5800x (and other Zen 3 chips) PBO settings/Temperature fix
1,772 (0.88/day)
Processor 7800X3D 2x16GB CO
Motherboard Asrock B650m HDV
Cooling Peerless Assassin SE
Memory 2x16GB DR A-die@6000c30 tuned
Video Card(s) Asus 4070 dual OC 2610@915mv
Storage WD blue 1TB nvme
Case Corsair D4000 Airflow
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Benchmark Scores Superposition 8k 5267 Aida64 58.5ns
That would be great only I have no Idea what to look for or where to look, or how to understand what I click on when I do find something, most of it looks like binary gibberish and I have no idea how to read binary.
You must find the windows logs - system. Find the time of the reboot and you can see what core crashed. Generally the report as WHEA18. If I were you I would start with a baseline like -10 on all. Find which ones crash, the ones that don`t try running -15 or higher. Corecycler can be useful for many :)
tabascosauz
8,226 (2.33/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Event Viewer > Custom Views > Administrative Events > sort by Source column to find WHEA-Logger events
For core-related errors you're looking for either Unknown Source or Cache Hierarchy as the Error Type. The APIC ID will tell you what core is the problem - iirc it doesn't count SMT threads (don't quote me on that) and starts from 0 like most programs, so you'd be looking at a number between 0 and 5.
The one below is a Bus/Interconnect so a different IF-related type, and not core-specific so APIC ID 0
1,212 (0.61/day)
Canada
System Name New compy
Processor AMD Ryzen 5800x3D
Case Thermaltake Core v71
I have no event id 18 nor whea logger events in the requested folder, there are 39k events in the list, my whea list is error free.
1,772 (0.88/day)
freeagent
9,817 (4.18/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Ppt is important for getting single core up, as well as for sustained all core loads. In my limited experience curve is based off of your ppt tdc and edc settings. If those aren’t right then curve won’t work well.
496 (0.23/day)
Texas
System Name i'm done in
Processor AMD 5950x
Memory GSkil 64gb 3600 cl16
Video Card(s) Power Color R7900xtx Hell Hound oh hell ya
Storage 2x wd sn770 2tb 1-4tb wd- hd 2x8tb wd hd actually 1 fire cuda
Display(s) LG Ultra Gear 1440p 32" 165hz hdr monitor might go oled
Case Corsair 4000D Air Flow
Power Supply EVGA SuperNOVA 1000w G5 80+ Gold
Mouse logitech and roccet wcord
Keyboard logitech
Software W10 forever
freeagent
9,817 (4.18/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
My curve isn't perfect, but its fairly tight overall I think.
Edit:
Playing with Core Cycler now..
Edit again:
Well, it’s just as I suspected. My CPU is shit. It won’t even do +50 with an all core -15 or 10.. which loads it at 4950 in core cycler. But for everything else my original settings were cock solid, except core cycler. I could bench, fold, crunch something.. game do whatever with no errors, bluescreams, hardware errors.. nothing
The last time I played with CC I think it failed at stock settings.
Should I RMA it?
Mussels
Freshwater Moderator
58,412 (7.85/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
seems like the curve just gives a more effect clock speed on all cores doesn't seem to do much for single thread for me.
Yes, that's what it does.
It lowers the wattage/amperage at any given clock speed, and those limits are most easily reached multi threaded.
Free: personally, i don't believe in RMA'ing because it wont overclock.
-15 is a large undervolt, few chips are stable past -10 (remember they're unstable at IDLE, so many people make bullshit claims and say its stable when its not)
freeagent
9,817 (4.18/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Ok good, thank you :)
I wont RMA it because it was working fine for the way I used it. I have flashed to the latest AGESA, went back to a clean install of 11. Boost and voltage are waaay down, but it still runs ok. I am not going to fuss over it.. I ran it completely stock and it felt just fine. 1600 1:1, factory limits and boost.. it was ok. Games were fine, it wasn't a massive loss of performance.. because I play at 60fps I didn't notice any loss lol.. Power has gotten a lot more expensive here, and will continue to do so..
1,212 (0.61/day)
Canada
Thanks for trying to help, now testing with -10 -5 -5 -10 -15 -10 after crashing more aggressive undervolts on the curve all over, I'm learning this new shit as I assume many of you already did by trial and error, figuring out what I can do and what I can't by testing both low and heavy loads and figuring out what works and what doesn't.
Passed 12 rounds of p95 because I forgot it was on.
1,064 (0.61/day)
System Name S.L.I + RTX research rig
Processor Ryzen 7 5800X 3D.
Motherboard MSI MEG ACE X570
Cooling Corsair H150i Cappellx
Memory Corsair Vengeance pro RGB 3200mhz 32Gbs
Video Card(s) 2x Dell RTX 2080 Ti in S.L.I
Storage Western digital Sata 6.0 SDD 500gb + fanxiang S660 4TB PCIe 4.0 NVMe M.2
Display(s) HP X24i
Case Corsair 7000D Airflow
Power Supply EVGA G+1600watts
Mouse Corsair Scimitar
Keyboard Cosair K55 Pro RGB
like mine error on core 3 with in 3 minutes in prime95
Later on, error on core 6 with 18 minutes in prime95.
These chips are so weird.
5,600 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
Edit:
Edit again:
Should I RMA it?
No just stop using Core Cycler as obviously that's the issue
freeagent
9,817 (4.18/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
I did, but again like the last time it kind of bugs me.
I also went back to the old voltage pumping bios.. still on 11 though.. so pretty.
Mussels
58,412 (7.85/day)
Oystralia
I'm thinking the lowered voltage/amperate is related to the intended changes for the 5800x3D
1,124 (0.17/day)
Chicago
Processor Amd Ryzen 5 5600x kryonaut paste
Motherboard Asus Prime X570 P bios 4021
Cooling Thermaltake Water 3.0 360mm (top mounted for exhaust) 3 Thermaltake 140mm riing rgb case fans
Memory G.Skill Trident Z Neo DDR4 3600 cl16 2x16 dual rank
Video Card(s) Sapphire Nitro+ RX 5700XT OC
Storage Seagate Firecuda 520 500gb NVMe PCIE Gen4 x 4 boot drive XPG S70 Blade Gen 4 x 4 NVMe gaming drive
Display(s) MSI Mag321CQR 32 inch curved 144 hz 1ms
Case Thermaltake View 31
Audio Device(s) Corsair Void USB RGB Dolby Digital 7.1 Headphones
Power Supply Thermaltake Grand RGB 750w
Mouse Corsair Harpoon RGB
Keyboard Corsair K55 RGB
+200
-15 crashes any higher
-19 fastest core
-23
-19 fastest core
-23
-23
power limits
130
80
130
these power settings seem high compared to others but running occt the ppt and the 3rd one (edc?) are close to maxing out. Single core boost isnt quite what it was before this journey but temps are down 10-12 degrees. Multi core is pegged at 4.74 at 72c though. One run of occt I know I seen cores 2 and 4 flash 4.95 for a second or two. I want to get to 5ghz single core. Any ideas
1,064 (0.61/day)
Display(s) HP X24i
+200
-19 fastest core
-23
-19 fastest core
-23
-23
power limits
130
80
130
The only way to get higher on a 5600x is to use a slight bump in bus speed. Which means you have to lower you ram divider before you even try a higher bus speed to counter act it. It won't take much to get a decent bump anyways even something like 100.03 is still a bump for Ryzen. I know I got pretty high on my bus speed, but I'm not using an NVMe SDD. I'm using a Sata SSD. I'm not sure what the usually is for high bus speed, but you don't need to get anywhere near 101.0 on bus speed. Tiny bus speed increments in Ryzen can throw up a lot of speed increase.
1,124 (0.17/day)
Chicago
Would raising it slightly effect nvme drives?
Even with pbo limits disabled?
freeagent
9,817 (4.18/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
I dropped my 5600X in and ran CC with no problems, I guess my 5900X just does not like that program..
Core 3 was cranky with 4850, so I chose +150 instead..
1,212 (0.61/day)
Canada
I tested with CC and had a core 2 fail with +200 even when undervolt was 0 for that core (-5 0 -5 -10 -15 -10 curve) so I'm just going to ignore it since 12 rounds of regular p95 passed. CC is large fft, my cpu ran at 71 degrees during the test.
freeagent
9,817 (4.18/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
I played with it for a couple of hours, it was pretty depressing. For absolutely everything else it never once gave me a problem with my settings. But.. I am enjoying my 5600X for now. My system is so quiet. Even when it gets a bit busy they barely lift from idle. Unlike 5900X which breathes fire lol.
1,212 (0.61/day)
Canada
I'm testing an extra -2 per core (-12 -7 -7 -12 -17 -12 curve) @ +150 and core 2 crashes again in CC. Dif in single core is 8-10 points in cpuz so not a huge drop vs +200 but CC still doesn't like it, I'm just going to go back to +200 and pretend CC isn't a thing.
1,772 (0.88/day)
Seems only 5600X is the quiet one of the 5XX0X-brotherhood for now. I have a bit of hope for 5700X and 5600, they should be good.
Or 5950X is possibly the best of cooler is good, lower allcore clocks might be the reason:
mattferris
10 (0.01/day)
I haven't gotten above 82C on prime95 with just Small FFT with AVX on, cinebenchr23 is 10C lower it's also like 300mhz higher lol
My current issues seems to be my VRM loop 1 is hotter then VRM loop 2 whey they should mirror each other. I wonder if it just has bad contact.
Just now change my EDC from 125 to 85 = better Cinebenchr23 score both single and Multi. guess I'll try to lower the wattage and see what it gets.
Prime95 is a weird load compared to Cinebench or other more traditional workloads. The heavy AVX Prime95 computations will slam you into your TDC limit before PPT or EDC (unless you have PPT and EDC lowered sufficiently). This can lead to weird outcomes like you saw above.
1,064 (0.61/day)
Display(s) HP X24i
I've been doing a little tinkering I let the motherboard set all the setting by just hitting the + button in the bios from auto
this is what it set
PPT 500W
TDC 143a
EDC193a
Then I ran Prime95/cinbenchr23 it only used this % of those settings on HWinfo.
500w 25%
143a 56.5%
193a 59.9%
which then looks like this
ppt 125w
TDC 78a
EDC 115a
I did notice that even if I switch the TDC with EDC
PPT 125w
TDC115
EDC 78
PPT won't make it up past 87.5 watts then. Think I'm going to test some static overclocks now
freeagent
9,817 (4.18/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Using 200/140/180 with my 5600X capped at +150 can put out over 140w PPT using Linpack Xtreme. The most I saw was just over 150w PPT on 5600X. Static OC should be easy on that CPU.
