Why is it so damn hard to find a white fan?
3,358 (1.18/day)
North East Ohio, USA
System Name My Ryzen 7 7700X Super Computer
Processor AMD Ryzen 7 7700X
Cooling DeepCool AK620 with Arctic Silver 5
Memory 2x16GB G.Skill Trident Z5 NEO DDR5 EXPO (CL30)
Video Card(s) XFX AMD Radeon RX 7900 GRE
Storage Samsung 980 EVO 1 TB NVMe SSD (System Drive), Samsung 970 EVO 500 GB NVMe SSD (Game Drive)
Display(s) Acer Nitro XV272U (DisplayPort) and Acer Nitro XV270U (DisplayPort)
Case Lian Li LANCOOL II MESH C
Audio Device(s) On-Board Sound / Sony WH-XB910N Bluetooth Headphones
Power Supply MSI A850GF
Mouse Logitech M705
Keyboard Steelseries
Benchmark Scores https://valid.x86.fr/liwjs3
I'm looking for a white-colored fan to do a push-pull config for my white-colored CPU cooler yet trying to find one is like looking for a needle in a haystack.
Edit: Oh, I've found some white-colored fans but they all have RGB and no... just no. I'm done with RGB puke.
3,809 (0.74/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
In that case, spray paint is your friend. Don't forget a clear coat to make it easier to wipe clean.
3,890 (0.82/day)
Processor AMD Ryzen 7 3700X
Cooling AMD Wraith Prism
Display(s) Samsung 50" QN94A Neo QLED
Case Antec 1200
Mouse Razer Deathadder Chroma
Keyboard Logitech UltraX
3,358 (1.18/day)
Mouse Logitech M705
The Corsair one looks good, but the CFM rating isn't the same as the one fan I do have. How important is it to match the CFM rating in a push-pull scenario?
17,444 (4.68/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710 (Red/Black)
Antec Storm comes in white, they are great fans I have some. the 3 pack usually comes out to about 10 bucks a piece. no rgb or lighting at all on these and great CFM
3,868 (0.59/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
Might just want to grab two - I know the noise from different fans together drives me nuts. I'm a little picky though. :kookoo:
Interesting...........
But there is merit to this though, loudness/acoustics/sound/noise however you want to describe it are not the same thing, and sometimes certain sounds can be far more aggrevating than a loud fan................
As for white fans, has basic run of the mills are not as common. It would be nice if Noctua had a white line of fans.
9,407 (3.40/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Cooler Master makes white fans and so does Deep Cool.
2,239 (1.24/day)
System Name GrandadsBadAss
Display(s) Acer XG270HU
Audio Device(s) Logitech z623 <---THE SUCK
Keyboard Roccat Vulcan Aimo
Software Win 10/11pro
Phanteks, Arctic, Thermalright, Fractal, Deepcool... that's all I can think of from solid companies. There are boatloads of cheapies that may or may not be worth trying out.
3,358 (1.18/day)
Mouse Logitech M705
Deepcool does not make a white fan despite how they make a white CPU cooler and bundle it with a white fan. I've looked!
freeagent
8,940 (3.90/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Thermalright makes white fans.
3,121 (2.43/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
NZXT makes white fans in both the 120mm and 140mm size. Some are RGB, some are non-RGB. Some are high static pressure and some are airflow optimized (case fans).
Deepcool makes white RGB fans. I presume the RGB function can be disabled or simply left unconnected. They also make white fans with a white LED.
EK also makes white RGB fans. Again I assume the RGB function can be disabled or left unconnected.
bequiet makes non-RGB white fans with black accents -- part of the Light Wings family.
I'll leave it up to the OP to do his due diligence in locating these on the respective corporate websites.
I stopped looking there. OP may wish to search a little harder since it took me less than 10 minutes to locate these four options.
3,358 (1.18/day)
Mouse Logitech M705
OK, so I finally bought the Corsair one that @Super Firm Tofu mentioned in his post. Now, considering that this new fan as a slightly lower CFM rating than the one that's currently on my CPU cooler, which one do I put in the pull and which one do I put in the push stage?
3,348 (1.69/day)
Power Supply Corsair RM750x
Mouse Logitech M575
I think pull is a bit harder so put the one with the better static pressure rating in the pull and the other as the push.
3,358 (1.18/day)
Mouse Logitech M705
OK, dumb question. How do I know which one is a high static pressure fan?
3,348 (1.69/day)
Mouse Logitech M575
From the specs of the Amazon link
2,342 (0.44/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
2,373 (0.57/day)
Audio Device(s) A LOT
Looks like the Corsair fan has slightly more pressure according to specs, but I’d personally put it in the push position to overcome the impedance from the fins
172 (0.03/day)
Akasa make great fans, I don't know if the are available where you are but they make white vipers AK-FN065-WKT03 they are really good.
3,348 (1.69/day)
Mouse Logitech M575
2,373 (0.57/day)
Marginally, like 2-3*, but yes
3,358 (1.18/day)
Mouse Logitech M705
Looking at pictures of the fin stack will push/pull on that deepcool ak400 really make a difference though? I'm not sure.
I'm just looking for a little bit more temperature stabilization, instead of the upswings in temperature. Does that make any sense?
I imagine that I'll have to get a new case as well, the air flow in my current case sucks.
2,373 (0.57/day)
That’ll make way more of a difference than an additional fan. Even upgrading the cooler will be much a better investment.
3,358 (1.18/day)
Mouse Logitech M705
I get it. When I took the front cover of my case off the idle temperature of the CPU dropped by 6 degrees. When the weather gets better in the North East area of the US, I'm going to take a trip out to my local Microcenter and look at a replacement case.
The bad part is that I don't want to have a huge thing hanging off my motherboard. I have an irrational fear of huge coolers. Will they break the motherboard? I don't know. Irrational, yes; but I still have them.
And no, I don't want to do liquid cooling.
