Swiftech Withdraws H220 CPU Liquid Cooling Kit from US Market
891 (0.19/day)
US
Processor AMD Ryzen 5 1600X
Cooling Corsair H60 Liquid Cooling
Memory 16 GB CORSAIR Vengeance LPX 3000 Mhz (Running at 2933)
Video Card(s) EVGA FTW2 GTX 1070Ti
Storage 740GB of SSDs, 7 TB's of HDDs
Display(s) LG 27UD58P-B 27” IPS 4K
Case Phanteks Enthos Pro M
Audio Device(s) Integrated
Power Supply EVGA 750 P2
Mouse Mionix Naos 8200
Keyboard G Skill Ripjaws RGB Mechanical Keyboard
Why can't everybody just get along?
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Because it sucks to spend time developing an idea only to have another company rip the idea off and sell it as their own.
474 (0.10/day)
Processor i5-13500
Motherboard MSI MAG B760 Tomahawk WiFi DDR4
Cooling Thermalright Peerless Assassin 120 White
Memory Corsair Vengeance LPX 4x8GB 3200
Video Card(s) EVGA RTX3060 12GB
Storage 250GB NVME (main) 1TB SSD (Game) 1TB HDD (Storage) 2TB HDD (ext Backup)
Display(s) Benq 27" GW2765 + Asus 27" VE278 + 55" Hisense
Case Cougar MX600 White
Audio Device(s) Audiotrack Prodigy Cube DAC + Edifer S330D + Plantronics RIG 400
Power Supply Corsair AX760
Mouse Logitech G403 Hero
Keyboard EVGA Z15 Brown Tactile (Blue Oring, Lube, Silence Pad)
I never said it was about close loops coolers.
4,013 (0.71/day)
Swiftech's pump system is vastly superior to Asetek's, and their block is only similar in the fact that it is copper. Following the whole pump/block patent theory would be like Yugo suing Lamborghini because they put a motor in a car chassis.
43,615 (6.45/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Must especially suck when the other company makes a vastly superior product too.
432 (0.09/day)
Processor Intel i9-9900k @ 5GHz
Motherboard Gigabyte Z390 Aorus Pro Wifi
Cooling ThermalTake Riing 240
Memory 2x8GB G-Skill 3600 CL19 @ 16-19-19-20
Video Card(s) Zotac RTX 2060 Amp!
Storage 2x Samsung 860 Evo 512GB, 4x Seagate 8TB
Display(s) 2x Dell U2713H
Case CoolerMaster M500P
Power Supply ThermalTake Toughpower 730W
Didn't this happen way back in 1905 with Springfield and Mauser? From what I've read about it the US paid royalties to the tune of $200,000 when they found that the M1903 infringed on seven of Mauser's patents.
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
What exactly do you mean by "vastly superior"? The Asetek built H110 hands the H220 its ass performance wise. The only thing "superior" is the BS customization, which basically defeats the point of an AIO.
Frick
Fishfaced Nincompoop
19,758 (2.86/day)
w
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
^ is that the best review you can find?
Reviewing coolers isn't difficult, as long as all coolers are tested in the same way, which I'm pretty sure is the case at Anandtech.
4,013 (0.71/day)
http://images.anandtech.com/graphs/graph6716/52896.png
Umm, the H100 is a 280mm rad compared to the H220s 240mm, so yeah, it gets a few degrees, not exactly an ass whooping. The true comparison would be the H100i with it's similar radiator, which doesn't perform as well or as quiet. Thanks for the chart, though.
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
Except the H100i isn't made by Asetek.
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
Then why isn't it on the chopping block as well?
CoolIT products are on the chopping block, CoolIT and Asetek are in a legal battle over the issue.
That wasn't the point of the post, anyhow, which you conveniently didn't respond to.
You're absolutely right, a true comparison would be the H100 vs H220 with the same fans, but I couldn't find any respected reviews comparing the two.
4,013 (0.71/day)
Fair enough:)
I'm hoping that a solution is found that works out for all manufacturers involved, not only for their sake, but also the consumer's.
2,373 (0.57/day)
Audio Device(s) A LOT
MartinsLiquidLab did one with the h100i. http://martinsliquidlab.org/2013/03/13/corsair-hydro-series-h100i-aio-cpu-cooler/9/
That said, the Corsair AIOs are not really comparable to the h220. The h220 has a superior pump in every regard - way quieter, much more flow. It is also expandable, in that you can use it to cool your GPUs or any other component you can find a block for. It also comes with much, much better fans.
43,615 (6.45/day)
That said, the Corsair AIOs are not really comparable to the h220. The h220 has a superior pump in every regard - way quieter, more flow. It is also expandable, in that you can use it to cool your GPUs or any other component you can find a block for. It is also comes with much, much better fans.
Indeed. The Swiftech h220 is by far the superior product for all of the AIO water coolers. Which makes sense as to why they were first on the chopping block. Swiftech now just needs to do better advertising with their kit that is the same thing as the AIO h220, just not assembled.
2,516 (0.47/day)
Canada
10,242 (1.45/day)
Granite Bay, CA
System Name Big Devil
Processor Intel Core i5-2500K
Motherboard ECS P67H2-A2
Cooling XSPC Rasa | Black Ice GT Stealth 240 | XSPC X2O 750 | 2x ACF12PWM | PrimoChill White 7/16"
Memory 2x4GB Corsair Vengeance LP Arctic White 1600MHz CL9
Video Card(s) EVGA GTX 780 ACX SC
Storage Intel 520 Series 180GB + WD 1TB Blue
Display(s) HP ZR30W 30" 2650x1600 IPS
Case Corsair 600T SE
Audio Device(s) Xonar Essence STX | Sennheisser PC350 "Hero" Modded | Corsair SP2500
Power Supply ABS SL 1050W (Enermax Revolution Rebadge)
Software Windows 8.1 x64 Pro w/ Media Center
Benchmark Scores Ducky Year of the Snake w/ Cherry MX Browns & Year of the Tiger PBT Keycaps | Razer Deathadder Black
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
I'm pretty sure CoolIT was sued first, Swiftech is just the first to give up and actually pull products.
2 (0.00/day)
spikey27
Although Asetek's response said they did not offer such licensing, I believe the opposite to be true. Visit their site, and others using their technology, and decide for yourself.
Numerous posts herein suggest Asetek is protecting their interests. I totally disagree - what they're doing is using their patent (validity not yet determined) and the threat of a lawsuit related thereto, to eliminate their strongest competition who likely has the best product through intimidation.
I hope somebody has the fortitude to destroy their patents.
For starters, I don't believe Asetek had the first such product. I suspect someone else (CoolerMaster?) had something which serves as apriori.
My 2cents worth.
