- Dec 8, 2020
- 3,065 (2.00/day)
- United Kingdom
Open HDXRT.inf in the cab file, and scroll though looking for DTS and Dolby (you can also use the search feature in Programmers Notepad 2).
There will be more code to look for, but in general, you compare your current .inf, with the .inf that has the code you need.
When you find a difference (for example .cab inf has extra code here, and its DTS), you copy it.
First copy all the codes to separate text document, so you can read it better, before you transfer to your master .inf.
Backup your current work to a .zip, this way if the .inf ends up broken, you can restore it.
At this point is nearly all self learning, you have no time limit.![Smile :) :)](https://tpucdn.com/forums/data/assets/smilies/smile-v1.gif)
Also I'm guessing here but by the sounds of you where successful making an update for your device, well done.
Next update (which will be when the new generic comes out), I will attempt to add analogue to DTS APO4 (tested before release), as its working very well for S/PDIF (digital).
You will be stuck on a default profile, that cannot be changed unless a license is purchased (for me the Sound Unbound app is bugged).
I have sent DTS an email, they have responded, and my guess is its being looked into (last app update was 2018).
