- Apr 16, 2022
- 35 (0.04/day)
Processor | AMD Ryzen 9 7900X3D |
Motherboard | ASUS ROG Strix B650E-E Gaming |
Cooling | ASUS ROG Strix LC III 360 |
Memory | G.Skill 48GB(2x24) TZ5 Neo RGB EXPO 6400mhz CL32 |
Video Card(s) | ASUS TUF RTX4070TI SUPER |
Storage | Adata XPG SX8200 Pro 2X2TB, Adata XPG SX8100 2X2TB, |
Display(s) | Dell 34" Curved Gaming Monitor S3422DWG |
Case | Corsair 5000X |
Power Supply | Corsair RM1000x SHIFT 80 PLUS Gold |
Mouse | Asus ROG Gladius II Core |
Keyboard | Asus ROG Strix Scope |
I don't know what quality the DAC in my monitor is. But I had another monitor in the past and used it for a while. It was not bad.I just use bluetooth speakers or USB gaming headset and never had a problem with audio.
Sound from my monitor (through 3.5mm jack) sourced from DP or HDMI as worked well for me using AMD cards but I guess this also depends on your monitor and the quality of the connection with the jack.
I found two DACs on second hand now.
Creative Soundblaster G6 and X4.
They seem to be reasonably priced and are clean products. I think I will choose one of these. If the firmware update doesn't fix my problem.
Thank you very much for your help.The G6 is well regarded as a portable DAC, and should work on your PC. The X4 is pretty good as well, and even more suitable for desktop use. Whichever you choose, I reckon you will be satisfied. Between those two, I would go for the X4. Good luck!
Now first I will try to update the firmware.
If the sound cracks still occur then I will buy one of these two DACs.
X4 seems better to me too. At least since I am using a desktop computer.
When making the DAC connection, can I disable the motherboard's built-in sound card from the BIOS? First I will remove the drivers from the system. Then I will turn off the sound card from the BIOS. Then I will connect the DAC and install it, I guess.
I have never installed a DAC before.
In fact, the last time I used a sound card was in June 1999. I had a Soundblaster sound card from Creative. I bought it with a CD drive. I was using it with a Pentium III 650 and a Gigabyte BX2000+ motherboard.
I have never bought a sound card in 25 years. Until the ALC4080
I did most of these steps.In essence it appears there are multiple issues of which audio is probably the hardest to ignore and most impacted. Strong reasoning exists to suspect the Asus mobo is especially prone towards amplifying or creating conditions for this to occur.
At it's core this is an enthusiast site where rebuilding and reconfiguring systems is considered fun. In no arranged order here are some good ideas.
1. Try another wall outlet. Or another wall outlet with a known functional powerstrip/UPS. Taking PC to a friend or relatives is also a good test.
2. You or someone you know proficiently using a multimeter to test everything from the wall outlet outwards. No programs, highly inaccurate and rely on inaccurate info.
3. Spend money on the solution you feel has the best chance of producing results.
4. If available try another PSU with your PC or a different PC in the immediate area of where yours is located.
5. Education. Example: ASIO audio driver traits versus typical audio drivers. One might even be present and unused on your mobo.
6. Digital audio programs/players can have a large effect by assessing and attempting to correct issues within the sphere intelligently programmed software can impact.
7. Completely disassemble and rebuild the system. Clean everything, examine everything, carefully insert everything back into place.
But then I realized that ASUS has published patches on their websites for different motherboards that use the same audio chip. But for some reason they didn't put them on the website for the motherboard I'm using, even though it's the same chip.
I found a firmware fix. I'll try it.
If it fixes the problem, which I hope it does, then it's fine.
But if it doesn't, then I'll get a DAC.
