What is your computers idle power consumption
1,682 (0.33/day)
State College, PA, US
System Name My Surround PC
Processor AMD Ryzen 9 7950X3D
Motherboard ASUS STRIX X670E-F
Cooling Swiftech MCP35X / EK Quantum CPU / Alphacool GPU / XSPC 480mm w/ Corsair Fans
Memory 96GB (2 x 48 GB) G.Skill DDR5-6000 CL30
Video Card(s) MSI NVIDIA GeForce RTX 4090 Suprim X 24GB
Storage WD SN850 2TB, Samsung PM981a 1TB, 4 x 4TB + 1 x 10TB HGST NAS HDD for Windows Storage Spaces
Display(s) 2 x Viotek GFI27QXA 27" 4K 120Hz + LG UH850 4K 60Hz + HMD
Case NZXT Source 530
Audio Device(s) Sony MDR-7506 / Logitech Z-5500 5.1
Power Supply Corsair RM1000x 1 kW
Mouse Patriot Viper V560
VR HMD HP Reverb G2
Software Windows 11 Pro x64
Benchmark Scores Mellanox ConnectX-3 10 Gb/s Fiber Network Card
With monitors and speakers on, just playing music, mine averages around 270W. It uses around 900W with an intensive game like Civ 5.
Worst part is the Z-5500 speakers, which unacceptably draw 10 watts IN STANDBY. I unplug them with not in use for that reason.
Mussels
Freshwater Moderator
58,413 (7.86/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
... for real? that seems like far too much power, even for 3 monitors. i cant make my system break 600 with overkill synthetic tests.
1,682 (0.33/day)
VR HMD HP Reverb G2
I'll bring out the power meter and recheck - give me a min.
Mussels
58,413 (7.86/day)
Oystralia
oh you mentioned speakers too, i missed that. i have no idea how much power z55's actually use, never measured mine. i too shut them off at the wall when not in use, they draw a fair bit at idle, and they hum too.
2,644 (0.45/day)
System Name MRCOMP!
Processor 5800X3D
Motherboard MSI Gaming Plus
Cooling Corsair 280 AIO
Memory 64GB 3600mhz
Video Card(s) GTX3060
Storage 1TB SSD
Display(s) Samsung Neo
Case No Case... just sitting on cardboard :D
Power Supply Antec 650w
speakers should draw fuck all when not at loud volumes (excluding idle power).... my sony HiFi uses 62 watts at idle.... and yet only draws 90 watts or less at decent volume with the bass up. it wont start pulling 900+ watts till the very last few notches as volume vs power consumption is exponential not linear. ( 1400s is the highest iv seen them peak at.)
1,682 (0.33/day)
VR HMD HP Reverb G2
Okay, I re-measured my system with my Kill-A-Watt. The idle number I stated was a little low and the load number was a little high.
Monitors (all 3): 133W
System (no monitors or speakers) (idle): 190W
System (no monitors or speakers) (load, Civ 5): 543W
System (no monitors or speakers) (load, Furmark): 633W
Z5500 (standby): 10W
Z5500 (on, nothing playing): 40W
So a reasonable number I'd be pulling playing Civ 5 with speakers and monitors on would be ~720W. BF3 is probably more, I didn't check.
2,644 (0.45/day)
System Name MRCOMP!
Processor 5800X3D
Memory 64GB 3600mhz
Storage 1TB SSD
is civ 5 with or without v sync?
1,682 (0.33/day)
VR HMD HP Reverb G2
It's with VSync
Frick
Fishfaced Nincompoop
19,816 (2.86/day)
north
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
1,682 (0.33/day)
VR HMD HP Reverb G2
Whats the draw with VSync off?
It's much less, only 487W for the system (no monitors or speakers). I don't know for sure why it's lower, but could it be because the game is CPU limited and VSync is just putting more load on the GPUs?
Mussels
58,413 (7.86/day)
Oystralia
maybe you got that backwards, or some kind of game bug is interfering.
301 (0.05/day)
Processor Intel i5 2500k @ 4.2ghz
Motherboard Asrock z77 Extreme4
Memory 8GB Corsair LP 1600mhz
Video Card(s) Gigabyte gtx570 + Evga gtx570 HD
Storage Corsair Force GT 120gb
Display(s) Samsung 931bw
Case Cooler Master Cosmos S
Power Supply Corsair vx550
Software Windows 7 Ultimate 64
Just changed my graphics card to an evga gtx 570 hd
i3 2120 with stock cooler
gtx 570
Asus P8Z68-V LX
Corsair vx550
2x4gb 1333mhz ram
Raptor X 150gb 10,000rpm
idle is now between 69 and 85. Slightly higher 'lowest' reading but for some reason its not as erractic as the 6870. perhaps it kicks into 3d mode easier.
104 (0.02/day)
only 37w
i7 2600
gigabyte h61 usb3 :(
8gb ddr3 1333 (2x4gb)
1tb WD green
LG bluray
116w at full load when compressing with x264
using a cheap u$20 chinese power monitor (+1/-1 error)
1,498 (0.28/day)
canada
System Name INTEL/AMD
Processor I7 4790k stock / 1100T@3.8GHZ(on air)
Motherboard GIGABYTE GAMING 5 / GIGABYTE GA-990FXA-UD3
Cooling Noctua NH-D15 / zalmen 9900
Memory 4x4 GB 1600 / 4x4gb 1600
Video Card(s) GTX670 x2 / ATI 5870 x2
Storage 2xcorsair ssd 120gb raid0 /2x adata ssd 120gb
Display(s) 55Iinch LCD / 22inch acer
Case CM 690 II Advanced (USB 3) / Anteck 900
Power Supply Enermax 800EWT / 750 zalman
Software Win 10
I only have my pc hooked up to my battery backup nothing else draws from it.
idel 110w
furmark 540-550w
prime 95 345w
combine test 740-755 watts
when i woke up it was cold as hell so my temps where 10 degc on cpu when i turned it on. Still stressing the cpu its only @ 38deg c.
anyone else have a system that goes over 750 watts?
Aquinus
Resident Wat-man
13,175 (2.77/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
My system as the following power usages:
Idles @ 165-watts
Full CPU + GPU load @ 350-watts
Full CPU + GPU load overclocked @ 450-watts
I have two monitors, a 22" and a 28" LCD with CCFL backlighting that consume a total of 100-watts together.
749 (0.13/day)
Netherlands
System Name gaming system
Processor 2600k @ 4.2 ghz
Motherboard MSI Z77 MPower
Cooling Thermalright ultra extreme 120 rev.C w/noctua NF-S12B push/pull
Memory 16gb corsair vengeance 2400 c11 @1.5 v/
Video Card(s) GB gtx670 WF3x sli @1080/1372/6660(core/boost/mem)
Storage 2x samsung 850evo 250gb raid 0 ,2tb wdblack, 3TB wd purple
Display(s) Samsung Syncmaster P2770FH, asus VH242t/19" lg 1440x900
Case fractal design r4
Power Supply Corsair HX1050
Mouse Razer abyssus
Keyboard corsair k70
Software Windows 10 pro x64
Dunno xd around 100watts xd i don't know about idle for my gtx275 xd
1,226 (0.24/day)
Omaha, NE
System Name Graphics Card Free...
Processor Ryzen 5 5600G
Motherboard MSI B450 Gaming Plus MAX Wifi
Cooling Cryorig M9a w/ BeQuiet! PureWings 2 ~ 92mm
Memory Corsair Dominator Platinum DDR4 3200 ~ 16GB(2x8GB)
Storage Samsung EVO 870 SSD - 1TB
Display(s) AOC 24G2
Case Cardboard...
Power Supply eVGA SuperNova 550w G3
Mouse Logitech t400 Zone Touch Mouse
Keyboard IBM Model "M" Keyboard
Software Manjaro ~ KDE Plasma
Benchmark Scores She's a Runner!
I have a Core i3 2120 that spixel has. Idles at 23-25 watts without a video card on an Intel DH67CF. Add 12-13 watts per monitor with a video card(HD 7770). Top end fluctuates between 140-155 watts if I am playing a game with dual 24" monitors hooked up. I only game on one monitor.
My core i3 530, same story...about 25 watts on an Intel DH55TC(highly recommend for efficiency/stability).
My P2412H's use 25 watts or so and my Klipsch 2.1's idle at 12w.
So...Core i3 2120 on a DH67CF with two monitors hooked up? 47-48 watts at idle. 60 watts including speakers. About 100w including monitors.
Best,
LC
11,880 (2.18/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
ive got to be close to the 850watts my psu is rated at, ive no meter, but im at the limits of what the psu can and will do its at that 24/7 folding:eek: any higher oc and my pc flatlines till reboot:confused:
Aquinus
Resident Wat-man
13,175 (2.77/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
You do realize doing that is putting your computer at risk? I would get a bigger PSU if you really think you're getting close to it or you might find that a new motherboard, CPU, or video card will be in your future if not all of them.
AsRock
TPU addict
19,175 (2.98/day)
UK\USA
Cooling D15
Phenom 2 555 x2 unlocked around 115w idle ( don't really use it for game so no max but seen it around 220w mark..
Intel Q9550 on a maxinus mobo 180-200w idle max 280-370w depending on game. How ever with the newer DDR3 775 mobo idles around 100w-120w.
i5 2500k 77w-120w idle and only seen it as high as 300w.
The intel setup were tested with the same HDDs\SSDs which is\was 6 in total as for the AMD setup has only 2HDD's installed.
2,732 (0.54/day)
Greece
Motherboard MSI B550 Tomahawk
Cooling ZALMAN CNPS9X OPTIMA
Case SHARKOON M25-W 7.1 BLACK
Keyboard Trust GXT280
Idle 70-80W.
Normal gaming 130-150W.
Stretching 180W.
CPU undervoltaged. Monitor off. Plus 50-60W when it's on.
1,056 (0.18/day)
Romania
Processor i7-9700
Motherboard Gigabyte Z390 AORUS PRO
Memory 32GB DDR4
Video Card(s) msi 1080
Storage Samsung SSD 850 pro 2TB+1tb hdd 7200rpm+ 1tb 970pro
Software Mageia 6 + Windows 10
-idle(+monitor) = 114w
-in winrar benchmark(+monitor) = 165w
specks
440 (0.09/day)
System Name Spreadsheet powerhouse
Processor Two P4s glued together
Motherboard Asus P5KPL-AM EPU
Cooling CoolerMaster Hyper TX3
Memory 2gb (2x1gb) Kingston Value Ram DDR2 800mhz
Video Card(s) Sapphire HD4670 1gb GDDR3 w/ Arctic Cooling Accelero L7
Storage 500GB Western Digital Caviar Blue
Display(s) Philips 191EL 18.5"
Case Thermaltake V4 Black Edition
Power Supply Thermaltake TR2 600W
Software WinXp
I'm guessing mine is about 150W idle
Mussels
58,413 (7.86/day)
Oystralia
5,459 (0.88/day)
Australia
I hate to think what mine is =/
