gadgetgeek
- Nov 2, 2019
- 12 (0.01/day)
I mean two of 32GB each,its cheap comparatively.Hmm, will it? only 1 channel
System Name | Beaver's Build |
Processor | AMD Ryzen 9800X3D |
Motherboard | Asus TUF Gaming X670E Plus WiFi |
Cooling | Corsair H115i RGB PLATINUM 97 CFM Liquid |
Memory | G.SKILL Trident Z5 Neo DDR5-6000 CL30 RAM 32GB (2x16GB) |
Video Card(s) | NVIDIA GeForce RTX 4090 Founders Edition |
Storage | WD_BLACK 8TB SN850X NVMe |
Display(s) | Alienware AW3225QF 32" 4K 240 Hz OLED |
Case | Fractal Design Design Define R6 USB-C |
Audio Device(s) | Focusrite 2i4 USB Audio Interface |
Power Supply | SuperFlower LEADEX TITANIUM 1600W |
Mouse | Razer DeathAdder V2 |
Keyboard | Corsair K70 RGB Pro |
Software | Microsoft Windows 11 Pro |
Benchmark Scores | 3dmark = https://www.3dmark.com/spy/51229598 |
For the ram I would recommend buying the Trident Z NEO, it is the latest series by G skill designed specifically for Ryzen 3 to guarantee hassle free compatibility.
System Name | Wut? |
Processor | 3900X |
Motherboard | ASRock Taichi X570 |
Cooling | Water |
Memory | 32GB GSkill CL16 3600mhz |
Video Card(s) | Vega 56 |
Storage | 2 x AData XPG 8200 Pro 1TB |
Display(s) | 3440 x 1440 |
Case | Thermaltake Tower 900 |
Power Supply | Seasonic Prime Ultra Platinum |
System Name | Apex Raptor: Silverback |
Processor | Intel i9 13900KS |
Motherboard | z790 Apex |
Cooling | LT720 + Phanteks T30 |
Memory | 32GB |
Video Card(s) | RTX 5090 Astral |
Storage | 990 PRO 4TB |
Display(s) | Neo G8 / C1 65" |
Case | Antec Performance 1 |
Audio Device(s) | DT 1990 Pro / Motu M2 |
Power Supply | Hx1200i |
Mouse | G502 X Plus |
Keyboard | K95 Platinum |
Everything looks great, part selection seems solid for a high end build including the monitor, only thing left to add is the RGB blingThank you,
here's the rig details so far including the Trident Z Neos:
Corsair AX1200 | Western Digital Black 6TB | NVIDIA GeForce RTX 2080 Ti FE | LG - 27UD68-P 4K IPS | Corsair H115i RGB AIO Water Cooler | Inland 1TB NVMe M.2 (Phison E12 Controller) | G.SKILL Trident Z Neo (For AMD Ryzen) Series 32GB (2 x 16GB) | Fractal Design Define R6 | Asus ROG X570 Crosshair VIII Hero | Ryzen 9 3950X
Honestly, since you're not limited by the case and (clearly) not by budget, haven't you thought about a more potent AiO? Some 360mm perhaps?Corsair AX1200 | Western Digital Black 6TB | NVIDIA GeForce RTX 2080 Ti FE | LG - 27UD68-P 4K IPS | Corsair H115i RGB AIO Water Cooler | Inland 1TB NVMe M.2 (Phison E12 Controller) | G.SKILL Trident Z Neo (For AMD Ryzen) Series 32GB (2 x 16GB) | Fractal Design Define R6 | Asus ROG X570 Crosshair VIII Hero | Ryzen 9 3950X
Well all right - if you already have this AiO, use it.So I got the Corsair H115i RGB AIO 280mm for relatively cheap (at the time)
Thing is though: you're getting a CPU with a very high heat concentration and it's not fully optimized yet, i.e. it may get faster and hotter with updates.
If you're just going to game and you wanted this CPU for fun, it'll be fine.
But if you're thinking about long time all-core load (some computing tasks, some video processing etc), those 140mm fans may end up running near 2000 rpm max and this will NOT be pleasant.
Honestly, with this new era of high-core 7/10nm CPUs, cooling will become an issue. I just hope Peltier coolers are not coming back...
System Name | The work PC /2700x/5950x |
Processor | 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V |
Motherboard | Gigabyte AORUS Master X570/2xMSI X470 M7 AC |
Cooling | Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE |
Memory | 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400 |
Video Card(s) | 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI |
Storage | 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro |
Display(s) | Dell UltraSharp U2518D/2408WFP |
Case | Corsair 800D / Lian test bench/NZXT 500 |
Power Supply | AX 850 Titanium/AX 860i/AX 760 |
Software | Dual boot/Win 10 / Linux / Win 10+Linux |
I, obviously, don't have a 3950x yet but my 3900x running pure stock and 100% 24/7 struggles to stay below 70 C and that is with a 480 mm radiator placed in a 20 degree room (outside the case). You will hear your rad fans if you try to copy that load.Even if i don't overclock?
Keyboard | Corsair K70 Max |
Software | Windows 10 Pro |
Yes, the problem is that the cores jumps up and down a lot and as such, even on my now "simple" eight core CPU, the temperatures can jump from 35 to 65 degrees C, in the blink of an eye. Imagine how 16 cores will behave...Even if i don't overclock?
Better keep the load at 100 %, the jumps still gets me worriedYes, the problem is that the cores jumps up and down a lot and as such, even on my now "simple" eight core CPU, the temperatures can jump from 35 to 65 degrees C in the blink of an eye. Imagine how 16 cores will behave...
OK, fans are not running fast, I have a 3-way splitter running slow and one running at a more normal 1200 rpm. I still haven't bothered to optimize/figure out their speed.That's insane, 70C with 480mm radiator?
What in the world?
Well temperatures seems to be a mixed bag but in general these chips are hard to keep cool. Below is a 6 hour run at 96% load.Sanity check on 3900x heat issues...
Ok, I am building two 3900x rigs to replace two i7-6700k rigs that I used with Cooler Master V8 GTS High Performance CPU Coolers (Vapor Chambers) for several years.. Went AMD for the first time in 15 years.... I am used to temps (and space heaters as it were) that are pretty low/cool... So I...hardforum.com
Well temperatures seems to be a mixed bag but in general these chips are hard to keep cool. Below is a 6 hour run at 96% load. View attachment 137476
Sure, but as I wrote I'm not 100 % sure about the speed. The Noctua NF A12 runs with a low noise resistor so I think that is around 1700 rpm, the three Noiseblockers (can't really remember their real name) is low speed. 27 C exit air from the Noctua and the rad is not warm.you got fans on that 480mm radiator, right?
Don't focus too much on someone's posts. People don't know how to build PCs or have bad airflow. Just look at some discussions on this forum.![]()
3900X With Corsair H115i hitting 90-95C ☹️
Hello ? I recently upgraded my computer and I thought everything was fine but my temps while playing games and benchmarks are getting really really hot. I have that ryzen master program and it shows my temps are around 35-40 when browsing but as soon as I start a game or benchmark it’s hitting 80...linustechtips.com
