- Dec 8, 2020
- 3,155 (1.97/day)
- United Kingdom
Feel free to post you mods here, just make sure they have a unique name for people to identify the driver, and also so you can support it directly (and so I don't have to, since I didn't make it).
You will need either the encoder and its CLSID to input into your .inf, as probably endpoint for digital. Or a Realtek APO (RltkAPOU64.dll) that directly supports these features.
I have attached the tools I am using, you will find: FX Configurator, RTK APO Tool and RTK Device Tool. The APO tool I use to read settings and changes.
Not every setting you apply in the device tool will show in the apo tool. For example DTS encoder shows as disabled, although enabled.
It can also tell you what CLSID's and files are needed for different systems.
