- Nov 1, 2008
- 4,213 (0.74/day)
- Vietnam
System Name | Gaming System / HTPC-Server |
Processor | i7 8700K (@4.8 Ghz All-Core) / R7 5900X |
Motherboard | Z370 Aorus Ultra Gaming / MSI B450 Mortar Max |
Cooling | CM ML360 / CM ML240L |
Memory | 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz |
Video Card(s) | Zotac 3080 / Colorful 1060 |
Storage | 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe |
Display(s) | LG 27GN800-B 27'' 2K 144Hz / Sony TV |
Case | Xigmatek Aquarius Plus / Corsair Air 240 |
Audio Device(s) | On Board Realtek |
Power Supply | Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum |
Mouse | Logitech G502 Hero / K400+ |
Keyboard | Wooting Two / K400+ |
Software | Windows 10 x64 |
Benchmark Scores | Cinebench R15 = 1542 3D Mark Timespy = 9758 |
65°C (149°F) is well above the threshold that would cause 2nd degree burns to the skin. That temp does not seem reasonable to me.
The UPS should not be placed in a confined space but it does not need to be in a place that receives a "flow" of cool air ventilation. It only needs to be placed where air can freely radiate off it.
I would not trust that UPS in my home.
The UPS itself is not 65C. Just the iron core on the transformer when opened up! That is meant to get hot. Ambient here is around 30 C anyway
I switched it with my 6 month old one and it exhibits the same behavior, getting warmer in that location, but I haven't opened it up to measure the temp on the transformer as I don't want to void the warranty, but I can tell that the warmth is coming from the transformer area.
I may open up my one with 2 batteries again and add some sort of (non-flammable) insulation between the transformer and the battery compartment. Though the batteries are cool to the touch, they are closer to the transformer compartment since making the modification.
I've moved the dual battery system to my main rig for the time being anyway and I will keep it turned off at night or when not in use.
