Threadripper 3970X set up.
4,461 (1.41/day)
Currently Norway
System Name Bro2
Processor Ryzen 5800X
Cooling Corsair h115i pro rgb
Case Fractal Design G
Audio Device(s) Realtec 5.1
Mouse Logitech G402
Keyboard Logitech slim
Software Windows 10 64 bit
Hi everybody.
I'm getting two Threadrippers 3970X and just wanted to ask, what you guys think of the components? Would you have changed something or maybe you have inputs that may be useful for me?
Components.
Chieftec UNC-410S-B-U3
Noctua U14s TR4 sp3
Corsair Vengeance LPX DDR4 3600Mhz 4x16 CL18 XMP
Asus Prime TRX40-PRO
Corsair AX850
Rx 5500XT 4GB
SSD Smasung 970 PRO 1TB
HDD WD GOLD Enterprise 4TB
This is what I got. Any thought?
6,142 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
What about cooling? 3970x does not come with box cooler.
That corsair ram kit might cause some problems.
7,374 (3.18/day)
California
System Name His & Hers
Storage lots of SSD.
If you're in the states newegg has the strix $150 off with the purchase of a CPU for the next 70 hours.
Otherwise cooling is very important with open loop cooling probably being ideal.
4,461 (1.41/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
Right. Added in the list.
Thanks
I'm going with air although I'm considering liquid. Maybe I will try air and see how it goes and if necessary I will slap liquid on these 3970X's
555 (0.16/day)
In the middle of nowhere
System Name Scrapped Parts, Unite !
Processor Ryzen 5 3600 @4.0 Ghz
Motherboard MSI B450-A Pro MAX
Cooling Stock
Memory Team Group Elite 16 GB 3133Mhz
Video Card(s) Colorful iGame GeForce GTX1060 Vulcan U 6G
Storage Hitachi 500 GB, Sony 1TB, KINGSTON 400A 120GB // Samsung 160 GB
Display(s) HP 2009f
Case Xigmatek Asgard Pro // Cooler Master Centurion 5
Power Supply OCZ ModXStream Pro 500 W
Mouse Logitech G102
Benchmark Scores Minesweeper 30fps, Tetris 40 fps, with overheated CPU and GPU
just out of curiousity, why would you use RX 5500 XT in 4000+ dollar system?
4,461 (1.41/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
Well, I still have to use a GPU right? Are you suggesting that since it is a $4k+ I need to use what?
8,223 (2.14/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
5700XT over a 5500
4,461 (1.41/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
6,142 (2.85/day)
Poland
7,374 (3.18/day)
California
Why 5700XT ? If this TR had an iGPU I wouldnt even bother
Much better to use the budget towards cooling/memory/storage.
4,461 (1.41/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
Obviously he'll be gaming on his 3970x...
Yes yes. I will definitely play games on it :p
I been thinking and looking over at Guru3D review and I'm concerned about the temps. 3970x with 240mm Enermax LXS showed 85c when stressed with WPrime. Damn, maybe I should go liquid no questions asked. I'm reading articles and searching for strict answer but can't find anything about aircooled 3970X. How will it perform etc.
It will still be locked in a rack in an air-conditioned room so that should keep it cool enough I suppose.
6,142 (2.85/day)
Poland
I don't have the exact numbers but search on reddit, people posted their results with noctua. Either way AMD pretty much puts "use premium liquid cooler with 3970x" on their website.
4,461 (1.41/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
Yeah I've read some comments and the opinions differ. I will have to check this one myself. If anything I will get liquid as of now it will have to stay air.
7,374 (3.18/day)
California
I really like techspots temperature information because they run a blender load for an hour.
Open loop hit 70c
360 aio hit 74C
84c for the garbage wraith ripper
Given this a high end noctua cooler should only be slightly worse than the 360 aio at most. I would be looking for a dual tower variant if they have one though.
Keep in mind this was likely done on an open test bench. In case temps will likely be 3-7c warmer depending on airflow and ambient.
8,223 (2.14/day)
SE Michigan
System Name Dumbass
not too many air coolers can handle 250-275 watt TDP, but there are a couple.
theonedub
habe fidem
8,027 (1.40/day)
Northern CA, USA
System Name Erakith || AsRock NUCS
Processor AMD ThreadRipper 2990WX ES (32c/64t 3.5ghz@1.02v) || Intel i7 1360P Raptor Lake-P
Motherboard MSI X399 MEG Creation || AsRock OE
Cooling EK Supremacy TR4 Full Nickel, D5 w/ EK Top, 2X EK-CoolStream XTX 360 & Photon 270 Res || OE
Memory 32GB (4x8GB) Corsair Vengeance PRO RGB DDR4 3000|| 2x16GB Corsair DDR4
Video Card(s) Vega 64 EK FC|| Intel Iris Xe
Storage 250gb WD Black NVMe & (2) 2TB Intel 660p NVMe || 2TB Corsair MP600 Pro
Display(s) 34" Dell Ultrasharp U3415W
Software Windows 10 Pro x64 || WIndows 11 Pro x64
Wouldn't recommend air-cooling a Threadripper. Do some sort of water, bare min 360 AIO.
3,820 (0.74/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
3970x actually games incredibly well as good as any cpu out there.
That said, I don't quite get the purpose of this build/s. Rack cases... but with cpus that perform best under water. And aircooling inside a rack case is not a good idea especially with no crazy Deltas in sight, oh there is air conditioning. Those Sammy m.2 are only gen3.
What will be the use case for this setup?
4,461 (1.41/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
I know. I been looking over and it will just clock dwon to maintain the temp. I will have to look at the temp and the performance and see if it is up my alley.
But i will have it in a rack and arcon so i think it will be ok ?
That said, I don't quite get the purpose of this build/s. Rack cases... but with cpus that perform best under water. And air-cooling inside a rack case is not a good idea especially with no crazy Deltas in sight, oh there is air conditioning. Those Sammy m.2 are only gen3.
Not gaming. I must have put this in the title for the confusion some people are getting. :/ damn didn't know it will be so much confusing
Open loop hit 70c
360 aio hit 74C
do you ? I know it will clock down (temperature constraints) and I have to make my case with the performance.
I just don't want to damage it and I'm going for two more after this set up pans out.
Tatty_Two
Gone Fishing
25,955 (3.74/day)
Worcestershire, UK
Software Win 11 Home x64
4,461 (1.41/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
3,820 (0.74/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
But you talk liquid. I'm seriously getting the impression that air is for breathing not cooling this thing :/
You can do air but its not recommended. Granted if you do use air the cpu will not perform as its intended, ie. throttled all the time.
4,461 (1.41/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
Yeah. Well I've ordered already. This is my trial run with the two on air. I can always go liquid. Maybe I should have done that at a start :)
I will upgrade if anything. I will see how it goes :)
Thanks
3,719 (1.89/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 200W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2605), upgraded from Win10 to Win11 on Jan 2024
Cooling is a major factor for all ZEN2 CPU performance. 10C reduction to all core boost could mean 50~100MHz more clock. On a 6 core CPU like mine this is almost insignificant, but on 32 cores is a lot performance gain/loss.
250+Watt is for water really. Air towers must dissipate all that heat in case and then case cooling must throw that out. Can’t be sufficient as a radiator throwing that heat directly out of case. Let alone the cooling capacity of each cooler.
TIM material also play high role to heat transfer and dissipation, because of the density of these chiplets/dies.
4,461 (1.41/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
Here are the "twins". Still waiting for some stuff but more less that is how it looks.
2,034 (0.33/day)
Processor RyZen R9 3950X
Video Card(s) RTX 3050
Storage Samsung 2TB SSD
Case Zulman MS800
Audio Device(s) On Board
Power Supply Seasonic 650W
Software Windows 11 64bit
very nice indeed,....
To be honest though, I don’t quite see how typical water cooling would be a viable option in the case model chosen. There is no clear path for air flow be the front. A 360mm AIO would be ideal, failing that perhaps a 280mm AIO but that could be difficult in a rack mount.
Therefore air is the easiest option. The typical massive Noctua air coolers likely won’t have the necessary clearance in a 4U Rack mount case.
What air cooler did you opt for?
I gave serious consideration to buying a Threadripper 3960X but I couldn’t justify the cost and it wasn’t the ideal option for the typical workloads I would be dealing with. So I stepped it down to an AMD R9 3950X which was IMO a good compromise. The 3950X is a bit of a beast to cool though. Initially it was spiking To as high as ~80C to ~85C at load. However, with some tweaking I was able to get that down to about ~70C to ~75C under load. That is with a Coolermaster Master Liquid 240mm AIO. I think AMD recommends a 280mm to 360mm.
