- Jan 31, 2011
- 2,221 (0.43/day)
System Name | Ultima |
Processor | AMD Ryzen 7 5800X |
Motherboard | MSI Mag B550M Mortar |
Cooling | Arctic Liquid Freezer II 240 rev4 w/ Ryzen offset mount |
Memory | G.SKill Ripjaws V 2x16GB DDR4 3600 |
Video Card(s) | Palit GeForce RTX 4070 12GB Dual |
Storage | WD Black SN850X 2TB Gen4, Samsung 970 Evo Plus 500GB , 1TB Crucial MX500 SSD sata, |
Display(s) | ASUS TUF VG249Q3A 24" 1080p 165-180Hz VRR |
Case | DarkFlash DLM21 Mesh |
Audio Device(s) | Onboard Realtek ALC1200 Audio/Nvidia HD Audio |
Power Supply | Corsair RM650 |
Mouse | Rog Strix Impact 3 Wireless | Wacom Intuos CTH-480 |
Keyboard | A4Tech B314 Keyboard |
Software | Windows 10 Pro |
If its stable on idle and on load i guess its fine. Offset mount on our arctic liquid freezer is basically an optional feature for Ryzen 3000/5000 cpus where the core of the CCD is offset the main package chip, using the offset mount makes the cold plate on the center so it will cool optimally.I'm running this config for months now. Had to adjust two times because of a WHEA but never again. It's running fine and stable, I ran long cb23 and prime sessions to double check. No problems at all. I do not know what Rev4 offset is, so I guess not
You can take a look at the manual and/or under your arctic cooler box and see what revision it is. The 4th revision is the best one so far for Zen3, if you dont have it, i think you can just ask arctic about it and they will send you rev4 kit.
