AsRock
TPU addict
- Jun 23, 2007
- 19,346 (2.93/day)
- UK\USA
Processor | AMD 3900X \ AMD 7700X |
Motherboard | ASRock AM4 X570 Pro 4 \ ASUS X670Xe TUF |
Cooling | D15 |
Memory | Patriot 2x16GB PVS432G320C6K \ G.Skill Flare X5 F5-6000J3238F 2x16GB |
Video Card(s) | eVga GTX1060 SSC \ XFX RX 6950XT RX-695XATBD9 |
Storage | Sammy 860, MX500, Sabrent Rocket 4 Sammy Evo 980 \ 1xSabrent Rocket 4+, Sammy 2x990 Pro |
Display(s) | Samsung 1080P \ LG 43UN700 |
Case | Fractal Design Pop Air 2x140mm fans from Torrent \ Fractal Design Torrent 2 SilverStone FHP141x2 |
Audio Device(s) | Yamaha RX-V677 \ Yamaha CX-830+Yamaha MX-630 \Paradigm 7se MKII, Paradigm 5SE MK1 , Blue Yeti |
Power Supply | Seasonic Prime TX-750 \ Corsair RM1000X Shift |
Mouse | Steelseries Sensei wireless \ Steelseries Sensei wireless |
Keyboard | Logitech K120 \ Wooting Two HE |
Benchmark Scores | Meh benchmarks. |
It can't just be because the "vapor chamber" can't handle the heat load. When the 6900 XT uses the same type of heatsink & has about the same thermal heat load is watts when overclocked.
Maybe they over worked the machines that make these ( the molds or what ever ), there fore getting a bunch with weak seals or some thing. Then again you get AIO with contaminates so shit happens right.
