Samsung 980 PRO NVMe SSD Uses TLC NAND Flash with Half the Endurance of 970 PRO: Product Page
28,921 (6.84/day)
because they aren't relevant for most consumer workloads.
That's a load of nonsense. 1000P/E(and that is a best case scenario) cycles is absolutely terrible for a OS/Boot drive. I have been testing QLC drives for reliability and the picture is not good. Less than a year and whole groups of blocks are failing already. SSD Makers are failing to state those stats because they want to hide QLC's pathetic lack of durability. They want to sell a product line and make gobs of money doing it(because QLC is dead cheap to make).
Apply that same thought process to this thread topic and the same mentality fit well here. Samsung is pushing TLC as a professional product because that want to make more money from a product that cost less to make. Granted, to there credit, their latest iteration of TLC 3DNAND has some improvements. However, it is still no comparison to the longevity of MLC and SLC. TLC has no place in professional and prosumer devices, especially at the prices being asked.
7,631 (1.77/day)
That's a load of nonsense. 1000P/E cycles is absolutely terrible for a OS/Boot drive.
It really depends on what you're using the drive for. I wouldn't recommend QLC for anyone who's using the drive for say applications/tasks with large number of writes but then when you're using the QLC argument for sweeping statements like these ~
You're also failing to understand the basic premise which I've been trying to debunk over the last few pages!
Much more important than the performance changes is the write endurance boost the 665p brings compared to the 660p. Both capacities of the 665p have 50% higher rated write endurance than the 660p, bringing them up to about 0.16 drive writes per day (DWPD) from the 660p's 0.11 DWPD. This is still a lot lower than the 0.3 DWPD that is typical for low-end consumer SSDs that use TLC NAND, but the increase does show that Intel's feeling more confident in their second generation of QLC.
Intel wouldn't back their QLC drives for 5 years if they are as brittle as some of the theories here suggest, in having said that given you actually know your workloads well ~ you should get the appropriate drive whether QLC, TLC or MLC. At the risk of repeating myself I'd say modern NVMe drives labelled PRO, in case of Samsung, are geared more towards (higher) performance than durability or better endurance. For that you have enterprise drives, now you can debate all you want whether these (PRO) drives should be rated as highly as their predecessors wrt TBW but there's no evidence to suggest as of now they're any less reliable or lasting than their predecessors!
7,631 (1.77/day)
If only it was as simple as that, looking at this thread though it's pretty apt that "common sense isn't as common" as you'd think. I'm sure you've heard of the term write amplification, haven't you?
Let some of the experts weigh in ~
1 DW/D Does Not Equal 1 DW/D
A common misconception when examining SSD specifications is that “1 DW/D” on one drive means the same endurance as “1 DW/D” on another drive. That’s not true, even for drives of the same model but different capacities.
This effect becomes even more pronounced as drives increase in capacity. When comparing the highest capacity model of the Ultrastar DC SS200 at 1 DW/D with the highest capacity Ultrastar DC SS200 available in a 3-DW/D specification, we see that even though the DW/D value of one is three times the value of the other, the actual amount of lifetime data that can be written to the 3.2TB model is only about 25% more
Following up ~
Micron's 64-layer 3D TLC NAND has consistently proven to offer higher performance than their first-generation 32L TLC, but Memblaze isn't advertising any big performance increases over the earlier PBlaze5 SSDs. Instead, they have brought the overprovisioning ratios back down to fairly normal levels after the 32L PBlaze5 drives. Those drives were rated for 3 DWPD, and as a result kept almost 40% of their raw flash capacity as spare area. The PBlaze C916 with 64L TLC, on the other hand, reserves only about 27% of the flash as spare and suffers only a slight penalty to steady-state write speeds, and no penalty to rated endurance. (For comparison, consumer SSDs generally reserve 7-12% of their raw capacity for metadata and spare area, and are usually rated for no more than about 1 DWPD.)
You know the single biggest difference between enterprise drives & the lesser rated PRO drives, from someone like Samsung is? Apart from the custom firmware & sometimes different controller ~
If you haven't guessed it already it's overprovisioning!
The first drives that can take advantage of the new features are already shipping to interested parties. The PM1733 and PM1735 are based on a common hardware platform. The PM1733 is rated for 1 DWPD and offers capacities up to 30.72 TB, while the PM1735 has more overprovisioning and lower usable capacities to reach 3 DWPD. Both models are available in either U.2 or PCIe add-in card form factors. The U.2 form factor gives a few more capacity options, while the add-in card versions have a PCIe 4.0 x8 interface to enable 25% higher sequential read performance (for other workloads, PCIe 4.0 x4 is fast enough to not be the bottleneck).
So to summarize ~
A TLC drive, say 1.5TB, can easily last as long if not longer than an MLC, at 1TB, if you keep enough spare room on it. Write amplification is a drive killer & there's something on the horizon ready to address that ~
Used properly, ZNS allows the host software to avoid almost all of the circumstances that would lead to write amplification inside the SSD. Enterprise SSDs commonly use overprovisioning ratios up to 28% (800GB usable per 1024GB of flash on typical 3 DWPD models) and ZNS SSDs can expose almost all of that capacity to the host system without compromising the ability to deliver high sustained write performance.
And before you pivot back to the "TBW" ratings I'll add a couple of points ~
No two drives are the same, with the exact same NAND or even controller+firmware. There are minute differences at the atomic & subatomic levels, then there's entropy. That's an undeniable fact. Which also means that to get to the NAND "endurance" rating that some of you want, Samsung will have to sacrifice on the usable space whether doing more OP or going MLC. So pick your poison.
Lastly the useless back & forth here is like someone having a 3950x & complaining it doesn't do 1000 fps in Doom Eternal. People who can afford the 980 Pro can surely afford an enterprise grade drive, & if you don't know the kind of writes (or WA) your applications/work demands then you're not a PRO! Like I said previously, you can't have it all ~
a drive having chart leading performance, which "lasts" 10 years, is cool to boot & covers itself in glory for everything you throw at it.
28,921 (6.84/day)
Yes, I have and it is a very serious factor in wear leveling.
True! But then that might eat into the profit gains of using TLC over MLC. This depends on the cost of the making the TLC VS the cost of making MLC.
Wasn't going too. You make valid points.
I complete agree with your factual perspectives. The main problem with the cell durability question is a matter of usage model. Heavy usage would indicate the need for a more durable type of storage, lighter usage would make durability a lesser concern.
3,382 (0.60/day)
Czech republic
Processor Ryzen 5800X
Motherboard Asus TUF-Gaming B550-Plus
Cooling Noctua NH-U14S
Memory 32GB G.Skill Trident Z Neo F4-3600C16D-32GTZNC
Video Card(s) Sapphire AMD Radeon RX 7900 XTX Nitro+
Storage HP EX950 512GB + Samsung 970 PRO 1TB
Display(s) Cooler Master GP27Q
Case Fractal Design Define R6 Black
Power Supply Seasonic PRIME Ultra 650W Gold
Mouse Roccat Kone AIMO Remastered
Once the Cache has a size which is bigger then 10 times your normal file size it's kind of academic.
That's a bit like saying my VRAM is not fast because once it's exceeded the system RAM is used.
Possibly, but I hate the concept anyway.
What's the cache on 970 Pro models, anyone knows?
3,923 (0.59/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
