rebadges and sells those.
19 (0.01/day)
Denmark
get the 850w Focus+
It isn't a Focus Plus, but a Focus GX-850 - I compared them on Seasonic's home page and couldn't see a difference between them. Same efficiency rating so, guess its fine?
ITs from https://www.happii.dk/ - they have Super Flower at a significantly higher price but the EVGA GQ 850 for same price. So the EVGA is an OEM Focus with same quality build but EVGA customer support?
1,374 (0.35/day)
Display(s) PG348Q
Case Core X71
The GQ is not too good, EVGA does not use Seasonic as an OEM. As for the GX, I'd suggest buying a more beefy Seasonic than those. Asus makes some Focus Plus units as well, with bigger fans and heatsinks, etc. I'll check the site.
19 (0.01/day)
Denmark
Beefi
Oh, well, then Ill probably NOT get the GQ. I was kind of thinking 850W was beefy enough for the build I am running (Outervision recommends 650W). So that gives me 150+ W headroom. And there seemed to be somewhat a split between 750W being enough and 850W being a bit overkill but w/e in this thread up to now. You disagree with that I sense?
Edit: Added a rather important 'NOT'
1,374 (0.35/day)
Display(s) PG348Q
Case Core X71
It all depends on your CPU and whatnot. You might pull about 500W tops in games, then it might be 600 or 400. Don't listen to Extreme Power Supply calculator, do your own calculation by checking your components and how much power it all consumes.
I wouldn't bother with the GQ, it's not worth it. Here is an overkill unit:
It physically looks like a big PSU though, make sure you have the space.
19 (0.01/day)
Denmark
Thank you for your help, X71200. But it looks like it is twice the cost, and I have been doing fine on an old clanker of a 80+ Bronze certified Corsair TX850 from 2011 for the last 4 months. I think Ill try to scrooge by with a Gold Plus certified replacement. Unless the GX-850 is much worse than what I have, it would probably run just as stable.
1,374 (0.35/day)
Display(s) PG348Q
Case Core X71
You're overpaying:
Same PSU with digital monitoring.
Alternatively, this is even kind of better:
9,340 (5.17/day)
Louisiana
Keyboard G710+x3
19 (0.01/day)
Denmark
With a fairly normal i7 8700K running at 4,9 GHz when boosting, AIO cooler and nothing fancy outside of the 3080 TUF, I'll go with the 850W Gold solution since it is priced the same.
9,340 (5.17/day)
Louisiana
Keyboard G710+x3
More important would be what size breaker the computer is on and how much other stuff is connected to the same circuit as this machine.
Otherwise yeah I'd do 850w minimum too the psu chart doesn't account for extra ocing ability with delid chips or specialized cooling like chiller or just taking advantage of seasonal cold weather cooling.
45 (0.01/day)
Processor 9700k
Motherboard asrock z390 extreme4
Video Card(s) 5700
Display(s) benq xl2411p 144hz 1080p
wait what?
you're saying igor made up his 3080 stats or some individual? what individual anyway
1,374 (0.35/day)
Display(s) PG348Q
Case Core X71
wait what?
Igor never had an Ampere GPU. The whole capacitor thing was made up without actual evidence in the first place.
19 (0.01/day)
Denmark
Its a modern housing with 13A rated at 240V for the breaker group my pc is on, and it shares it with the normal fixtures for lights etc. of half the appartment. Kitchen hardware is on third group with 16A. I think the power we got is very stable, and clean.
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
its a focus + with a different name.
the problem with the RTX 3 series isnt the PSU, it is that they draw massive power at peak usage in a spike.
the issue is reported with users using many different PSU's from many different OEM PSU makers.
i replaced my focus+ with an identical higher wattage focus+ & it fixed the issue.
1,277 (0.29/day)
Motherboard MXI APEX
Storage 660P 1TB, 860 QVO 2TB
Case Open Benchtable V2
Audio Device(s) SB X-Fi
Power Supply MSI A1000G
Mouse G502
Keyboard G815
Software Gentoo/Windows 10
Watercooled 3080 here running fine with Seasonic X-850.
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
yea, my Over voltage protection shutdowns were with the 3090, on a focus+ 750W. the way i looked at it, i didnt want to order a 850W for $180 & find it didnt cut the power needs, so i just spent $240 for the 1000W version , i figured better safe than sorry.
the beauty is when switching the PSU's, all i had to do was pull the box & the PCI cables, i reused all the other cables from the 750W with the 1000w. as easy an upgrade as installing a new RAM stick almost
i spoke with nvidia , & showed them all the people posting in their own forums about the same issue, how Power supplies that are more than capable based on Nvidias own specs, arent cutting it with real world use of the RTX3 series cards. this is from their own Spec's page.
350W
750W PSU recommendation. so when a guy owns a 750W Power supply from one of the better PSU makers, he'd be understandably surprised when it isnt capable of powering previously mentioned 3090's/3080's
