Wrong PCI Express in GPU-Z
leeocf
13 (0.02/day)
Guys, I have a problem. My video card is not using the correct PCI Express.
Here's the setup:
1) i7 13700k
2) Asus Rog z690-A Strix DDR4
3) RTX 4080 Galax
4) Source: 850W XPG Core Reactor
Look at the picture of GPU-Z and NVIDIA:
Actions I took:
1) Remove the video card and put it back
2) Clean PCI-Express connector with electrical contact cleaner
3) Update the BIOS
4) Update the Driver
Help me please!
Solaris17
Super Dainty Moderator
27,198 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
Do you use a riser cable?
Is it always x2?
Do you have another PC and does it show up fine then?
Did it ever work in this machine?
18,049 (2.44/day)
Did you hit the ? and follow the instructions?
leeocf
13 (0.02/day)
Is it always x2?
I don't use rise cable. I connect the video card directly to the motherboard.
I have another computer, but the video card does not fit on it. I even put another video card in the computer with the problem and it appears the same way.
I don't understand
Solaris17
27,198 (3.83/day)
Alabama
VR HMD Quest 3
That sounds like a motherboard issue to me then.
866 (1.20/day)
Belgium
System Name Prometheus
Processor AMD Ryzen 7 9800X3D
Motherboard ASUS ROG Crosshair X870E Extreme Gaming Wifi
Cooling AIO Cooler Master MasterLiquid 360
Memory 32GB DDR5 6000Mhz CL30
Video Card(s) Gigabyte GeForce RTX 3060 OC Edition 12GB
Storage Samsung 970PRO 2TB, Samsung 990PRO 4TB, WD SN850X 2TB, Samsung 980PRO 2TB. WD GOLD HDD 8TB
Display(s) Corsair XENEON 32UHD144 32" 4K UHD gaming monitor
Case Cooler Master HAF
Audio Device(s) Creative Sound Blaster AE7 + Logitech Z-5500 500W 5.1.
Power Supply Corsair AX850 Titanium.
Mouse Logitech MX Master 3
Keyboard Corsair K95 RGB
Software W10-11 Enterprise- Linux Mint 22.1 Cinnamon Edition.
There is nothing wrong with your system or video card, it just switch back to slower PCIE lanes because you not use it at moment.
With the question mark in GPU-Z it will do a graphics test and then you will see it switch to FULL PCIE.
2,282 (2.66/day)
Brazil
Processor AMD Ryzen 7 5700X3D
Case Lian Li Lancool 216
Mouse Razer Viper Ultimate
Did you see if GPU-Z changes it under load?
leeocf
13 (0.02/day)
This happened after I installed a new watercooler and installed the Armory Crate.
Is there any fact connected to this?
I already ran 3D mark and GPU-Z stays the same
Solaris17
27,198 (3.83/day)
Alabama
VR HMD Quest 3
I dont think they go down to 2x. I think x4 is the PCI-E step down speed. Do they allow step down to x2?
866 (1.20/day)
Belgium
Then you either use the wrong PCI slot, or bios setting wrong. Remember you can't have another card placed in an other X16 slot on your motherboard. If you do the lanes will be shared with your video card.
My motherboard has three x16 slots, if i use the other places and a video card, then all available x16 lanes will be shared with the tree slots.
In my system if i not use the video card it switches back to X16 1.1. So it must be some bios setting i guess.
leeocf
13 (0.02/day)
See, I have only one video card plugged into the PCI Express slot in the image below.
In the BIOS, where could I configure correctly?
866 (1.20/day)
Belgium
I think you are using the wrong slot, it should be in the upper slot. I think your card is now places in pciex16 1.2 and it should be in 1.1.
My motherboard is also ASUS and video card should ALWAYS be placed in the first slot.
leeocf
13 (0.02/day)
I'm using this slot. Look image
866 (1.20/day)
Belgium
Strange, are you sure you tested it with the question mark? It should switch to full pcie then. If not, either bios setting.
If not BIOS then there's a motherboard problem.
leeocf
13 (0.02/day)
Yes I tested.
Where should I change it in the BIOS to make it work correctly?
866 (1.20/day)
Belgium
In the BIOS go to ADVANCED/ONBOARD DEVICES CONFIGURATION, there a lot of settings, it should be on auto or default. If you are not sure, choose in the bios for default settings, save and restart. It that all not helps you, then there's a problem with your MOBO.
1,755 (1.16/day)
Would any M.2 NVME drives cause the primary 16 lane PCIe slot to lose lanes?
866 (1.20/day)
Belgium
Here's a screenshot in default it should more or less look like this. It's a different motherboard so some setting will be different or not there for you.
No it has nothing to do with that, that uses other lanes directly from CPU or chipset. You can place anything you want, it has no influence on your video-card:).
leeocf
13 (0.02/day)
I have two NVME drives in motherboard. Is that it?
My BIOS is ROG. Only GEN 1, GEN 2, GEN 3, GEN 4 and GEN 5 appear. In Bifurcation mode do I put Auto or X8?
866 (1.20/day)
Belgium
No your NVMe uses other lanes, not shared with your video-card. It should all be in auto mode. Don't use other slot's available, are they empty and just a video card?
3,763 (1.72/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Disable PCIE express power saving options in the bios in case they are breaking the negotiation speed. There is probably 3 or 4 of these options, to keep it simple disable them all. Might be labelled as ASPM.
866 (1.20/day)
Belgium
You said you did use another video-card and same result? If all settings here does not change anything, i guess there's a problem with your MOBO.
Could even be broken or damaged pins in the CPU socket.
W1zzard
Administrator
28,115 (3.72/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Any chance there's damage on your card near the socket area? Other card at x2 too? Then it's your motherboard. Also check inside your CPU socket. The lanes from the graphics card go straight into your CPU
866 (1.20/day)
Belgium
Another possibility is damaged traces on the motherboard going to the video-card slot, check that too.
If all okay then i think this will be an RMA case... :mad:
leeocf
13 (0.02/day)
Is there a possibility that the problem is processor? Remembering that I used another processor on the motherboard and even so it stayed at X2. I would like to know if it can be both, both motherboard and processor.
