Some GPU questions
vxdiez
4 (0.01/day)
Hi guys!
I hope you can help me choosing my new GPU. Im looking for something that I can keep and can perform well for as many years as possible. I want it to play, pref at 1440p (im getting a new monitor also) and to pair it with a 5600/5600X/5700X CPU.
I have already put my eyes on the RTX 3060ti and the RTX 3070, but im open to new options and I have some questions:
- Is it worth to pay 100€ more for a 3070 before a 3060ti?
- Im worried about the 8gb of VRAM in both cases, do you think that it will be enough for new games in a recent future?
- I have seen a 3070ti for the same price as the 3070, but its a inno3d and I dont know anything about that branch. Do you guys know anything about it? Is it worth to "take the risk" and get it?
As you can see, im a bit lost. Sorry for the long post and thanks in advance!
3x0
974 (1.15/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Lamzu Atlantis Mini Wireless
Keyboard HyperX Alloy Origins Aqua
Consider the RX 6700 XT 12GB as it's very close to the 3060Ti or RX 6800 16GB as it's around 3070Ti performance. They're usually cheaper than nV counterparts depending on the local market, and have more VRAM.
18,584 (2.67/day)
System Name AlderLake
I use a RTX 2070 Super with a 1440p 165Hz G-Sync monitor, works well for me, haven't had any issues yet because of it's 8GB VRAM..
If you live in a country where you can return the product within 30 days , I'd say you're good to go...
1,711 (1.07/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
Some games can already use more than 8 GB VRAM at 1080p with maximum detail. If your target is 1440p in future titles, I'd definitely suggest a card with a bigger frame buffer.
18,584 (2.67/day)
Depends what games you play, and settings ofc...
Which game uses more than 8GB vram @ 1080p?
1,711 (1.07/day)
Forza 5 and Watch Dogs: Legion go over 8 GB even without RT and MSAA:
18,584 (2.67/day)
64K
6,773 (1.70/day)
Processor i7 7700k
Motherboard MSI Z270 SLI Plus
Cooling CM Hyper 212 EVO
Keyboard Logitech G105
Hmm, I play Forza 5 @ 1440p and high/ultra settings with RT on and MSAA x2, 60fps, didn't had any issues yet.
Probably because it doesn't need more than 8 GB VRAM. Some engines allocate more VRAM just because it's there or don't delete old textures from VRAM that aren't needed anymore.
18,584 (2.67/day)
I just checked, I see I don't use MSAA, these are my settings at 1440p, nearly 8GB vram used but at 1440p 60fps for me.
4,814 (0.96/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
inno3d has been around for a while, kind of a no thrills board partner but legit and capable
this, using 8GB and needing 8GB is two different things
1,088 (0.73/day)
Processor E5-4627 v4
Motherboard VEINEDA X99
Memory 32 GB
Video Card(s) 2080 Ti
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
there will be a 4070 12GB at around that price, avoid everything else if you can. But I wouldn't count on it lasting very long. for it's essentially a 4060 class. everything got rebranded one tier higher since 3050-3090.
3x0
974 (1.15/day)
9,651 (3.28/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
That's not really true, I don't know why people keep believing this. If the game allocates some memory it's because it will use it at some point, GPUs swap data in and out of VRAM when they run out of memory just as the rest of the system does, the less memory available there is the more chances there are it's going to have to swap memory which will result in horrendous stutter.
That's not true either, that would be a memory leak which would be catastrophic no matter how much memory there is.
No, especially on an older gen, it's really not gonna matter down the line.
It might matter at higher resolutions, I would not buy a new card with 8GB these days.
It's fine if you can get a 3070ti for the same money then there is no reason not to.
64K
6,773 (1.70/day)
Processor i7 7700k
It is true though. The most extreme example I can recall is Call of Duty: Advanced Warfare reviewed here on TPU. It ran fine on a card with 3 GB VRAM. A member here reported that it was using 11 GB VRAM on his Titan X.
vxdiez
4 (0.01/day)
I would love to thank you all 1 by 1 for your answers :)
Reading all your answers and watching the video @3x0 posted, I think I got my 2 finalists. 3060ti and 6700XT.
- 3060ti (Gigabyte Gaming OC 520€):​
  • PROS:
    • Nvidia Features (DLSS + Drivers)
    • I think Gigabyte is a good branch
  • CONS:
    • 8gb VRAM
    • More expensive (60€ more than the 6700XT)
    • Less FPS (not a lot)
- 6700XT (XFX SPEEDSTER CORE Gaming 460€):​
  • PROS:
    • Cheaper
    • Better performance
    • 12gb VRAM
  • CONS.
    • I dont know a lot about XFX
    • AMD Features + Drivers.
My biggest concern about the 6700XT are the drivers and not having DLSS, I have a friend that recently bought an AMD and he is having some troubles with the drivers update and those things. I have always heard that the NVidia drivers are better and that DLSS is way better than FSR.
With all this in mind, and knowing that im pairing the GPU with a 3600X/3700X CPU and I want to play at 1440p, wich one would you recommend me?
Thanks again for all your help!
3x0
974 (1.15/day)
DLSS is marginally better than FSR 2.0, you won't notice the difference during gameplay unless you pause and look very closely. It all depends what games you play and the specific implementation of DLSS or FSR in that game. As for drivers, most of the trouble is being reported by people running multi monitor setups. They have fixed some of the reported issues but not all.
My choice would be to go for RX6700XT and spend the extra 60e on a better monitor if possible than the one you were planning on buying.
1,046 (0.60/day)
System Name S.L.I + RTX research rig
Processor Ryzen 7 5800X 3D.
Motherboard MSI MEG ACE X570
Cooling Corsair H150i Cappellx
Memory Corsair Vengeance pro RGB 3200mhz 32Gbs
Video Card(s) 2x Dell RTX 2080 Ti in S.L.I
Storage Western digital Sata 6.0 SDD 500gb + fanxiang S660 4TB PCIe 4.0 NVMe M.2
Display(s) HP X24i
Case Corsair 7000D Airflow
Power Supply EVGA G+1600watts
Mouse Corsair Scimitar
Keyboard Cosair K55 Pro RGB
he included "raytracing as an other Nvidia excluisive" feature.
It is not an "Nvidia exclusive feature" it's a "DX12 feature". RTX has ruined the thought raytracing being part of the DX12 A.P.I.
3x0
974 (1.15/day)
He said "even when factoring raytracing performance and other nVidia exclusive features", not that raytracing is nV exclusive.
10,945 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 1:1 CL30-36-36-96 FCLK 2000
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply RIP Corsair SF750... Waiting for SF1000
Keyboard 65% HE Keyboard
I want FSR to be good, but when I try it it's pretty bad in everything except cyberpunk (that implementation is quite good now).
Out of the 4 games that have FSR - 3 are basically unusable and 1 is great.
6700XT still slaps for the money though, I recommend that card in almost all scenarios below $600.
1,088 (0.73/day)
Memory 32 GB
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
You don't catch the drift of the video. None of the choices are good, the best value Nvidia is still stuck at 2 year old MSRP, this is a terrible value indeed. but if you really really need a card get a 6600.
1,775 (1.00/day)
Over the Hill UK
System Name AMDWeapon
Case Montech 903 MAX AIR
VR HMD -
Software Windows 11 Pro 24H2
I've never used FSR, despite having AMD. Don't see it as being necessary to be honest. I'd recommend the 6700/XT too.
vxdiez
4 (0.01/day)
Well guys, a new player has come to the game xD
I was waiting because I was choosing the other components of my new PC, and today I've seen a RX6800 for 550€ (90€ more expensive than the 6700XT. Do you think that it is worth those 90€?
Here is the link of the 6800, it is in Spanish, so maybe you dont understand anything, or maybe you can translate it. Do you see anything particular about that GPU?
Edit: added link
3x0
974 (1.15/day)
For 20% more money (460 vs 550) you get ~25% more performance. I don't see the link, so I don't know which model exactly are you referring to
tabascosauz
8,209 (2.34/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
If you want a GPU you can stick with, the other GPUs choices don't even come close to the RX6800. Basically a slightly faster 3070 Ti that doesn't have to worry about VRAM in the future (which is what the 3070 Ti should have been). Barring the current controversy about the December drivers (and no one knows the true cause), RX6000 drivers are mature enough at this time that Nvidia "driver advantage" doesn't mean much.
550EUR seems roughly around the price where I last saw RX6800 here in Canada. Doesn't seem like a screaming deal, but 6800/6800XT/6900XT/6950XT have been disappearing from the market.
I'd pick up a 6800 in a heartbeat over the 3060Ti/3070/3070Ti or 6700XT/6750XT.
2,980 (2.05/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
no.
yes.
yes.
