7700X lapping, replace IHS or direct die cooling?
179 (0.19/day)
too close to Russian borders
System Name Phat Cat
Processor Ryzen 7 5700x3d
Motherboard MSI B550 Pro
Cooling ID Cooling SE-224XT with 120mm Noctua, 2x200mm Noctua front, 2x140 Noctua back and inside
Memory 32GB Kingston Fury 3200mhz CL16
Video Card(s) Asus RTX 3070 TUF OC
Storage Kingston NV2 256GB boot + Kingston NV2 2 TB storage
Display(s) Dell G3223D
Case Thermaltake Commander C32
Audio Device(s) Audigy 5/RX for optical SPDIF out to Audigy 2 Bay + Sennheiser HD569
Power Supply Thermaltake Toughpower GF1-750W
Software Windoze 11
I wanted to remove/shave also 1.5-2mm from the Zen 3 IHS but after some time spent learning more about the issue i gave up. The problem is not the IHS but the die size and placement. Also from die size and heat generated at such low surface, thermodynamics laws dont help also. The heat propagation from such a small area it's not helped by the placement and the thickness of the IHS.
Yes a delid will help keeping at bay the temps, but the issue comes from desing. AM4 comp...
Your cooler also has to transfer the heat 5 times.
1. From cold plate to heatpipes
2. From heat pipe to vapour
3. From vapour to heat pipe
4. From heatpipe to fin stack
5. From finstack to air
Reduced heat exchange cycles like in the water block can help a bit but not much if the heat source is not centered on the coldplate.
Der8auer had a idea for this that works fine. Direct die waterblock. As you cans see here the finstack offset.
Now with enough spare time and money some issues can be solved. But at the end of the day you still have to answer the question, "does it worth it?".
2,097 (4.28/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) 1080P 144hz
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
The original poster just wants to do it. To work with his hands. I say go for it.
It's worth time to gain experience points. The accomplishment could be 10c temp drop. Maybe only 4c on average. It's something to do!
Delid? Lap it off. Nice course grit 200 to 400g. Heat is a little too invasive for most people, but it's not actually necessary. Lapping is a viable solution for delidding.
Don't tell anyone I said that. Delid tool companies might start to dislike me much.
179 (0.19/day)
Software Windoze 11
now if AMD would use this instead of current...
I cant see why to center the IO-DIE on the IHS since it's a 20W part, compared to CCX...
2,097 (4.28/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
That is grinding, not lapping.
I wish you could see all the wiring under the chips, you cannot just move or rotate stuff at will.
I've delidded, grinded, lappeded, grinder wheel, torch, and everything in between IHS plates. Dozens and dozens of modifications.
Last one I lapped, ahem grinded, with my hand no less, on the garage floor. I know what I'm looking at.
Haha. Think I haven't been there and done something, well you'd guessed wrong! XD
Edit, forgot to mention razor blade the pcb in half.... roughly. Heh. It's in the trash, I didn't hold onto this one.
TPU exclusive. Never before seen elsewhere lol.
dgianstefani
TPU Proofreader
5,349 (2.03/day)
Swansea, Wales
Processor Ryzen 9800X3D @ 5.5ghz all core 1.2 V, Thermal Grizzly AM5 High Performance Heatspreader/1185 G7
Benchmark Scores Legendary
No need to lap, just replace stock IHS with AM5 High Performance Heatspreader from TG.
Temps are good.
dgianstefani
TPU Proofreader
5,349 (2.03/day)
Swansea, Wales
Heatspreader and delidder from TG cost $125, that is 35% over the current price of 7700X ($350 at Newegg). Is that reasonable???
You also loose the warranty.
And you don't lose the warranty with lapping? You also don't need to use the delidder.
8,951 (4.03/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Manual lapping evenly is easy as long as you take it steady and use marker pen to record progress to ensure you're balancing how much material you move from each side evenly.
It doesn't have to be perfectly level with the die unless you are aiming for <500 microns of IHS left. After all, the original IHS isn't even flat, how could it possibly be perfectly level - you've got adhesive to worry about with AM5 too, so IMO you should just avoid getting too thin - be happy with the benefits of removing a good fraction of the IHS and getting a mirror finish that will let you get away with near-zero, ultra-thin layer of paste/pad/LM.
82 (0.19/day)
System Name Ryzen AM5 + Radeon 7000
Processor R7 7700X
Motherboard ASUS ROG STRIX B650E-E WIFI
Cooling AK500 ZERO DARK + 2x Arctic 120MM static opt. PWM fans + KRYOSHEET
Memory GSKILL Flare X5 32GB (2x16GB) DDR5-6000 CL36
Video Card(s) ASUS TUF Gaming RX 7700 XT OC 12GB
Storage WD Black SN750 500GB (OS Drive) + CRUCIAL P5 PLUS 2TB (Game Drive) + (20) Crucial MX500 250GB
Display(s) LG 34" 1440p ULTRAWIDE 160Hz (main) + 2X LENOVO 27" 1080p 75Hz (sides)
Case FRACTAL DESIGN Pop Air w/ 3x140MM + 2x120mm ARCTIC PWM fans
Power Supply DEEPCOOL PQ850M 850W Gold
Mouse Logitech G502 Gaming X Wired
Keyboard Microsoft ANB-00006 Wired Slim Keyboard
Software WINDOWS 11 PRO
Got my 7700x for $205 so that puts me right at MSRP! Hate to say it, but warranties already out the window...
1,143 (1.71/day)
You mean HALF of the MSRP, did you get it used? It seems that you already saved some money for the High Performance Heatspreader from TG - it looks nice BTW.
82 (0.19/day)
Processor R7 7700X
Got the CPU and my motherboard from Microcenter open box. Motherboard (ROG STRIX b650e-e) was only $175! Their list price at the time was $350 and have seen it for $400+.
Motherboard had a couple of bent pins on the board connectors but was mint otherwise. I was patient and got really really lucky...
As long as they keep letting me inspect before purchasing, I don't mind open box.
Literally felt like I won the lottery walking out of there. Think the guy checking me out was pretty annoyed.
I am pretty sure this "BoggledBeagle" guy just goes around all the threads just warranty trolling for the lols
Every time I see him, he is saying "oh no, the warranty" in 100 different ways and for instance going onto a delidding/lapping thread and talking about warranty like any of us care about that here...
Gives the occasional tidbit of info, but that's about it. Mostly just trolling for reactions IMO.
Either that or he is genuine and just needs to learn to read the room, and is terrified of warranties!
1,143 (1.71/day)
I realised it is almost 10 years since I played with any CPU (Ivy bridge i5 3570 - it got full treatment, deliding, liquid metal and lapping, temps improved by 20°C). Time flies ... :(
82 (0.19/day)
Processor R7 7700X
I know it may be a waste of money in some respects, but the knowledge and experience I have gained over the years is priceless to me and so much fun! Has also help me in spades in my career and just helping others. Each time I do better and better with less mishaps along the way. Been quite a while since I have actually killed something, at least that I couldn't fix.
Also I see you say stuff like this occasionally and it just wins me back... confusing to see this after the warranty stuff, but if this is true I know part of you misses the adventures. Specially the triumphant victories!!! The only thing that I have found to rival this feeling for me is when my kids were born or tell me they love me and I can tell they are not just saying it to get something.
2,097 (4.28/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
dgianstefani
TPU Proofreader
5,349 (2.03/day)
Swansea, Wales
With honesty.
For X3D.
Is it actually worth it to "re-lid" a cpu that cannot be overclocked? I'd hope a temp reduction would bring frequency. 5.6ghz?
BCLK OC and memory controller stability.
2,097 (4.28/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
1,143 (1.71/day)
Ivy Bridge was really frustrating after Sandy, because it had inside some horrible TIM after soldered Sandy and the temps were awfull. So it pushed even the less adventurous people like me to do something about it. I have a new Intel CPU now and at least in temps there is nothing wrong with it, it is easy to cool. So for no real reason I am not going to mess with it (for example lap it for 2°C difference). It was pretty expensive too and I am keeping the warranty... :)
2,097 (4.28/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
Ïvy Bridge was really frustrating after Sandy, because it had inside some horrible TIM after soldered Sandy and the temps were awfull. So it pushed even the less adventurous people like me to do something about it. I have a new Intel CPU now and at least in temps there is nothing wrong with it, it is easy to cool. So for no real reason I am not going to mess with it (for example lap it for 2°C difference). It was pretty expensive too and I am keeping the warranty... :)
You must exit the overclocking section of the forum.
If you changed any bios setting for that cpu other than the stock configuration, you've already voided the warranty. This includes enabling Extreme Memory Profiles because the board will increase cpu values beyond stock specifications.
But, you'd OC, lie to the manufacturer and have the cpu replaced anyways I'd be willing to bet....
____
But as an overclocker whom has used DryIce cooling on my 13700K processor.... multiple times, and bench the platform just about daily.
If the 13700K ever dies on me, I'd expect it. Was only a few hundred bucks, I'll just go get another one.
9,764 (3.26/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
For something like a 7700X just a better cooler should be all that's needed, a 360mm AIO will prevent it from hitting tjmax, with these 7000 series CPUs it really doesn't matter if they run at 70C instead of 80C.
1,143 (1.71/day)
360 AIO can handle 300W, even more. 7700X produces max. 140W with PBO, you can cool that with a small air cooler!
825 (0.42/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
1 vote for direct die cooling, lapping is not gonna go well without professional equipment
446 (0.78/day)
System Name No.1
Processor Ryzen 9 9900X with custom PBO + 2200 FCLK fully stable
Motherboard B650 Gigabyte Aorus Elite v1.0
Cooling Thermaltake toughair 710 + Thermal Grizzly Kryonaut extreme
Memory Patriot Viper PVV532G740C36K @ 6200MT/s 30-36-36-63 1:1
Video Card(s) Asus TUF gaming RX 7900 XTX OC edition
Storage 1TB T-Force Z44A7 + 2TB T-Force A440 Pro
Display(s) 34 " Asus TUF Gaming VG3A series
Case Antec C8 constellation white edition
Audio Device(s) Asus Xonar AE 7.1 + Logitech Z906
Power Supply Corsair RM1000x V2
Mouse MSI Clutch GM20 Elite
Keyboard Logitech G512 Carbon
Did you just lap the surface or take some height off?
I used this to guide me but didn't go overboard, just took off about mm. All the time, I was conscious of how my deepcool AK620 would mount without the factory screws & other fittings. Lucky I had a plethora of washers lying around, so could pick'n choose to make the HS fit snuggly.
7,466 (1.05/day)
Video Card(s) Sapphire PURE AMD Radeon™ RX 9070 Gaming OC 16GB | Intel® Iris® Xe Graphics
Honestly I didn't bother with a X variant of the Ryzen 7 7700 that's why I took the non-x it's 65W it's easy to cool, I can use my Noctua NH-D15 chromax.black and if I need the performance I can just unlock it to a X variant.
Am I missing any performance? Not really if looking at tests
This was why I almost paid the same for the non-x version of my CPU and I didn't want to pay up for a 7800X3D at the time and I still don't for my 1440p gaming.
