RX 5700 XT GPU Swap
Durvelle27
6,800 (1.49/day)
Memphis, TN
System Name Black Prometheus
Processor |
Cooling Thermalright PA120 SE |
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
Hey guys,
If any of you know I’ve had numerous issues with my 5700 XT 50th Anniversary since day one. My question for current owners/users is it worth swapping for AIB 5700 XT. As I was offered a deal to virtually swap for no cost but I’m not sure if it will make any difference.
FreedomEclipse
~Technological Technocrat~
24,283 (3.75/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Sounds like an excuse for a 2080Super
187 (0.10/day)
Processor Ryzen 9800X3D
Motherboard B650 - Asus TUF B650-E WiFi
Cooling Arctic Freezer II 240mm AIO
Memory 32GB DDR5-6000 - CAS 32
Video Card(s) 4070 Ti - Gigabyte Eagle OC
Display(s) 32” 1440p - Samsung C32HG70
Case Silverstone GD11
Audio Device(s) Focusrite Scarlett 8i6 3rd Gen - Sennheiser HD595
I’d do the swap. Noise and thermals are tremendously better on the aftermarket cards.
Durvelle27
6,800 (1.49/day)
Memphis, TN
Processor |
5,717 (0.93/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
Isn't 5700XT anniversary specially binned? That would be a downgrade no?
Didn't 19.9.2 fix your problem? Can you RMA the card with AMD? That should be well within warranty.
Personally I won't just hang on to your 50th special 5700XT. There is a good chance that by end of this year the driver will be all sorted out. Only 3 more months, not a whole lot!
Durvelle27
6,800 (1.49/day)
Memphis, TN
Processor |
No as mentioned in the other thread
After 19.9.2 I still get freezing Which requires a hard reset and crazy as it is temps be sitting around 45*C before the freezing
Also warranty would be a hard thing as 50th are very limited and there’s almost no stock of them
And I don’t think they are binned as AIBs run higher clocks
5,717 (0.93/day)
I wish lemon law applies to GPU, that right there is a lemon. You can keep trying your luck with other 5700XT. Good luck man
43,007 (6.72/day)
Asrock or sapphire
Durvelle27
6,800 (1.49/day)
Memphis, TN
Processor |
187 (0.10/day)
A measly 75mhz or something. The thermals on those stock blowers are horrific. Whatever he “gained” from the factory OC is almost certainly being lost and thensome to thermal throttling after the card hits 100C+ in about 15 minutes. Read some reviews of aftermarket versus the stock cooler. They’re terrible.
Put it this way, I already have my 5700 XT, but if someone had previously handed me a New-In-Box Anniversary Edition, I would’ve immediately sold it and bought an aftermarket model.
To the OP: Take the offer.
6,130 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Yeah, better thermals, idle fan stop. Dump that Anni as soon as you can. Just don't trade it for something like that golden MSI card with way too small thermal pads on memory.
1,269 (0.34/day)
Birmingham UK
System Name El Calpulator
Processor AMD Ryzen R7 7800X3D
Motherboard ASRock X670E Pro RS
Cooling ArcticCooling Freezer 3 360ARGB AIO
Memory 32GB Corsair Vengance 6000Mhz C30
Video Card(s) MSI RTX 4080 Gaming Trio X @ 2925 / 23500 mhz
Storage 5TB nvme SSD + Synology DS115j NAS with 4TB HDD
Display(s) Samsung G8 34" QD-OLED + Samsung 28" 4K 60hz UR550
Case Montech King 95 PRO Blue
Audio Device(s) SB X4+Logitech Z623 2.1+Astro A50 Wireless
Power Supply be quiet! Pure Power 12 M 1000W ATX 3.0 80+ Gold
Mouse Logitech G502X Plus LightSpeed Hero Wireless plus Logitech G POWERPLAY Wireless Charging Mouse Pad
Keyboard Logitech G915 LightSpeed Wireless
Software Win 11 Pro
Benchmark Scores Just enough
I had similar issues with my 2 5700xt's I think it is a driver problem.Try disable Hardware Acceleration on your web-browser and also disable Enhanced Sync and this could probably fix some issues
7,582 (1.77/day)
Isn't the pulse supposedly the best AIB 5700xt out there? If you get an option to swap, with no extra costs, I'd say give it a try.
632 (0.30/day)
I would try to sell it, hoping to catch some AMD fanboy willing to pay decent money for it, then add a couple dozen bucks and get a 2070super ;)
17,471 (4.67/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710 (Red/Black)
I would do the swap for the Sapphire Pulse 5700 XT. then do a clean install of OS when it arrives.
I still think you need to try a new B450 motherboard, MSI has some new "Max" B450 and X470 boards. only $80. I think it might fix all your issues. I know it shouldn't be that way, but you might just have a bad B350 board, the quality control on them wasn't all that great to be honest.
Durvelle27
6,800 (1.49/day)
Memphis, TN
Processor |
Again my board has nothing to do with the issue
I’ve had this board since first gen Ryzen with a 1700X and it has never given me an issue. Only issue I’ve ever had was my CPU overheating due to the paste needed to be replaced.
1,340 (0.36/day)
Nowy Warsaw
System Name SYBARIS
Processor AMD Ryzen 5 3600
Motherboard MSI Arsenal Gaming B450 Tomahawk
Cooling Cryorig H7 Quad Lumi
Memory Team T-Force Delta RGB 2x8GB 3200CL16
Video Card(s) Colorful GeForce RTX 2060 6GV2
Storage Crucial MX500 500GB | WD Black WD1003FZEX 1TB | Seagate ST1000LM024 1TB | WD My Passport Slim 1TB
Display(s) AOC 24G2 24" 144hz IPS
Case Montech Air ARGB
Audio Device(s) Massdrop + Sennheiser PC37X | Koss KSC75
Power Supply Corsair CX650-F
Mouse Razer Viper Mini | Cooler Master MM711 | Logitech G102 | Logitech G402
Keyboard Drop + The Lord of the Rings Dwarvish
Software Tiny11 Windows 11 Education 24H2 x64
Wasn't anniversary edition $450 instead of $400? Unless you get similar value AIB you're facing loss. But then again holding on to it longer won't net you anything. It's not like Nvidia's Star Wars edition cards.
Solaris17
Super Dainty Moderator
27,176 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
I’m pretty sure they hold some in reserve for replacement or attempt repair. Just RMA.
Nvm I can’t read, you got a swap offer my bad.
5,717 (0.93/day)
Will the warranty be transferable from the new GPU? If not transferable I would not swap. Warranty is absolute must have for hardware this new, 7nm and such
Durvelle27
6,800 (1.49/day)
Memphis, TN
Processor |
Yes new includes warranty
5,717 (0.93/day)
17,471 (4.67/day)
your decision is easy then. do the swap. and if you end up not liking the sapphire pulse, i will buy it from ya for a small discount. (not buying the reference cooler though) :D
msi has bad reviews for the thermal pads not touching the vrm's, so I would get the sapphire pulse.
3,984 (1.11/day)
System Name Wut?
Processor 3900X
Motherboard ASRock Taichi X570
Cooling Water
Memory 32GB GSkill CL16 3600mhz
Video Card(s) Vega 56
Storage 2 x AData XPG 8200 Pro 1TB
Display(s) 3440 x 1440
Case Thermaltake Tower 900
Power Supply Seasonic Prime Ultra Platinum
I have the Pulse 56 and I would not get a Pulse line again. Nitro would be my preferred.
17,471 (4.67/day)
Yeah if he could do a swap plus pay like $30 more for the Nitro that would be ideal. Pulse is a good card this round though, gamersnexus highly recc it / reviewed it.
Durvelle27
6,800 (1.49/day)
Memphis, TN
Processor |
MSI Mesh and Sapphire Pulse are the only options
