- Jun 24, 2015
- 8,208 (2.34/day)
- Western Canada
System Name | ab┃ob |
Processor | 7800X3D┃5800X3D |
Motherboard | B650E PG-ITX┃X570 Impact |
Cooling | NH-U12A + T30┃AXP120-x67 |
Memory | 64GB 6400CL32┃32GB 3600CL14 |
Video Card(s) | RTX 4070 Ti Eagle┃RTX A2000 |
Storage | 8TB of SSDs┃1TB SN550 |
Case | Caselabs S3┃Lazer3D HT5 |
I'm not sure what AMD were thinking with the default voltage curve on these. I was also hitting 90c out of the box on stock. MSI has a 'Kombo Strike' option in their latest BIOS that provides three all core CO options. I now get 80c under full load using level 3. Supposedly that's a -30.
I learned about the Kombo Strike thing earlier today and kinda wish Asus had it too. Though, the convenience of tweaking CO and limits on-the-go in Windows is just too good to pass up.
Something to try before using CO is to try negative offset on the CPU in the BIOS then test if R23 score are going higher or lower.
Once you get the highest score with my 5800X its offset 0.0500V this gets the highest score any lower or higher performance drops.
Then use CO on top of that and you should have better performance.
I will definitely try that. Just still trying to figure out how this CPU behaves - it seems to behave differently in a lot of ways than any other Zen2 or Zen3 CPU I've come across. Some people on reddit and OCN were speculating that the cache is calling the shots on how boost behaves. Makes some sense. ST boost is very lazy compared to other Zen3. Whereas 5900X might spike close to Fmax just opening an application (lightning fast), 5800X3D just kinda sits around and so the difference is definitely felt.
I have not succeeded in hitting 1900Mhz Fabric yet. Tried a lot of things, just won't train. Funny because at 1800 the VSOC and VDDG characteristics are pretty much identical to my 5900X but it just refuses to train 3800.
