Again, laptop batteries have nothing to do with UPS batteries. Amazon sells CR2032 and deep-cycle marine batteries too. Does that make them relevant to this topic? No.
And note I did mention Amazon as a source to check in my post #5 above. But I will point out they do NOT always have the best price as prices change frequently. So again, it is important to check other sources on the day one is ready to purchase. Also Amazon only delivers them faster if the cells you want are in the current inventory of one of their nearby distribution centers.
I thought this topic was about buying a UPS battery. I said:
"Since then I been [buying] UPS batteries using Amazon" ... where's the beef ? If you wanted to criticize, cuda pointed out I left out the word "buying" or perhaps "getting" . Can you quote the part of the post where it was indicated that there is any similarity between laptop and UPS batteries other than you can buy both at the same place. No you can't cause it isn't there. Doubling down implying it is doesn't change the written word.
I spent two paragraphs talking about UPS batteries. In the 3rd paragraph I provided a bit of background on
what led me to consider Amazon as a source of UPS batteries. I included this because when I 1st heard it, it seemed odd and it was not something I had ever before considered.
1. I never considered buying any type of battery from Amazon, never would have entered my mind.
2. When I went to order a laptop battery replacement from our custom laptop builder (an individual I have known for about 10 years and know something about his knowledge and hobbies) and he suggested Amazon. When I expressed a considerable level of incredulity ... he went on to explain that ya can buy any type of battery @ Amazon ... cars, boats, motorcycles, ATVs, UPSs, power tools whatever .... and they provide next day delivery.
3. So I bought the laptop battery there and later on when the need arose, remembering his earlier recommendation regarding
"all types of batteries" I went and took a peek about what Amazon had to offer and as was said ....
The fact is I never would have thought to to look at Amazon for UPS batteries if not for the laptop guy's recommendation ... a recommendation that included all types of battery replacements. I design water treatment plants ... does that make any recommendation I make on these forums off topic ? How is it that when you provide suggestions on where to buy a UPS battery it's relevant and when someone else does it's not ? I did not recommend that OP purchase a laptop battery, I specifically recommended he consider Amazon
as a source of UPS batteries ... so in what way is this irrelevant ? I'm as lost here as I was with the weather map and black sharpie explanation on TV. How does the fact that someone I have known for 10+ years recommended that we use Amazon for any / all types of batteries make anything irrelevant ? In what possible way does battery design restrict who can sell it ? Which of these is acceptable ? Only one ?
After my laptop supplier suggested I consider Amazon as a source for all types of batteries, I looked into it and "since then I been getting UPS batteries from Amazon"
After "Ask Woody" suggested I consider Amazon as a source for all types of batteries, I looked into it and "since then I been getting UPS batteries from Amazon"
After "my electrical contractor" suggested I consider Amazon as a source for all types of batteries, I looked into it and "since then I been getting UPS batteries from Amazon"
After "my mother-in-law" suggested I consider Amazon as a source for all types of batteries, I looked into it and "since then I been getting UPS batteries from Amazon"
After "Bill Bright" suggested I consider Amazon as a source for all types of batteries, I looked into it and "since then I been getting UPS batteries from Amazon"
Yes, we all agree that there is little similarity between the design of a laptop battery and a UPS battery ... but
as such was never stated or implied, why do you see it as justification for irrelevancy ? How does the fact that "a guy who builds laptops for a living " recommended I consider getting
any / all types of batteries from Amazon make my actual experience buying UPS batteries there and recommending them as a source of UPS irrelevant ?
Yes, I'm sure its possible that a particular battery might not be available. The relevant facts however are, in my experience:
a) No other supplier I looked at offered any indication of delivery date. Amazon said "next day". Everyone else was vague on when it might be delivered with "usually 2-4 weeks" being the most common statement. To my mind, that's extremely relevant as not many folks want to go without a UPS during Hurricane season for "usually 2 - 4 weeks".
b) By your own statement "all of the sources you listed" had only 1 year warranty, I'd think the option for a 3 year warranty (4 with AMEX) would be relevant to most purchasers.
c) I did look at other sites ... I was unhappy with the warrantees, unhappy with not knowing when I'd get it....unhappy that i had to 'add to cart" before i could get any information at all.
d) Yes, Amazon might not have a particular model number in stock, but most of the other sites had few choices and when they say 2 - 4 weeks does it matter if it's in stock ... is it in stock, if it is why so long ? However, there were dozens upon dozens of alternative choices of varying warrantees, brands, etc you can see on screen. Remember, a large % of these purchases are via storefronts. Given the number of dollars coming in thru these storefronts, rest assured that every vendor has Amazon listed as a higher priority than any of us.
By all means shop at various sources, I always do ... I looked at other sites ... but no 3 year warrantees, no guaranteed next day delivery. I'm not saying look only at amazon, I'm saying don't leave Aamzon off ya list of places to check.
