Swiftech Withdraws H220 CPU Liquid Cooling Kit from US Market
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Here's where we're going to have to differentiate opinions on the matter.
Asetek has filed a patent that is basically applicable to any closed loop heat transfer system. You're looking at a patent from a computer hardware focused company, and only seeing that one application.
In reality, houses can use a system of tubes beneath the flooring for heating and cooling. A heat transfer segment, with an integrated pump, can push the heated or cooled liquid out and into the tubes. The tubes then transfer a portion of their heat into the surroundings. These systems have been around in high-end houses and building for decades.
Now, tell me that Asetek has a case. A patentable system must demonstrate that it is a unique solution, and not a trivial combination of existing components.
So, Swiftech is doing the only sensible thing. They are forgoing the huge money pit that this litigation will cost. They are pulling the product that they think might be the source of this litigation, and they are changing their aims.
I cannot call this trolling, because it isn't. I'm calling this a crappy patent, that should never have been approved by the US patent system. Because it would take a law suit to challenge this, Swiftech is backing down. They cannot afford the litigation, but hopefully someone else will.
As far as not suing for other products, just wait. Rarely do companies stop when something is proven viable. If one lawsuit threat stops the AIO competitors, another could well kill the custom loop makers. Who's to say that Asetek won't be designing these systems in the near future? I prefer to allow action to speak, and Asetek's licensing refusal speaks volumes about their intents.
Edit:
Let's clarify one more thing. If you were to spend 20 minutes, and remove all references to CPU and computer what do you have? A patent for a generic closed loop heat transfer system, where the pump happens to be integrated with one of the heat transfer surfaces. I could make the same claims about any car radiator, home heating/cooling system, and the environmental water heating systems used in houses (black sacks on the roof absorb solar energy, heat water, then the heated water is used in the house).
This indicates that the patent was improperly awarded, and any judge presented with it should invalidate it for not meeting basic requirements. If the US patent office was competent and well staffed this crap never would have been given out in the first place.
You went and typed all that out and it was a complete waste. You're still trying to argue based on the assumption they are suing over AOI cooling systems, they aren't. They are suing about the individual, unigue, parts that they developed and patented. I swear I read somewhere that it was the pump/block combo, but BTA said it was the rotating fitting. Either way, they aren't suing simply because they threw a bunch of pre-existing parts together into a system and patented the system. Parts of the system didn't exist before they developed them, that is why they have a valid claim, and these unique parts in the patent are what they are trying to prevent other companies from using.
And if you spend 20 minutes removing CPU and computer, you still have a patent on the pump/block combo and 180° rotating fittings, both of which as far as anyone can tell didn't exists before Asetek developed them. Both of these things are innovative ideas that seem to be unique, no patent judge would invalidate the patent on these.
4,213 (0.71/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
The patent in question covers that L-shaped fitting on the block/pump, which can turn around 180° while remaining watertight.
"The two patents are intrinsically related: the latter was filed back in 2010, while the former revised the design of the system to better reflect the state of the art when it was filed in 2011. Both include reference to the use of a liquid-cooling system connected to a pump and radiator, designed to be fully integrated into a single maintenance-free design - and if you think that sounds a little broad, you might be right given that the patents encompass 'different embodiments of the heat exchanging system as well as means for establishing and controlling a flow of cooling liquid.'"
and
"The patent in question, publication number US 2012/0061058 (PDF warning), describes 'a cooling system for a computer system [...] comprising a reservoir having an amount of cooling liquid, said cooling liquid intended for accumulating and transferring the thermal energy dissipated from the processing unit to the cooling liquid. The cooling system has a heat exchange interface for providing thermal contact between the processing unit and the cooling liquid for dissipating heat from the processing unit to the cooling liquid.'"
- http://www.bit-tech.net/news/hardware/2013/03/11/asetek-sues-cm/1
- http://www.bit-tech.net/news/hardware/2012/08/31/astek-sues-coolit/1
I haven't read anything about the L-Shaped fitting. But, I have yet to find a well-written (neutral) article on the matter.
2,866 (0.57/day)
What?
Neither patent 362 or 764 make mention of that component. The diagrams provided in the patent filing don't even include provisions for that fitting.
Are you seeing something that I am missing? If so, please point it out so I can understand where you're coming from.
Don't go by what you read, do the reading. Here is the article the other thread linked to, from Swiftech: http://www.swiftech.com/pr-7-19-13-h220-removedfromus.aspx
Their two filings don't make mention of a fitting. What they are (and they're really one filing later updated to reflect the changing reality) is an attempt to make a pump, radiator, block system into a two component system. This is clear as day if you look at the pictures.
My argument is that this is not a novel approach or idea. It's a logical progression. They took a pump, relocated it in the cooling loop, and tried to patent it. The structure of the pump could likely be patented, assuming that the pump worked in some novel way. That is not well defined in the patent.
I am all for patents protecting unique ideas. Asetek likely spent a good chunk of money in designing the system, which was an engineering challenge. What it was not is a novel idea. The purpose of a patent, hopefully we both agree on this, is to protect novel ideas not engineering investments.
As far as the 180 degree bracket, that should be patentable. It is a unique design, that is not a trivial design change. Assuming that is buried in the patent somewhere deep, Asetek has a winner. The problem is that unique idea should have a patent, not the heat change system that is incorported around it.
Neither cited patent from Swiftech covers the bracket, so I don't know how that conclusion has been reached. If there is something other than the press release cited, please do provide it. I'd be happy to be wrong if why I am wrong could be cited, rather than conjectured at.
4,213 (0.71/day)
Vietnam
The pump block combo's original drawing uses Socket 478 mounting, its been in there for a while...
Edit: This is the original patent filed in 2004. It clearly has the pump/block combo in it.
http://www.google.com/patents/EP1923771A1
I just read through this.
It appears to be the original patent + the 2008 update.
Does the unedited 2004 patent contain a water block + pump combination. If not, then it should not even have been considered for a patent due to prior art.
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
You can't use the logic that someone would have thought to do it eventually to invalidate a patent. That is true of most patents. The fact is no one had thought of combining the pump and block before Asetek, it was a unique idea, and patenting it is a valid thing to do.
Tons of patents are just someone taking something and improving it in a new way that no one else thought of, that is the definition of innovation.
Does the unedited 2004 patent contain a water block + pump combination. If not, then it should not even have been considered for a patent due to it being existing technology.
You can read the original on the USPTO website here. I can't get the image to work, but the descriptions of the figures still match, so it appears that yes the pump/block combo was in the original 2004 filing.
Again, the original art shows 478 mounting hardware, that should give you an idea of how old these drawing are, 775 replaced 478 in 2004 and 478 was pretty much off the market by 2005.
4,213 (0.71/day)
Vietnam
As the patent also mentions a separate res, block, pump and radiator system, I am dubious as to the scrutiny the patent was given. It seems like a patent for a 'pre-assembled' water cooling solution.
We'll see what a judge says at the outcome though. It's a lot of text to read for a Sunday afternoon so I will reserve judgement until a judge rules on it or I see a proper write up on the issue.
Edit - I got the image from the original it appears it was issued in 2005.
2,558 (0.45/day)
United States
System Name Aluminum Mallard
Processor Ryzen 1900x
Motherboard AsRock Phantom 6
Cooling AIO
Memory 32GB
Video Card(s) EVGA 3080Ti FTW
Storage SSD
Display(s) Benq Zowie
Case Cosmos 1000
Power Supply Corsair CX750
VR HMD HTV Vive, Valve Index
Software Arch Linux
Benchmark Scores 31 FPS in Dalaran
Only read the first page here, so here I go.
Asetek is clearly in the right in demanding licensing fees for their intellectual property. Asetek clearly doesn't meet the requirement of being a patent troll. They actually manufacture AIO units. They invented the pump/block, they patented it at the very least, so it's their property.
Swiftech, etc. should immediately begin the process of license fee negotiations. If Asetek won't license it, then they are dicks, lol.
Mindweaver
Moderato®™
8,329 (1.45/day)
Charleston, SC
System Name Tower of Power / Delliverance
Processor i7 14700K / i9-14900K
Motherboard ASUS ROG Strix Z690-A Gaming WiFi D4 / Z690
Cooling CM MasterLiquid ML360 Mirror ARGB Close-Loop AIO / Air
Memory CORSAIR Vengeance LPX 32GB (2 x 16GB) DDR4 3600 / DDR5 2x 16gb
Video Card(s) ASUS TUF Gaming GeForce RTX 4070 Ti / GeForce RTX 4080
Storage 4x Samsung 980 Pro 1TB M.2, 2x Crucial 1TB SSD / NVM3 PC801 SK hynix 1TB
Display(s) Samsung 32" Odyssy G5 Gaming 144hz 1440p, 2x LG HDR 32" 60hz 4k / 2x LG HDR 32" 60hz 4k
Case Phantek "400A" / Dell XPS 8960
Audio Device(s) Realtek ALC4080 / Sound Blaster X1
Power Supply Corsair RM Series RM750 / 750w
Mouse Razer Deathadder V3 Hyperspeed Wireless / Glorious Gaming Model O 2 Wireless
Keyboard Glorious GMMK with box-white switches / Keychron K6 pro with blue swithes
VR HMD Quest 3 (512gb) + Rift S + HTC Vive + DK1
Software Windows 11 Pro x64 / Windows 11 Pro x64
Benchmark Scores Yes
Wow.. Just when I was going to pull the trigger on one of these units..
2,866 (0.57/day)
Answer me this question, then either agree to the absurdity or continue with an argument that is untenable.
Tomorrow I am going to file a patent. This patent will be based off of an initially three component system; a pump, a radiator, and a heat transfer surface. Instead of three unique components, I will combine all three into one. It will have the heat transfer surface on the bottom, the pump integrated above that, a flow through a finned radiator, then a series of pipes taking the cooled fluid back down into the heat transfer surface.
The unit itself will look very similar to a conventional large air cooler, with an extra large base.
I am taking three things that were once separate, and combining them into a single device. By your logic, this is patentable. On top of the patent issued to me, I can sue pretty much everyone. I will argue that the competitive options may use a large loop, but selling all three things together violates my patent.
Please, argue that what I am saying is wrong. Argue that this is somehow a derivative work, and it would never get a patent. My argument is that Asetek already has a similar patent. That is the problem I've got. They got a patent for something that should never have been issued a patent. The connectors can reasonably be patented. The pumps, depending upon operational methodology, can be patented. Bolting two existing components together is not novel or unique, and thus should not have been patentable.
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
http://img.techpowerup.org/130721/Untitled.png
Patents can cover a lot of technology, they do not have to focus on one item. You do not have to patent every individual part. If you patent a system that contains unique parts, then the unique parts are patented as well.
Sure, its patentable, but you couldn't sue everyone. They already have prior art. Your concept would improve upon it, compacting the design, and would likely require some pretty nifty engineering to make into on unit that can hang off a CPU socket. You would get the patent, and that engineering that you did would be protected, but you couldn't sue everyone that makes AIO coolers.
You want a perfect example of how the patent system allows people to take something an innovate it just look at barbed wire. There are literally thousands of patents for barbed wire were someone took the original design and just tweaked it. Moved the barbs closer, changed the barb design, changed the material it is made from. Barbed wire was original made of wire, someone decided to make it out of stamped razor thin metal and patented that. Then someone came along and figured out if you run a reinforcing wire down the middle of the stamped metal it worked better, he combined the two previous concept into one and patented that. It was still a patent for barbed wire, but the idea of combining the wire and stamped metal was something no one else had thought to do, and hence was patentable. However, he couldn't go back and sue everyone else that was making barbed wire out of just wire or just stamped metal.
That is why Asetek isn't suing everyone selling closed water loops. If the pump is separate or contained in the res or radiator, they aren't suing them, because they know they really can't.
Also, you'd think combing different parts of a system would be logical and easy to do. But, ironically, Swiftech tried combining the pump with the radiator, they even patented it so no one else could do it. It doesn't work nearly as well as combining the pump with the waterblock. Thee reason is that a lot of people put the radiator at the top of the case, the highest point in the case. So when the fluid gets a little low the pump begins sucking air in this situation. However, putting the pump on the waterblock greatly reduces the likelihood of the pump sucking air.
2,866 (0.57/day)
This argument is getting us nowhere. I concede that you have some reasonable points, but the truth is both of our ideas mean little. Going to court is the only way this is going to be solved, and lawyers don't run on logic.
With that, I concede. Continued point and counterpoint doesn't serve either of us.
cdawall
where the hell are my stars
27,683 (4.10/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
Ultra sold that 5-6 years ago and its already been patented.
432 (0.09/day)
Processor Intel i9-9900k @ 5GHz
Motherboard Gigabyte Z390 Aorus Pro Wifi
Cooling ThermalTake Riing 240
Memory 2x8GB G-Skill 3600 CL19 @ 16-19-19-20
Video Card(s) Zotac RTX 2060 Amp!
Storage 2x Samsung 860 Evo 512GB, 4x Seagate 8TB
Display(s) 2x Dell U2713H
Case CoolerMaster M500P
Power Supply ThermalTake Toughpower 730W
Just about every complex machine is about bolting two or more existing, simpler components together. If we can't patent based on that logic, then by all rights we shouldn't be able to patent anything at all.
283 (0.05/day)
Honky Tonk Nashville, TN
If Asetek even wins against any of the others, it will fail due to the prior Apple G5 LCS that uses the Panasonic pump+block combo. The time Asetek was even fileing for the patents, Panasonic was already in production.
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
The Panasonic system didn't use a pump/block combo, the pump was separate from the blocks.
4,213 (0.71/day)
Vietnam
It looks like the pump and block are together. Along with the radiator, that is.x
637 (0.10/day)
Canada
System Name Tahiti Treat
Processor i7 4770K @ 4500MHz
Motherboard Asus Maximus VI Hero
Cooling Custom H20
Memory Patriot Viper 8GB @ 1866MHz
Video Card(s) 2X Sapphire 7870XT (Tahiti Core) @ 1150/1500 CrossFire
Storage 2 x Intel 120GB 520 Series SSD Raid0 # 2x Seagate 1TB Raid0 # 1 WD 2TB EARS
Display(s) 3 x 22" Eyefinity
Case Cosmos S Custom
Audio Device(s) Asus X-FI
Power Supply Corsair AX860i
Software Win7 64Bit Ultimate
Benchmark Scores http://www.3dmark.com/3dm11/6848547
looks very heavy
Norton
Moderator - Returning from the Darkness
14,108 (2.95/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
http://img.techpowerup.org/130722/kuehlblock.jpg
I owned one of these, look at it from a different angle, the pump is clearly completely separate from the waterblocks. In fact, anyone into watercooling will recognize the pump they used.;)
Here's another one:
http://img.techpowerup.org/130722/Xig AIO.jpg
XIGMATEK AIO-S80DP
*EDIT- Here's an Easter Egg- click Xigmatek's product page for this :laugh:
http://www.xigmatek.com/product/liquid-aios80dp.php
True, but that came out in 2007, long after Asetek's patent, and the pump was still technically a separate unit from the block.
cdawall
27,683 (4.10/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
Its a ddc1t with the noise isolator block at the bottom. I had one myself.
Deleted member 24505
I'd like to find one of them in a market for a tenner :p
4,213 (0.71/day)
Vietnam
http://www.the620guy.com/Images/ebay/2011-08-15/Apple G5 Dual 2-7GHz 512K 5.JPG
Couldn't it be argues that as they are bolted together, it is essentially a single unit rather than separate pieces? The tech in the swiftech units does seem different as in the pump has been opened at the bottom and had the waterblock bolted on, but is it a big enough difference?
The meat of their patent seems to cover any type of integrated heatsink, block (+rad), can certain aspects of a patent be invalidated whilst keeping the individual components intact?
johnspack
Here For Good!
6,047 (0.96/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 1x27" 1440 display 1x 24" 1080 display
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Win11 Ent 24h2
Benchmark Scores It's linux baby!
Having a hard time getting this... aren't all closed loop cooling systems pretty much the same darn thing? Weird.....
474 (0.10/day)
Processor i5-13500
Motherboard MSI MAG B760 Tomahawk WiFi DDR4
Cooling Thermalright Peerless Assassin 120 White
Memory Corsair Vengeance LPX 4x8GB 3200
Video Card(s) EVGA RTX3060 12GB
Storage 250GB NVME (main) 1TB SSD (Game) 1TB HDD (Storage) 2TB HDD (ext Backup)
Display(s) Benq 27" GW2765 + Asus 27" VE278 + 55" Hisense
Case Cougar MX600 White
Audio Device(s) Audiotrack Prodigy Cube DAC + Edifer S330D + Plantronics RIG 400
Power Supply Corsair AX760
Mouse Logitech G403 Hero
Keyboard EVGA Z15 Brown Tactile (Blue Oring, Lube, Silence Pad)
Yes they are, Swiftech H220 and CM Eisberg is not a closed loop. They are watercooling kits, that is pre-built for your convenience.
This is basically gone too far in my books by Asetek. I see the reason to sue Coolit, which is a copy of theirs.
But Swiftech I do not see it, when they been doing this for so long.
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
Being bolted together into a single functioning system is different then making them one solid unit. If you can pull a piece out and the piece still works as it is intended, then it is still technically a separate part. In Asetek's case, the waterblock becomes part of the pump and the pump becomes part of the waterblock, the two will not function separately.
And yes, patent judges can pick apart patents invalidating some parts while upholding others.
This isn't about closed loop coolers, it is about the pump/block combo(and maybe the special fittings).
