Mussels
Freshwater Moderator
- Oct 6, 2004
- 58,412 (7.85/day)
- Oystralia
System Name | Rainbow Sparkles (Power efficient, <350W gaming load) |
Processor | Ryzen R7 5800x3D (Undervolted, 4.45GHz all core) |
Motherboard | Asus x570-F (BIOS Modded) |
Cooling | Alphacool Apex UV - Alphacool Eisblock XPX Aurora + EK Quantum ARGB 3090 w/ active backplate |
Memory | 2x32GB DDR4 3600 Corsair Vengeance RGB @3866 C18-22-22-22-42 TRFC704 (1.4V Hynix MJR - SoC 1.15V) |
Video Card(s) | Galax RTX 3090 SG 24GB: Underclocked to 1700Mhz 0.750v (375W down to 250W)) |
Storage | 2TB WD SN850 NVME + 1TB Sasmsung 970 Pro NVME + 1TB Intel 6000P NVME USB 3.2 |
Display(s) | Phillips 32 32M1N5800A (4k144), LG 32" (4K60) | Gigabyte G32QC (2k165) | Phillips 328m6fjrmb (2K144) |
Case | Fractal Design R6 |
Audio Device(s) | Logitech G560 | Corsair Void pro RGB |Blue Yeti mic |
Power Supply | Fractal Ion+ 2 860W (Platinum) (This thing is God-tier. Silent and TINY) |
Mouse | Logitech G Pro wireless + Steelseries Prisma XL |
Keyboard | Razer Huntsman TE ( Sexy white keycaps) |
VR HMD | Oculus Rift S + Quest 2 |
Software | Windows 11 pro x64 (Yes, it's genuinely a good OS) OpenRGB - ditch the branded bloatware! |
Benchmark Scores | Nyooom. |
Yep, its a great little feature. I played around with it here too, but my chips low voltage at 4.6 all core just sealed the deal on that one... until i run into something that actually needs more single threaded gruntI'm not sure if I should post this here or if a new thread should be started, but yesterday I watched a video (that I link to here) showing that if you set CPU Boost Clock Override to -200 in the bios, so that it runs at 4650 mhz, it lowers the temperature by a lot, so I tried it using Cyberpunk 2077 as a load. With a Noctua NH-D15s cooler and PBO power limits set to stock disabled settings (142, 95, 140) and with Curve Optimizer enabled and CPU Boost Clock Override set to +200, my 5800x ran at 78c. Next I tried only changing CPU Boost Clock Override to -200 and my 5800x's temperature was 68c, so 10 degrees cooler (at CPU Boost Clock Override set to 0 it was 74c). The performance wasn't noticeably different, just a few fps slower, so I thought I would mention this. The video's thumbnail shows -20c, but for me it was -10c, but other than that I though it was useful information. I do realize that lowering PBO limits will allow single core loads to boost much higher than setting boost clock override to -200.
As for me, nowadays I'm running my 5800x with PBO power settings at 142, 95, and 140 with no boost clock override, even though it's stable at +200, and tuned curve optimizer.
