7700X lapping, replace IHS or direct die cooling?
825 (0.42/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
I am afraid you are mixing lapping with machining. Lapping involves removing just very thin amount of material to ensure flattless and is pretty easy to do manually.
Nah, I'm talking about lapping, it's easy to achieve a lower roughness manually, but not flatness.
For flatness, it is usualld defined through total thickness variation (TTV), which could be affected by the roughness, waviness, form and parallelism of the top bottom surfaces.
A mirror finish only guarentees roughness.
635 (0.50/day)
Processor Ryzen 7 9700x
Motherboard Asrock B650E PG Riptide WiFi
Cooling Underfloor CPU cooling
Memory 2x32GB 6200MT/s
Video Card(s) ASUS Prime Radeon RX 9070 XT OC Edition
Storage Kingston Fury Renegade 1TB, Seagate Exos 12TB
Display(s) MSI Optix MAG301RF 2560x1080@200Hz
Case Phanteks Enthoo Pro
Power Supply NZXT C850 850W Gold
Mouse Bloody W95 Max Naraka
Touching 90+ on stress tests/benchmarks, CO-20+500MHz boost freq, additional negative voltage offset of 0.10 volts, gaming temps are 70 or less, scores above average for performance on that hardware.
This is just where I am currently settled, about every weekend I do some tweaking for fun
S's and G's really. I just like to tinker... this is my next itch.
Kryosheet + AK500 zero dark, was using Kryonaut paste and results are the same as new paste. Kryosheet outperformed my 6 month old Kryonaut paste numbers
If you want just to drop your temps, there is a smart way.
All core clock > 5400/5500MHz + auto voltage, this will drop significantly your temps (10C+). Of course, your mobo must support this future (my mobo supports it (Asrock)).
Yes, you will lose a little single core boost, but your multi-tread will rise and your temp will be less.
344 (0.43/day)
Processor AMD Ryzen 7 7800X3D (4.2Ghz base, 5.0Ghz boost, -30 PBO offset)
Video Card(s) PowerColor Radeon RX 7900 XTX Red Devil OC 24GB (2.39Ghz base, 2.99Ghz boost, -30 core offset)
Mouse Logitech G502 X LIGHTSPEED Wireless Gaming Mouse
Keyboard Keychron K4 Wireless Mechanical Keyboard
Software Arch Linux
I took a soft route with my 7700X, I set a -25 PBO and a temp cap of 85C. In benchmarks and some games i'm still able to hit 5.4Ghz effective clock as required too. This is with a DeepCool AG400 Plus air cooler, nothing fancy. Maybe a software solution is the ticket?
1,143 (1.71/day)
I already mentioned earlier that it is easy to make a sphere surface instead of a flat surface while lapping. With some experience making a (nearly) flat surface is possible and doable.
635 (0.50/day)
PBO uses a lot more voltage by default to be stable, you can't lower so much with CO -25 and have the same result as I describe.
82 (0.19/day)
System Name Ryzen AM5 + Radeon 7000
Processor R7 7700X
Motherboard ASUS ROG STRIX B650E-E WIFI
Cooling AK500 ZERO DARK + 2x Arctic 120MM static opt. PWM fans + KRYOSHEET
Memory GSKILL Flare X5 32GB (2x16GB) DDR5-6000 CL36
Video Card(s) ASUS TUF Gaming RX 7700 XT OC 12GB
Storage WD Black SN750 500GB (OS Drive) + CRUCIAL P5 PLUS 2TB (Game Drive) + (20) Crucial MX500 250GB
Display(s) LG 34" 1440p ULTRAWIDE 160Hz (main) + 2X LENOVO 27" 1080p 75Hz (sides)
Case FRACTAL DESIGN Pop Air w/ 3x140MM + 2x120mm ARCTIC PWM fans
Power Supply DEEPCOOL PQ850M 850W Gold
Mouse Logitech G502 Gaming X Wired
Keyboard Microsoft ANB-00006 Wired Slim Keyboard
Software WINDOWS 11 PRO
360 AIO can handle 300W, even more. 7700X produces max. 140W with PBO, you can cool that with a small air cooler!
Absolutely, my AK500 air cooler is enough to not allow over 90-91 on a stress test so I am not even hitting TJmax, never seen any throttling but some freq loss unless undervolted. I did replace the fan with an Arctic static pressure fan and added another for push/pull, but the second fan on this cooler only helps a couple of degrees. No-one "needs" a water cooler for a 7700x IMO at stock, but you need a decent performer to pull it off without throttling in some way or freq loss.
On my current setup I can go with stock settings to lets say userbenchmark (I know they suck...) to compare to similar hardware and mine will say above average for 7700X, top 25% or something like that. You absolutely cannot use this site to compare AMD to Intel and I would even argue that gen to gen comparison is meh. Specially the RX to RTX comparisons, I don't know where they pull half their numbers from and they spout a bunch of horrible personal opinions about AMD if you actually read what the site says about AMD hardware. A site like this needs to be as unbiased as possible, that is not the case. Especially recently.
What I am going to do to my CPU is absolutely not needed in any way, just the thrill of the chase.
I typically make a jig to help maintain angle while lapping and has served me well. Helps prevent tilting to one side or another. I have at times measured with a micrometer to make sure all sides are even, adjust jig accordingly.
Slow with light pressure, turtle beets the hair on this one. When checked against a known good flat edge for light bleeding I have never had an issue with this method. I imagine too much pressure while hand lapping is typically what gives people the spherical surfaces.
I typically add an additional negative voltage offset to help with this but don't do too much or you will become unstable quick. I recommend per core CO if you do this, I have had better results with it. Wider stable range.
9,764 (3.26/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Air coolers behave differently than AIOs. With an air cooler as soon as there is a high load temperatures will rapidly increase and reach steady state, with a large enough AIO that happens much slower and the heat can be dissipated before it reaches tjmax.
82 (0.19/day)
Processor R7 7700X
I did this and was only able to achieve -20 but capped at 85C with my silicon and not a sustained 5.4, it only touched it but fell back fairly quick. Looks like you won more in your silicon lottery than I did... :-(
May be due to a better cooling solution too though
Tinkering and experimenting for fun with cooling solutions is all I am really going to do here. Was planning to do this weekend but an emergency electrical service came up at work this weekend though so the tinkering is going to have to wait till following weekend. :(
Really looking for anyone that actually did/experimented with this on 7000 series to see what I should definitely avoid trying
I thought this too until recently. I don't know if the term has changed meaning, but lots of outlets refer to height reduction as lapping
for example, JTC refered to taking 0.8mm off as lapping. I think the thermal grizzly product made for lapping is for the AM5 height reduction up to 1mm
They have them for Intel as well and is called a "CPU lapping tool" and is made specifically for height reduction of the IHS
I think there has just been a recent expansion of the terms meaning in mainstream.
82 (0.19/day)
Processor R7 7700X
Well, TG uses a term "grinding".
Nice catch, I didn't notice that on there. I can be bad at skimming...
Technically it is grinding, my point is that the term Lapping is being used loosely in media on too many outlets which is in a social setting, changing the meaning. Not literally but in social slang terms I guess.
Kind of like the word that starts with F and has 3 letters (I'm not saying it...) has meant many things over the years and even different things in different regions.
I know there is a better example, just cant think of it off the top of my head right now...
LOL, i just noticed in the description it pulled form the sight on my post even says grinding... wow:kookoo:
2,097 (4.28/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) 1080P 144hz
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Wikipedia says:
If you want to remove 2mm, use milling machine and then lap it to get a final finish.
This thread had gone off the deep end.
A mill is considered a lapping or grinding machine.
The same procedure can and is done by hand.
Does anyone not research first, just a tiny bit. Like 13 second read will tell you what the term lapping means.
Please. Unless you actually know something or actually have experience, please stop posting here.
82 (0.19/day)
Processor R7 7700X
I might do a quick surface lap on CPU and cooler this Sunday just to see what that does. I should have enough time.
I will try my best to do before and after screenshots
Likely try Kryonaut paste for comparison and leave it with a fresh Kryosheet at the end of the day.
If I can't I will have at least some kind of results in by the end of January for lapping and maybe IHS height reduction.
18,584 (2.65/day)
System Name AlderLake
After 3 pages: OP, did you lap your CPU yet?
I have done it in the past with a E2200, iirc it improved by 2~3 degrees.
2,097 (4.28/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
1,143 (1.71/day)
Quick wikipedia quotes fot you:
Milling is a cutting process that uses a milling cutter to remove material from the surface of a work piece.
Lapping is a machining process in which two surfaces are rubbed together with an abrasive between them, by hand movement or using a machine.
Lapping often follows other subtractive processes with more aggressive material removal as a first step, such as milling and/or grinding.
YOU REMOVE THE BULK OF MATERIAL BY MILLING OR GRINDING.
THEN YOU CAN FINISH THE SURFACE BY LAPPING
Do you understand it? It is not very complicated. I made the text large for easy reading.
2,097 (4.28/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
A mill is a machine.
Invented from a process that was done by hand before the machine was invented.
And it even says by hand....
The procedure refers to using an abrasive to flatten a surface.
82 (0.19/day)
Processor R7 7700X
I only did about 5 seconds of research on this one personally... sorry. Not gonna lie, I was embarrassed. My point was more of the media feel when you are listening to people talk about the height reduction they just keep referring to it as a lapping process. Some will specify that it is technically grinding or whatnot once but the rest of the video it is all lapping, lapping, lapping. Starting to feel like that was just my personal impression.
But thank you honestly for saying that. I am really looking for people with experience in 7000 series that can share any of their actual experiences with this before I get started. No-one is going to persuade me to not do this, just looking for feedback, experiences and suggestions other than to nerf the chip and keep my warranty. If I wanted to nerf it, I just would've gotten the 7700. I got the X sku to be able to play around more with it.
Lets not get hung up on "technicalities" arguments that is going to derail the conversation...
2,097 (4.28/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
That's because lapping and grinding mean the same thing.
Lapping is geared towards making a surface flat.
You can grind anything, doesn't mean the goal is to make flat, which is what lapping means.
However, using abrasives is grinding, but lapping is grinding for a reason.
It's a term that's been used since the release of AMDs IHS plate used on platform socket 754. Before this it was socket 462 which the cpus didn't come with a plate on the cpu. It was all direct die.
82 (0.19/day)
Processor R7 7700X
OP seems more like a "sayer" than a "doer"...
Trying to research and see what others have done before doing, guys... I thought that is what these were for. Sharing ideas and helping others.
If you have followed any of my threads, I am a doer
This is my first attempt to reach out to a community before a project and honestly is pretty counter productive so far
Mostly people telling me not to do it, limit my stuff, save my warranty and make technical corrections that don't help advance the conversation.
I think 2-3 posts have given me what I am asking for with limited details on some of it
Just got done turning my GPU from a screaming heater into a beast of its sku and this is my next itch to tinker around. YOU should do what is mentioned above and research before posting! not a doer...
I do what most people are scared of
2,097 (4.28/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
Yes, if you want procedure, must directly ask for it.
Gather materials needed.
Flat mirror on a flat surface
Tape wet sanding paper to the mirror.
Figure 8 motions for lapping. Do not go back and forth.
Watch for the paper to clog. You can clean wet sanding paper by simply cleaning it with water and a rag.
You do not need to use water for theblapping process, but you can if wanted. I find it just makes the process messy.
Start with a corse grit to remove a lot of material if that's the goal. Start at 200 to 400 grit wet sanding paper.
Once you've taken off the amount of material you desire, then you increase grit. 600, a few minutes, 800 a few minutes, 1000 for a few minutes, 1500 for a few minutes.
You do not need to push down. A little hand weight is enough, let the abrasive do its work.
Follow this process, you'll do just fine.
Try finding that in wiki
82 (0.19/day)
Processor R7 7700X
If you read the original post I'm asking for anybody that has specifically had experience in 7000 series I've done this many times and I know the process. Wins/losses experienced in ryzen 7000, that kind of thing
But I definitely appreciate the level of detail here and I know you're just trying to help out so I don't mind these type of posts. Thank you!
18,584 (2.65/day)
I did it wet, you can "polish" the surface shiny with wet and very fine sandpaper.
82 (0.19/day)
Processor R7 7700X
I actually asked specifically for 7000x experience due to the offset center location of the dies once the IHS is removed. Seems to be creating contact/mounting issues
DerBauer actually talked about this and his experience is the a mirror finish actually does worse than a hi-grit finish. I have also heard this from others but still see a lot of people doing it
A hi-grit finish will give you an extra degree or two over mirrored
So they say...
Count von Schwalbe
Nocturnus Moderatus
3,374 (2.76/day)
Knoxville, TN, USA
With or without TIM? With TIM, it make sense a slightly coarse finish would help. If you are going TIMless, mirror will give better contact.
18,584 (2.65/day)
