- Jan 14, 2019
- 16,197 (6.86/day)
- Midlands, UK
System Name | My second and third PCs are Intel + Nvidia |
Processor | AMD Ryzen 7 7800X3D @ 45 W TDP Eco Mode |
Motherboard | MSi Pro B650M-A Wifi |
Cooling | Noctua NH-D9L chromax.black |
Memory | 2x 24 GB Corsair Vengeance DDR5-6000 CL36 |
Video Card(s) | PowerColor Reaper Radeon RX 9070 XT |
Storage | 2 TB Corsair MP600 GS, 4 TB Seagate Barracuda |
Display(s) | Dell S3422DWG 34" 1440 UW 144 Hz |
Case | Corsair Crystal 280X |
Audio Device(s) | Logitech Z333 2.1 speakers, AKG Y50 headphones |
Power Supply | 750 W Seasonic Prime GX |
Mouse | Logitech MX Master 2S |
Keyboard | Logitech G413 SE |
Software | Bazzite (Fedora Linux) KDE Plasma |
That's speculation. Fact is, having X number of sensors that cover some area on the GPU die is still better than nothing.I will tell you something shocking, the hotspot is not actually the hottest part of the chip, because it is also an estimate according to the simulations so the sensor is placed there. The entire die is not fully covered by temp measuring sensors so if someone, for example, manages to leave the part of the die without paste or not touching the cooler, it can simply get damaged by high temps depending on the sensor grid and solution.
If it's safe (like you said it yourself), then how is AMD risking damaging the card? What is prolonged use? An hour? Maybe two? Six hours? Do you think AMD didn't factor this in when they gave guidelines on what a safe temperature means?Secondly, the safe operating temperatures of GPUs are specifically made with hotspots in mind and local temps up to 120C are safe depending on the process, architecture, area, PCB, material and longevity of the exposure to such temp. It was AMD's decision to OC them out of the box and so much they are risking damaging the die if the exposure to such temps would be prolonged so that's why they actually measure the hotspot, it is not because they like you or technically superior.
We have hotspot temperature sensors so that the driver has a better understanding of how hot the GPU die actually is so it can give us more performance without a risk of damage. I never said AMD liked me or were superior in any way.
Edit: I'm not just talking about AMD vs Nvidia. I'm talking about any GPU that has hotspot temperature sensors on it.
