Water Cooled Lian Li O11 Dynamic EVO Project Build
28,883 (4.58/day)
Miami, Florida
Motherboard ASUS ROG Crosshair X670E Hero
Cooling ARCTIC Liquid Freezer III 360 A-RGB // X12 Phanteks D30-120 D-RGB Fans
Memory G.SKILL Trident Z5 Neo RGB Series (AMD Expo) DDR5 RAM 32GB (2x16GB) 6000MT/s CL30
Video Card(s) ZOTAC Gaming GeForce RTX 4090 AMP Extreme AIRO
Storage Samsung Pro 980 2TB NVMe (OS and Games) // WD Black 10TB HDD (Storage)
Display(s) SAMSUNG 34-Inch Ultrawide 75Hz (Desk Games) // SAMSUNG 49-Inch Ultrawide 144Hz (Sim Racing Rig)
Case Phanteks NV7
Power Supply Seasonic Vertex GX-1200, 1200W 80+ Gold, ATX 3.0
Got 3 of these running off 1 fan header which is pretty neat.
It is indeed. Ordered 7 to have all my fans the same. I'm more excited for that than the build itself :laugh::roll::roll::roll:
dgianstefani
TPU Proofreader
5,316 (2.03/day)
Swansea, Wales
Benchmark Scores Legendary
I think there is still a limit, as each fan will have a certain W draw, and one header can only provide x W before there's an issue. But yeah, cool tech.
28,883 (4.58/day)
Miami, Florida
Case Phanteks NV7
I'm going to be using 3 per header which I had done before so it should not be a problem.:) but yes, of course there's is a limit and one we should always keep an eye out for if we don't want to be short a header hehehe
28,883 (4.58/day)
Miami, Florida
Case Phanteks NV7
HammerON
The Watchful Moderator
8,402 (1.44/day)
Up North
System Name Aki
Processor AMD 7800X3D
Motherboard ASUS ROG STRIX X670E-A
Cooling MSI MAG CoreLiquid E360
Memory Patriot Viper Elite 5 32GB 6200
Video Card(s) PNY RTX 4090 XLR8
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard ASUS ROG Strix Scope II Wireless
Software Win 11 Pro
Sub'd.
I have used mono blocks on several builds recently. I have found them to work pretty well. One big downfall though is the lack of being able to use it in other builds since they are specific for the motherboard. Hence the reason I have moved away from them in my recent 3960X builds.
Looking forward to you build CP!!!
28,883 (4.58/day)
Miami, Florida
Case Phanteks NV7
Sub'd.
That's something I thought off too and I believe was mentioned earlier too. Sub'd at a good time. I'm installing some stuff today!
3,469 (1.70/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Don't forget to do some of those sexy plastic peel off photos.
28,883 (4.58/day)
Miami, Florida
Case Phanteks NV7
Unfortunately nothing had anything to peel off, but here is the distro plate installed. Tomorrow I'll order the rest of the loop. Need to figure out which radiator I want to go with.
what do you guys think of it? I think its a lovely piece!
3,469 (1.70/day)
Mouse Logitech M575
Awesome. For some reason part of my brain is working on how to gift my 011D for Christmas so I have an excuse to get an EVO. It looks like they really engineered the problems and issues out of the original 011D and still managed to add some cool features.
I can't help but think it might be nice to have a small vertical display panel behind the large unobstructed part of the distroplate and display stats like temps and stuff. (never mind, just forget I mentioned that.)
28,883 (4.58/day)
Miami, Florida
Case Phanteks NV7
It truly is an amazing case. I also removed the HDD Cage from the back and mounted my two HDD's where the side fans go using the supplied plate it brings. So now I got tons of room back there for cables and tidying them up.
As far as an LCD, that's in the works. Planning one currently to see if I can mount in the rear case fan area.
28,883 (4.58/day)
Miami, Florida
Case Phanteks NV7
P.S., you should totally get the EVO HAHAHAHA
28,883 (4.58/day)
Miami, Florida
Case Phanteks NV7
Just ordered the rest of the loop. Hopefully it's all compatible, and I'm not missing anything :confused:. If not I'll have to exchange/order as I go.
My you know what still hurts. Atleast they included free lube, I mean lubricant for bending hard tubing :roll:
3,469 (1.70/day)
Mouse Logitech M575
I'm not a fan of the EK Duraclear soft tubing. My first box clouded quickly (like the insides were covered in a white powder) and yellowed fairly quickly although this may have been due to not cleaning my rad well enough. My 2nd attempt (replaced all tube from my first year) lasted significantly longer maybe 6-8 months before dulling and not looking so great. I'm switching to an opaque black PrimoFlex (still waiting for it to arrive) while I try to optimize loop flow to reduce pump noise.
28,883 (4.58/day)
Miami, Florida
Case Phanteks NV7
I'm not a fan of the EK Duraclear soft tubing. My first box clouded quickly (like the insides were covered in a white powder) and yellowed fairly quickly although this may have been due to not cleaning my rad well enough. My 2nd attempt (replaced all tube from my first year) lasted significantly longer maybe 6-8 months before dulling and not looking so great. I'm switching to an opaque black PrimoFlex (still waiting for it to arrive) while I try to optimize my loop flow to try and reduce my pump noise.
I'm going to be using the hard tubing, hopefully it doesn't suffer from that. But I bought soft tubing just in case I needed a small portion or something. Doesn't hurt to have. Or for filling/draining.
Black tubing would look great!
3,469 (1.70/day)
Mouse Logitech M575
I don't think hard tubing has those problems.
EK has a very nice drain valve fitting. In this picture I have an redundant plug on the end of it but you can screw in a compression fitting at the end with a tube which is very handy including if you need to pressure test your system before you fill it. This is one of the best mods to my loop where before I used to have a heavy and cumbersome ball valve.
202 (0.22/day)
28,883 (4.58/day)
Miami, Florida
Case Phanteks NV7
I was actually on the fence of getting one and I think I will. Ordering now. Thank you for the heads up. That indeed seems much easier.
28,883 (4.58/day)
Miami, Florida
Case Phanteks NV7
Not cheap eh, think i spent over £600
Nope, right under $500 USD. But they threw in some free stuff and it was 10% off storewide for labor day. :) had to take advantage.
28,883 (4.58/day)
Miami, Florida
Case Phanteks NV7
D5 PWM pump installed. Now to wait for the motherboard tomorrow and hopefully by Saturday the rest of the loop. Can't wait!. Also need to order some black sleeving to take care of some misc wires such as the pump wires. Going to do that now.
28,883 (4.58/day)
Miami, Florida
Case Phanteks NV7
So, the mother load from Titan Rig full of EK goodness has arrived. They even threw in some free stuff.
Dark Hero VIII X570 ready to drop in
EK block installed
Today's progress, fittings, caps, rad mounted
I ordered two fittings shy of what I needed, brain fart! I ordered another pack of 6 to have some extra for maybe adding GPU later when I upgrade it. Those get here Sunday. Tomorrow I will cut and install tubing. I'll move the fittings around to do the tubing then Sunday when I get the missing ones I'll flush it, and fill it :)
Arriving tomorrow I ordered a Samsung Pro 2TB NVMe. Arriving Tuesday I have a 7"LCD to mount in the rear case fan area (hopefully) to monitor everything. Then Wedneaday I get my 6 Lian Li SL Infinity fans and that is it folks. Build should be done then!
Let me know what you guys think so far. Anything I should change, etc?
3,469 (1.70/day)
Mouse Logitech M575
EK block installed
Ha I did that too!
Looking nice!
Don't forget to clean your radiator very important!
Do you have a leak tester? (it's quite handy to use before filling the loop)
28,883 (4.58/day)
Miami, Florida
Case Phanteks NV7
Hahaha tends to happen all the time man, end up a fitting or two short somehow.
I forgot to order one *knew I was forgetting something). I'll see if I can ghetto rig something tomorrow if not I'll just do some praying hahaha. And yes, I will be flushing everything with distilled water first :)
28,883 (4.58/day)
Miami, Florida
Case Phanteks NV7
Definitely a learning curve. Took some trial and error but got it done. Now just need to 90º fittings that arrive tomorrow to connect the outlet to the inlet so I can leak test :)
I also ordered a Samsung 980 Pro Gen4 NVMe 2TB drive which is already installed. So next stage is leak test so that then I can also flush it and get to the cable management.
9,340 (5.07/day)
Louisiana
Keyboard G710+x3
90's ? bite your tongue bend those pipes it looks excellent :clap:
