What is your computers idle power consumption
3,145 (0.65/day)
Processor 8700k Intel
Motherboard z370 MSI Godlike Gaming
Cooling Triple Aquacomputer AMS Copper 840 with D5
Memory TridentZ RGB G.Skill C16 3600MHz
Video Card(s) GTX 1080 Ti
Storage Crucial MX SSDs
Display(s) Dell U3011 2560x1600 + Dell 2408WFP 1200x1920 (Portrait)
Case Core P5 Thermaltake
Audio Device(s) Essence STX
Power Supply AX 1500i
Mouse Logitech
Keyboard Corsair
Software Win10
274w :eek: (without the monitors)
Aquinus
Resident Wat-man
13,175 (2.77/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
Over-clocked idle:
Over-clocked fulled loaded CPU + GPU:
Courtesy of my 1500va APC UPS.
That is without my monitors, they add about ~100-watts between the two.
Edit: I also ran Kombustor (Furmark) with elevated priority with Prime95 right behind it to ensure max load.
Mussels
Freshwater Moderator
58,413 (7.86/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
jesus that seems high, i dont even load that high and i'm running crossfire
Easy Rhino
Linux Advocate
15,645 (2.35/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software Fedora KDE Spin
That isn't a computer, that is like saying my cell phone draws 500mA at 3.5 volts.
not a computer? surely you jest. your cellphone is also a computer.
streetfighter 2
1,655 (0.31/day)
Philly
~120W is my typical idle sans monitor. Without underclocking the GPU and CPU, it is around 180W. :D
Aquinus
Resident Wat-man
13,175 (2.77/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
Games usually don't tax a computer 100%. Keep in mind that is with Furmark running with elevated priority and wprime running in the background, so the GPU, CPU, and Memory are running as hard as they can with both the GPU and CPU running overclocked.
We all know how much power AMD chips love to eat. Nom nom nom. Where is a picture of Pac-Man when you need it. :p
499 (0.07/day)
6.8w idle, laptop
w/ wifi on and screen brightness third lowest setting :) gigantic battery lasts me around 10 hours of real use.
The (Legendary) ASUS UL30VT. Games well too, Core2Duo overclockable to 1.9ghz and Nvidia 210m switchable graphics.
11,880 (2.18/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
borrowed a power meter from work and i was surprised at the result, idle mine draws 200-230 watts
cnq off obv as its at 4.05cpu 3.2 nb 1800mem gfx idleing but in performance profile so one isnt turning off, I expected more given the two pumps and 13 120 fans plus main rig:eek:
at load i was taken aback ,500-650 watts absolute max loaded and about 550watts folding 100% on all available cores etc:) ,not bad though im doubting that meter a bit:rolleyes:
base unit only :cool:
Aquinus
Resident Wat-man
13,175 (2.77/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
Was that with just the CPU loaded, or GPUs loaded as well, because if that includes the GPUs, that isn't unreasonable.
Mussels
58,413 (7.86/day)
Oystralia
people always get thrown off because "oh, my PC wont run on a 600W generic PSU, therefore my PC must need more than 600W to run", failing to take into account that most cheap PSU's over-rate themselves and have their wattage available on the wrong rails (EG, heaps on 3.3V, crap all on 12V)
166 (0.03/day)
System Name Render Box
Processor AMD Ryzen 7 1700x
Motherboard ASUS Crosshair VI Hero
Cooling Corsair H100i v2
Memory 32 Gigs Trident Z@2400 cl15
Video Card(s) Dual XFX RX 480 8gig
Storage 2x1TB Seagate Barracuda,2TB Seagate Barracuda, 250g Seagate Barracuda, 240g HyperX Predator M.2
Display(s) ACER 23.5, HP LE1911 x2
Case Modded Raidmax Agusta
Audio Device(s) Realtek 12 Series HD Audio
Power Supply Corsair CX750M
Keyboard CM Storm
mhmm
70-100watts idle
201watts Max load.
According to my "Efficiency Vermont" Free wattage meter from CVPS
I used 3d studio max to bang on the CPU (100% all 4 cores) 119 watts
Then ran BF3 which hammers my GPU right up to 100% and CPU right around 75-90%.
201 watts
Any good CPU/GPU benchmarks that push CPU and GPU to 100%?
Most power company's will loan you one for a few months to test power consumption throughout your home. At no cost.
Mussels
58,413 (7.86/day)
Oystralia
70-100watts idle
201watts Max load.
201 watts
i find OCCT's inpack x64 test + furmark (fullscreen since i have two GPU's) really hammers up the power.
499 (0.10/day)
System Name Multipurpose desktop
Processor AMD Phenom II x6 1605T @ 3.75Ghz , NB @ 2.5
Motherboard Gigabyte 990FXA-UD3 (rev 1.0)
Cooling Prolimatech Megahalems Rev. C, 2x120mm CM Blademaster
Memory Corsair Vengeance LP (4x4GB) @1666Mhz 9-9-9-20-24 1T
Video Card(s) ASUS Strix R7-370 4GB OC
Storage 2x WD Caviar Black 500GB Sata III in RAID 0
Display(s) Acer S211HL 21.5" 1920x1080
Case Cooler Master Centurion 534+, 3x 120mm CM Sickle Flow
Power Supply Seasonic X650 Gold
Software Windows 7 x64 Home Premium SP1
Total system (including monitor, speakers, and ADSL modem):
Idle 150-160W (120-130W case only)
Max Load 415W (Kombustor X-treme burn in + IBT "very high")
10,885 (1.55/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
Using Kill-A-Watt directly to PC PSU (no peripherals)
Idle = 185 Watts
Load (Crysis for instance) = 345 Watts
11,880 (2.18/day)
Manchester uk
VR HMD Oculus rift
everything , both gpus loaded max plus cpu:)
if said to me , i Know cheap psu's are shit , i just honestly thought my pc needed more watts then my 850 corsair TX gives but at 650 watts max that clearly isnt the case, hmm i must just be ocin wrong in some way , i had thought mine was BSODíng beyond these stable speeds(cpu4 nb3.2 mem1800) due to my PSU
Aquinus
Resident Wat-man
13,175 (2.77/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
It surprises me how many people don't realize this. You get what you pay for.
3,145 (0.65/day)
Mouse Logitech
Keyboard Corsair
Software Win10
Also cheap PSUs will give you higher wattage reading on the wall, because of the poor efficiency.
Mussels
58,413 (7.86/day)
Oystralia
this is true. when i went from OCZ (mid range) to corsair (high end, but similar wattage - 700W to 750W) i shaved about 40W off my systems load.
