Unofficial 12V-2x6V Power Connector Melts NVIDIA GeForce RTX 5090
14,296 (6.44/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
They uses 110V/220V, that's different.
5090 runs on 12V 50A, and the working temperature >60C.
So 1x 6AWG, or 2x 10AWG
Give it some safe room and the solution could be just scale up the original 6 pin design with 10 AWG wires and connectors
Go Big Vanessa Lachey GIF by CBS
Or maybe we shouldn't have 600 W GPUs? I know, heresy, but what if...? :rolleyes:
1,694 (0.77/day)
Motherboard MSI X670E Carbon
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
Display(s) Samsung G8 OLED
Case Silverstone FT04
If the plug works correctly then 12 pins is fine. It's been fine for the 6-pin and 8-pin GPU plugs. 8 pins for the CPU power plugs are doing just fine too.
According to spec, for 8-pin, the 3 live wires only share maximum load of 13A (150W)
Even 1x 18AWG wire could handle that load.
And there are three wires in a 8-pin plug to spread the load.
So it is "safe" even in a case of "one wire carries all the load"
But Nvidia's 12pin isn't.
The spec was 50A and putting 50A in "one wire carries all the load" situation would blow the whole thing up.
2,832 (1.61/day)
I don't think you understand my point.
Go to Home Depot and feel 12 AWG or 16 AWG wire. Its thick, inflexible, bulky and hard to work with. By the time you're talking about 6 AWG wire that's needed to carry 50 Amps safely, its a specialty wire that I don't think you'd see in any common situation.
You might see 6AWG on central home air conditioners or maybe generators. Its very rarely used given how big, and expensive, the copper is.
At these wattages, its clear that larger wires like 6AWG or even 4x 8-pin connectors are too bulky for computer usage. But 12vhpwr adapter might be too small.
1,694 (0.77/day)
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
Average quality 12vhpwr cable uses 16 AWG wires, and I think they are quite flexible, the bulkiness comes from the fact that it is 12 wires clamped together.
I think a simple scale up of a 6-pin with 10 AWG wires, or 8-pin with 12AWG wires should be Okay.
They have 80-90 total amps capacity in terms of safety, and okay flexibility.
And one wire could at least withstand 20+Amps...
A simple amazon search gives me roughly the same price for 12 AWG and 16 AWG wires, hence cost isn't the problem.
10 AWG costs twice than 16 AWG but is also uses 1/2 number of wires so they costs roughly the same.
One more observation.
Noticed that both the burn and der8auser's hottest wire all come from the nearest pin from PCB
That pin has the shortest 90 degree bridge behind the connector, hence least amount of resistance.
280 (0.15/day)
But it would be a hot wire, and the pin wouldn't be lasting either. Besides, the CPU plugs can go way higher than that. They're rated up to 32 Amps in total.
The nitpicking over slight length differences is just that, nitpicking. The huge measured differences in current and thermals can't be from minor length differences.
It's clearly a faulty connection, and that fault can only be from the plug - The 12VHPWR cable plug. Which is now rectified with the newer 12V-2x6 cable plug.
6,216 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Yeah, stretching the power limits, connector limits and such isn't the way to progress. We need more performance for less power without any tricks like MFG.
3,903 (1.33/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
That's the plug's fault, not the card.
The discussion at hand about monitoring each wire seems to point at exactly the opposite. The cable and plug does not have problems when usage of it is even remotely in spec.
Nvidia just forgo any control and let nature do its thing on balancing between the wires.
While Nvidia clearly messed up big with lack of monitoring, isn't the actual cause for something like this in either cable or the PSU? As repeatedly said and shown/explained in videos, at least on card side this all goes into one big blob of 12V. Is the only thing card can do in situation with per wire monitoring is raise alarm when one wire is overloaded and preferably shut the card down? Or would separating the wires as 3090Ti did and not the blob to make it work?
That would basically be an 5080. There is no real path to more performance until TSMC has the new process available and/or Nvidia/AMD/Intel is willing to use it. Or, as an alternative, tricks like MFG...
Der8auer had 8-pin connectors on PSU side of things. 20A through one of those wires. I wonder if someone will do an actual test again in burning down a card or plugs :)
14,296 (6.44/day)
Midlands, UK
Cooling Yes
Storage A lot
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
I'm not an electrician, but based on my limited knowledge, this makes complete sense to me.
3,903 (1.33/day)
Spec calls for 16AWG as minimum.
