Ryzen 3950X Build Help
1,098 (0.16/day)
System Name Beaver's Build
Processor AMD Ryzen 9800X3D
Motherboard Asus TUF Gaming X670E Plus WiFi
Cooling Corsair H115i RGB PLATINUM 97 CFM Liquid
Memory G.SKILL Trident Z5 Neo DDR5-6000 CL30 RAM 32GB (2x16GB)
Video Card(s) NVIDIA GeForce RTX 4090 Founders Edition
Storage WD_BLACK 8TB SN850X NVMe
Display(s) Alienware AW3225QF 32" 4K 240 Hz OLED
Case Fractal Design Design Define R6 USB-C
Audio Device(s) Focusrite 2i4 USB Audio Interface
Power Supply SuperFlower LEADEX TITANIUM 1600W
Mouse Razer DeathAdder V2
Keyboard Corsair K70 RGB Pro
Software Microsoft Windows 11 Pro
Benchmark Scores 3dmark = https://www.3dmark.com/spy/51229598
with my CH8W mobo i noticed even with the power off the RGB LEDs and other LEDS are running, does that seem normal for modern boards?
7,746 (3.29/day)
California
System Name His & Hers
Storage lots of SSD.
Yes, specifically Asus boards do that my Maximus XI code does the same thing you can turn it off in the bios though.
850 (0.42/day)
Processor Intel i9 13900KS
Motherboard z790 Apex
Cooling LT720 + Phanteks T30
Memory 32GB
Video Card(s) RTX 5090 Astral
Storage 990 PRO 4TB
Display(s) Neo G8 / C1 65"
Case Antec Performance 1
Power Supply Hx1200i
Mouse G502 X Plus
Keyboard K95 Platinum
If you unplug your HDMI/DP cable they should switch off. At least they do that on my system
1,098 (0.16/day)
7,746 (3.29/day)
California
Were you able to grab one? They sold out before I could even click on the page lol.
1,098 (0.16/day)
7,746 (3.29/day)
California
Yes, but Micro Center seems to have some also if you hurry !!
Oh I have 0 interest my 3900X/9900k combo is already pretty overkill.... I was more curious about how fast they would sell out.
Congrats on being able to pick one up.
1,098 (0.16/day)
Seems like NewEgg had very little but Micro Center has a whole bunch
Micro Center now sold out Online as "AVAILABLE FOR IN-STORE PICKUP ONLY." now
1,098 (0.16/day)
7,746 (3.29/day)
California
1,098 (0.16/day)
7,746 (3.29/day)
California
1,098 (0.16/day)
Looking good man.... I'm excited to see it all finished and cable managed.... also use R20.... R15 is not a great fit for 8+ core CPU.
R20
need a new HDD ... mine just kicked the bucket
1,098 (0.16/day)
1,098 (0.16/day)
So I might have a number of bad components already... not sure which it is... memory, cpu, or mobo? seems to always land on CPU: "24" so far ...
Another pass:
Deleted member 185158
Wonder if Memtest, as newly released as it is, would be good for testing that chip?
This version was released Nov. 22nd 2019.
Have you tired any other testing? AIDA64 maybe? LinPack?
3,441 (1.69/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Another pass:
How does it behave when you relaxing your timings or frequency - will it pass at DDR4-3200 or looser timings?
( Remember Zen2 spec is DDR4-3200 anything over that is OC )
1,098 (0.16/day)
i'm running prime95 "Large" test stressing memory and memory controller and basically i'll get some issues with chrome and black screens temporarily
i already swapped the ram chips that was the 2nd test you saw
3,441 (1.69/day)
Mouse Logitech M575
I have a feeling you just need a little nudge somewhere to get stability since you only have a few errors.
Can you provide a screenshots of Ryzen Master showing it's detected memory settings and SPD chip details from Thaiphoon Burner (http://www.softnology.biz/)?
1,098 (0.16/day)
i bumped SoC to 1.1V and DRAM to 1.360V
2019-11-29 18:46:08 - [Data Error] Test: 4, CPU: 24, Address: 1DD9CBF08, Expected: F7F7F7F7, Actual: E7F7F7F7
it's always starting at this memory address:
Lowest Error Address0x1DD9CBF08 (7641MB)
3,441 (1.69/day)
Mouse Logitech M575
How many sticks do you have installed?
Wonder if tRFC isn't loose enough at 630 clocks. You could try looser say 700 clocks.
Looks like your tRC is really loose in comparison to your XMP profile. Should be 58 not 85. Take that off auto, and set this manually.
1,098 (0.16/day)
It was 2, I’m trying with 1 now as we speak
Testing on single channel to run 2 sticks may help if you can test both sticks properly, you gotta set up your memory timings the best you can manually. Don't forget the tRC timing should be correct for proper XMP functionality.
Also, the memory controller may not like the Cas 16-19-19 either. IMC can be picky that way.
3,441 (1.69/day)
Mouse Logitech M575
Make sure they are installed in slots A2 and B2.
tRC does seem high as ShrimpBrime pointed out. One simple thing you can try real quick is to change your timings to match the Thaiphoon Burner output for 1802Mhz as from your screen shot and set everything else to AUTO but keep your SOC and DRAM voltage. Also try PROC ODT to 60 ohms. (set all in BIOS/UEFI - NOT via Ryzen Master)
Can you use HWiNFO64 to output your DRAM data. I want to see if it provides the XMP timings in nanoseconds for your ram. Since the tRC was off maybe something else if off too and we can calc a reasonable value in particular for your tRFC.
