5800x (and other Zen 3 chips) PBO settings/Temperature fix
1,124 (0.17/day)
Chicago
Processor Amd Ryzen 5 5600x kryonaut paste
Motherboard Asus Prime X570 P bios 4021
Cooling Thermaltake Water 3.0 360mm (top mounted for exhaust) 3 Thermaltake 140mm riing rgb case fans
Memory G.Skill Trident Z Neo DDR4 3600 cl16 2x16 dual rank
Video Card(s) Sapphire Nitro+ RX 5700XT OC
Storage Seagate Firecuda 520 500gb NVMe PCIE Gen4 x 4 boot drive XPG S70 Blade Gen 4 x 4 NVMe gaming drive
Display(s) MSI Mag321CQR 32 inch curved 144 hz 1ms
Case Thermaltake View 31
Audio Device(s) Corsair Void USB RGB Dolby Digital 7.1 Headphones
Power Supply Thermaltake Grand RGB 750w
Mouse Corsair Harpoon RGB
Keyboard Corsair K55 RGB
Semi-automated undervolting, less volts means less heat - so higher boost
Do it too far and it's unstable at idle, usually
Mussels whats man. ts been awhile. Yeah I've been reading about it. Might try might not. I'm not quite the tinkerer I used to be lol. Last night I put a -5 all core and didnt see anything.
I've gotten up 4,915mhz on my 5600x with a slight Bus speed bump. You have a golden sample like mine in CTR :D:toast:
Might does that too usually I read HWinfo for the real.
Hope so. The game was just loading thats why the temps are so low. It maxes out around 63c. But still getting 4800-4825 all core boost. What did you bump the bus up tp?
taakefyrsten
4 (0.00/day)
In case someone with the same questions as I do come and read here. These are some data for reference about thermals and performance.
5800X
3080TI Air cooled
Gigabyte Aorus elite ax v2 rev 1.0
Meshify C - 2x NF-A14 Front intake, NF-A14 top rear exhaust, NF-A12x25 Rear exhaust. Fans running at 40-50% until 65c, then slowly ramp up to 100% at 85c
Tested at ~22c ambient
PPT 111 EDC 74 TDC 117
Curve offset: -21 -15 -30 ... -30
CPUZ
SC: 660-670
MC: 6850
R23
SC: ~1600
MC: 153XX-low 15400 | NH-U12A - 75-76c | SilentiumPC Fera 5 DualFan 80-81c
R20
SC: 624 | NH-U12A - 64c
MC 6020 | NH-U12A - 75c
PPT
130w EDC xx TDC xx
Cinebench R23 multicore
NH-U12A - 89.8c - 15300
Cyberpunk 10 minute idle
NH-U12A - 74-75c
SilentiumPC Fera 5 DualFan 77-82c
Metro Exodus numbers of the top of my head from playing the game
NH-U12A - 63-70c
SilentiumPC Fera 5 DualFan 65-75c
Jedi Fallen Order
NH-U12A - 64-73c
SilentiumPC Fera 5 DualFan N/A
Note that the Fera5 was a fantastic cooler for the price, but the single tower cooler saturates very quickly and the fan has to ramp for minor stuff such as opening a program which the U12A doesn't have to ramp for.
1,124 (0.17/day)
Chicago
So I messed with this all weekend on and off with no positive results so I got fed up and put pco back to default settings and disabled it. Now my 5600 is boosting 200 mhz slower. Rebooted and went into bios and reset to optimum settings and I'm still down 200 mhz. Kinda stumped. But I was thinking with over 2 dozen bios changes would cmos reset be in order? Also I seen that mussels recommends using the pbo section in Ai tweaker. Everything I've read says to use pbo in the advanced menu so what gives? What is everybody here using? Any input would on both questions would be appreciated.
de.das.dude
Pro Indian Modder
9,158 (1.71/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| J1nnx took Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
maybe i can help? what are you boosting to?
1,124 (0.17/day)
Chicago
I was 4.85ghz. Now 4.65-4.7.
de.das.dude
Pro Indian Modder
9,158 (1.71/day)
VR HMD ;_;
well mine does 4.65 with default settings on all cores.
i have never seen it go to 4.85.
At 4.65 it is already at 110W consumption. which is almost double the designed power.
are you sure it was on all cores? because few cores goes that high
1,124 (0.17/day)
Chicago
Look at my screeshot on page 13. Do you have autooc enabled?
157 (0.13/day)
Portugal
Processor Ryzen 7 5800x
Motherboard Msi b450 tomahawk max II
Cooling Artic liquid freezer II 240mm
Memory 2x8Gb B-die @3800 cl14/ 53ns on aida
Video Card(s) Evga 3060 ti ftw3
Storage M.2 Samsung 970 Evo Plus 250gb + 1tb ssd
Case Corsair 275r airflow
Audio Device(s) Hyperx
Power Supply Seasonic core gc 650w 80 plus gold
Mouse Zowie ec2-a
Keyboard Trust
Benchmark Scores Cinebench r20: 631/6232 Cinebench r23: 1628/15901 CPU-Z: 672/6960 SotTR:221FPS
1,124 (0.17/day)
Chicago
Yep on the latest. 4021
Mussels
Freshwater Moderator
58,413 (7.88/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
You have to add the +200Mhz in PBO to get the higher boost
If you're on the new agesa, it boosts lower than previous BIOS did
1,124 (0.17/day)
Chicago
What's up mussels. Yeah 200mhz is enabled. I was gonna clear cmos but then I thought maybe it's the ambient Temps up here in Chicago. It was in the 50's for 2 days. Colder than hell tonight though. I'll check it out tonight.
I'm on bios 4021 stable. Are you talking about the beta you flashed?
What about ai tweaker verses advance menu for pbo Mussels? I think most use advanced pbo menu for overclocking. Your findings?
de.das.dude
Pro Indian Modder
9,158 (1.71/day)
VR HMD ;_;
that game screenshot one?
its not even loading all the cores. so that screenshot really has no value. PBO works by optimizing how much cooling you get under load, while taking into account your silicons TDP etc.
since its very hard to reach tdp with a few cores, that limit wont be hit and you will almost always get higher clocks.
run some aida64 stress test or cinebench to load all cores at 100%. that is the real boost clock and use hwbot to monitor.
i have seen it randomly jump to 4.8ghz on few cores while gaming, but that is meaningless.
the real clock is what you end up with after 30mins of full load. for me its 4.65 and i dont have a really good radiator. just a normal 100$ antec one with good fans in push pull as an intec.
Plus its stupid hot here. :D
157 (0.13/day)
Portugal
Mouse Zowie ec2-a
Keyboard Trust
Maybe it's not a bug maybe it's a "feature"
If you do some research with last agesa bios most of people can't get the max boost you got in the past.
1,731 (0.87/day)
Processor 7800X3D 2x16GB CO
Motherboard Asrock B650m HDV
Cooling Peerless Assassin SE
Memory 2x16GB DR A-die@6000c30 tuned
Video Card(s) Asus 4070 dual OC 2610@915mv
Storage WD blue 1TB nvme
Case Corsair D4000 Airflow
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Benchmark Scores Superposition 8k 5267 Aida64 58.5ns
There is a voltage limit in agesa 1.2.0.5 that is a bit lower than previous agesas. If you don't use CO then boost might be limited due to this.
1,124 (0.17/day)
Chicago
I was wondering why it was boosting when not all were loaded. But still something has changed because it doesn't do that since I tried undervolting. Weird.
OneMoar
There is Always Moar
8,802 (1.63/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
not sure I have a problem with the voltage limit of ~1.46v
what I really want is a way to tell pbo to stop going into boost clocks when the cpu isn't doing anything
at <20% utilization it should not be boosting all cores
157 (0.13/day)
Portugal
Mouse Zowie ec2-a
Keyboard Trust
I think this is normal. On my system it's normal and I think it's because even at<20 utilization the cpu need to handles a lot of things so I think it's normal but I'm not an engineer.
Mussels
58,413 (7.88/day)
Oystralia
I mean, i've got an entire two asus boards here: of course yours may behave different. I think its mostly a problem if the two pages have different settings - i think i've seen PBO settings listed upto four times on one board.
The new AGESA does boost less, but in reality the performance loss is tiny. It's going to reduce those temp spikes for a lot of people as well
1,124 (0.17/day)
Chicago
Been tuning each core a little bit. Probably a stupid question but here goes. In ryzen master cores 2 and 4 are preferred and all cores are numbered 1 through 6. In curve they are numbered 0 through 5. Is core 2 from ryzen master really core 1 in curve?
OneMoar
8,802 (1.63/day)
Rochester area
id like to test it but the VDDG voltage control is still broken :banghead: I have opened multiple tickets with gagablow and they keep closing them saying they can't reproduce the issue despite multiple other people also opening tickets
119 (0.10/day)
System Name Phenomenal1
Processor Ryzen 7 5800x3d
Motherboard MSI X570 Gaming Plus
Cooling Noctua NH-D15s with added NF-A12x25 fan on front
Memory Predator Vesta 32GB (2 x 16GB) DDR4 3600 BL.9BWWR.300 B-Die @3733 CL14
Video Card(s) PNY XLR8 RTX 4090 VERTO EPIC-X Triple Fan
Storage Boot SSD: SATA 500GB - 1tb + 4tb pcie3 nvme / Spinning Drives: 2tb + 6 tb
Display(s) Gigabyte M27Q 27" 1440P 170 Hz IPS BGR monitor
Case Fractal Torrent - Black
Audio Device(s) Realtek ALC1220P
Power Supply Super Flower Leadex VII XG 1000W
Mouse Razer Viper
Keyboard Razer Huntsman V2 Optical
Benchmark Scores Time Spy - 28594 https://www.3dmark.com/spy/51010148
The way to handle that is to look at whatever you're using, no matter what utility or bios, and see what number the core count starts and ends with, as long as it shows the correct number of cores and compare them that way. Ryzen Master starts at 1 and in your case ends in 6. In the bios the core count starts at 0 and ends with 5. So yes, core 2 in Ryzen Master is core 1 in the bios. In any case where the number starts with 1 compared to something where it starts with 0 it will be that way.
1,124 (0.17/day)
Chicago
Thanks man. I thought so but just wanted to make sure.
5,583 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
in PC world 0 is always the first number so 0 1 2 3 4 5 6 so yes core 1 is actually the second core on your CPU
119 (0.10/day)
Mouse Razer Viper
Obviously not because Ryzen Master starts at core 1.
495 (0.23/day)
Texas
System Name i'm done in
Processor AMD 5950x
Memory GSkil 64gb 3600 cl16
Video Card(s) Power Color R7900xtx Hell Hound oh hell ya
Storage 2x wd sn770 2tb 1-4tb wd- hd 2x8tb wd hd actually 1 fire cuda
Display(s) LG Ultra Gear 1440p 32" 165hz hdr monitor might go oled
Case Corsair 4000D Air Flow
Power Supply EVGA SuperNOVA 1000w G5 80+ Gold
Mouse logitech and roccet wcord
Keyboard logitech
Software W10 forever
Did not Intel start the Core 0 naming scheme and some but not all label it as they wished? You can always use cpu-z if there’s any doubt
