Water Cooled Lian Li O11 Dynamic EVO Project Build
28,883 (4.54/day)
Miami, Florida
Motherboard ASUS ROG Crosshair X670E Hero
Cooling ARCTIC Liquid Freezer III 360 A-RGB // X12 Phanteks D30-120 D-RGB Fans
Memory G.SKILL Trident Z5 Neo RGB Series (AMD Expo) DDR5 RAM 32GB (2x16GB) 6000MT/s CL30
Video Card(s) ZOTAC Gaming GeForce RTX 4090 AMP Extreme AIRO
Storage Samsung Pro 980 2TB NVMe (OS and Games) // WD Black 10TB HDD (Storage)
Display(s) SAMSUNG 34-Inch Ultrawide 75Hz (Desk Games) // SAMSUNG 49-Inch Ultrawide 144Hz (Sim Racing Rig)
Case Phanteks NV7
Power Supply Seasonic Vertex GX-1200, 1200W 80+ Gold, ATX 3.0
90's ? bite your tongue bend those pipes it looks excellent :clap:
Thanks bud. Unfortunately I don't have enough pipe left to do two bends. Just thought it would look much cleaner with the 90° fittings and a short piece of tubing. But yes, so far super happy with how it's looking.
3,730 (1.78/day)
Power Supply Corsair RM750x
Mouse Logitech M575
I was actually on the fence of getting one and I think I will. Ordering now. Thank you for the heads up. That indeed seems much easier.
FYI on that quantum torque drain value be careful. It's actually really easy to accidently not close all the way. When closing it be sure it locks flush with it's mounting surface otherwise the value isn't 100% closed. I just made that mistake today refilling my rig. Luckily I had a cap on it anyway but when I went to remove the cap to use it elsewhere it started to leak then I realized my mistake.
JrRacinFan
Served 5k and counting ...
20,126 (3.04/day)
Youngstown, OH
System Name Snow White
Processor Ryzen 7900x3d
Motherboard AsRock B650E Steel Legend
Cooling Custom Water 1x420
Memory 32GB T-Force Deltas
Video Card(s) PowerColor 7900 XTX Liquid Devil
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Tt CTE 600 Snow Edition
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Corsair K65 Mini
Benchmark Scores Avermedia Live HD2
Good job on the build so far CP. My private messages are always open for you, if you need any minor assistance. :peace:
28,883 (4.54/day)
Miami, Florida
Case Phanteks NV7
Unfortunately I can't fit my drain valve because of the front glass. Didn't think that through. Unless I put it on another port? Not sure if that would work maybe? Haven't looked into that.
28,883 (4.54/day)
Miami, Florida
Case Phanteks NV7
Of course buddy, and thank you!
3,730 (1.78/day)
Mouse Logitech M575
You might need to get creative and put a T fitting somewhere. Here is an example but your solution will have to be a different with hard tubing.
If you are putting in a bottom rad (or rad with ports on bottom) that would be a solid mounting point for a T fitting. Personally I might be afraid to put any heavy fittings in the middle of a hard tubing run but I haven't done HT yet so I'm not sure what kind of weight it can carry unless it's on a vertical run. I'd look around on the web to see how hard tubers arrange their drain ports.
28,883 (4.54/day)
Miami, Florida
Case Phanteks NV7
Thing is distro plate is in the front, and front Glas is right in front of it. Even with a T fitting it won't fit. However I have an EK plug there now and it's in the lowest point of the distro plate and with front glass removed there's nothing in it'd way. I'm thinking I can put it by the sink and remove the cap and it'll drain easily with no mess.
3,730 (1.78/day)
Mouse Logitech M575
What I am saying is you can use a T fitting probably somewhere on the inside of your loop (preferably at the lowest point). In my example I have 90 rotary so I can tilt and connect the longer hose to drain but that only works for soft tubing. I'm not sure of your flow direction but inserting a T somewhere in the lowest portion is an ideal spot for the drain if you want one. It doesn't have to be in the perfect lowest spot, just enough to make draining and dissembling the loop manageable because you will still have some fluid left it the blocks or rads depending on the orientation of them.
28,883 (4.54/day)
Miami, Florida
Case Phanteks NV7
View attachment 260755View attachment 260756
Yes, that's what I was thinking, in one of those ports. When I finish the rest of the loop today I will see if I can put it into one of those ports. Thanks a lot for the pics and the help bud. Always appreciated.
3,730 (1.78/day)
Mouse Logitech M575
Figuring out tubing runs is a fun part. I spent just a couple of hours alone trying to convince myself how and where to relocate my drain port without having to order more fittings and just use what I had on hand. Even used some old pieces of soft tubing to test runs and ideas. Managed to save myself from buying $50 of stuff I didn't need yesterday.
28,883 (4.54/day)
Miami, Florida
Case Phanteks NV7
Hahaha I wasted what more for not thinking stuff through. To my defense I had not done a custom loop in a while. It happens. Haahah
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
You might rotate your pump like this image shows it's 90 degrees different than you show might help with the d5 noise.
JrRacinFan
20,126 (3.04/day)
Youngstown, OH
Storage 20+ TB
Definitely this CP. I have first hand experience.
28,883 (4.54/day)
Miami, Florida
Case Phanteks NV7
You mean to put it so the label is upright 100%? Is that what you mean?
28,883 (4.54/day)
Miami, Florida
Case Phanteks NV7
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
28,883 (4.54/day)
Miami, Florida
Case Phanteks NV7
Probably just my lack of coffee today so far, but not sure what you guys are trying to tell me about rotating the pump, sorry. :(
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
Computer guy said he's having pump noise
I suggested he try rotating his pump 90 degrees
ATM his pump is with the bar code horizontal
I'm suggesting rotate it like his last example of the distro plate shows which is this rotation showing the bar code vertical
.easiest thing to try.
Will it make any difference no telling.
28,883 (4.54/day)
Miami, Florida
Case Phanteks NV7
Oh gotcha. For some reason I thought you were telling me to rotate it and I was thinking well that picture is my picture hahaha. Sorry fellas.
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
No problem indeed that is your image so if you have no pump noise :cool:
3,730 (1.78/day)
Mouse Logitech M575
Yea I think I'm going to try that when I get the chance.
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
