AMD Contemplates Bundled Water-Cooling for Some FX-Series Processors
Halk
105 (0.02/day)
System Name Desktop PC
Processor 1090T
Motherboard Crosshair IV Forumula
Cooling Arctic Freezer 7 pro
Memory 4x2GB OCZ Reaper
Video Card(s) DirectCU 580
Storage Vertex 2 120GB
Display(s) Dell 24 inch
Case Fractal Design R3
Audio Device(s) Asus Xonar Essence STX
Power Supply Seasonic X 650
Software Win 7 Home Premium x64
Thats cool to hear but they have some big boots to fill if they plan on taking on Corsair's self contained water solution.
Corsair just get someone else to make it, same people as make it for Asus. Likely AMD would go to the same place and get theirs.
Personally I don't like it because those water coolers aren't as good as high end air, or as quiet or as cheap.
1,235 (0.23/day)
USA, Arizona
System Name SolarwindMobile
Processor AMD FX-9800P RADEON R7, 12 COMPUTE CORES 4C+8G
Motherboard Acer Wasp_BR
Cooling It's Copper.
Memory 2 x 8GB SK Hynix/HMA41GS6AFR8N-TF
Video Card(s) ATI/AMD Radeon R7 Series (Bristol Ridge FP4) [ACER]
Storage TOSHIBA MQ01ABD100 1TB + KINGSTON RBU-SNS8152S3128GG2 128 GB
Display(s) ViewSonic XG2401 SERIES
Case Acer Aspire E5-553G
Audio Device(s) Realtek ALC255
Power Supply PANASONIC AS16A5K
Mouse SteelSeries Rival
Keyboard Ducky Channel Shine 3
Software Windows 10 Home 64-bit (Version 1607, Build 14393.969)
Looks like AMD has found the fastest way to receive negative publicity. Bundle a water cooler with a processor so every joe shmuck can fry their computer and then complain about horrible warranties and faulty tech support.
Bad idea in my opinion... :laugh:
AMD Chips don't fry anymore
and again this is highly unlikely(LCS in a tin box is impossible)
I don't see it happening
1,238 (0.19/day)
SoCal
Processor AMD Phenom II 1055T @ 3.6ghz 1.3V
Motherboard Asus M5A97 EVO
Cooling Xigmatek SD1284
Memory 2x4GB Patriot Sector 5 PC3-12800 @ 7-8-7-24-1T 1.7V
Video Card(s) XFX Radeon HD 7950 DD @ 1100/1350 1.185V
Storage OCZ Agility 3 120GB + 2x7200.12 500GB Raid1
Display(s) QNIX QX2710 27" LCD 1440p @ 120hz
Case Cooler Master 690M
Power Supply Enermax Liberty 620W Eco Edition
Software Windows 7 Professional x64 / Ubuntu 12.04 x64
5,439 (0.84/day)
Tennessee
System Name AM5
Processor AMD Ryzen R9 7950X
Motherboard Asrock X670E Taichi
Cooling EK AIO Basic 360
Memory Corsair Vengeance DDR5 5600 64 Gb - XMP1 Profile
Video Card(s) AMD Reference 7900 XTX 24 Gb
Storage Crucial Gen 5 1 TB, Samsung Gen 4 980 1 TB / Samsung 8TB SSD
Display(s) Samsung 34" 240hz 4K
Case Fractal Define R7
Power Supply Seasonic PRIME PX-1300, 1300W 80+ Platinum, Full Modular
5,392 (0.94/day)
Carrollton, GA
System Name ODIN
Processor AMD Ryzen 7 5800X
Motherboard Gigabyte B550 Aorus Elite AX V2
Cooling Dark Rock 4
Memory G Skill RipjawsV F4 3600 Mhz C16
Video Card(s) MSI GeForce RTX 3080 Ventus 3X OC LHR
Storage Crucial 2 TB M.2 SSD :: WD Blue M.2 1TB SSD :: 1 TB WD Black VelociRaptor
Case Fractal Meshify C
Audio Device(s) Onboard Audio
Mouse Corsair M65
Keyboard Corsair K70 RGB Lux
They could get away with this if the bump in cost is say $65 or less. That to me seems like a sweet spot for people to consider it a deal over buying your own at $100+. Although I honestly don't see this happening due to manufacturing restriction.
I agree with those that think a beefier air cooler period should be used. This would ensure every customer gets a "decent" cooler and might actually considering keeping it. If they can get even a small percentage of customers to keep the stock cooler because it isn't the complete BS we are use to, it would be a small win. Especially if they can do it with on a $5 or $10 bump in price. It would also be something they could easily design themselves.
It doesn't have to be a tower either. AMD is also obviously concerned about RAM and case clearance issues. Dear AMD, this is all you have to do. Take the cooler you give out with Phenom II X6 CPU's spread the 4 copper pipes it has out more to get better heat distribution and increase the size of those pipes by 2mm. Increase the area of the aluminum fins up to just a few milimeters shy of the CPU area (say the distance away you normally find between RAM slots). The go up to a 92mm or 100mm fan. Slant the cooler slightly to get the air flow at least toward the back or top of the case and you are done.
Something like this should be great with a faster fan:
fullinfusion
Vanguard Beta Tester
9,909 (1.59/day)
All they'd do is use a proven asetek or coolit with an AMD logo. Wouldn't have anything to do with corsair.
I used Corsair as an example as most think its better then Cool it ;)
If AMD would incorporate a tec into the radiator that would be sick!
1,430 (0.29/day)
A frozen turdberg.
System Name Runs Smooth
Processor FX 8350
Motherboard Crosshair V Formula Z
Cooling Corsair H110 with AeroCool Shark 140mm fans
Memory 16GB G-skill Trident X 1866 Cl. 8
Video Card(s) HIS 7970 IceQ X² GHZ Edition
Storage OCZ Vector 256GB SSD & 1Tb piece of crap
Display(s) acer H243H
Case NZXT Phantom 820 matte black
Audio Device(s) Nada
Power Supply NZXT Hale90 V2 850 watt
Benchmark Scores Lesbians are hot!!!
How much you wanna bet me that I can fry a amd chip with water?
I can do you one better and fry one with any liquid you choose. Same goes for Intel because I'm multi-talented.
967 (0.16/day)
Motherboard MSI MAG X570S Tomahawk Max WiFi
Cooling EK Supremacy EVO Elite + EK D5 + EK 420 Rad, TT Toughfan 140x3, TT Toughfan 120x2, Arctic slim 120
Memory 32GB GSkill DDR4-3600 (F4-3600C16-8GVKC)
Video Card(s) Gigabyte Radeon RX 7900XTX Gaming OC
Storage WDBlack SN850X 4TB, Samsung 950Pro 512GB, Samsung 850EVO 500GB, 6TB WDRed, 36TB NAS, 8TB Lancache
Display(s) Benq XL2730Z (1440P 144Hz, TN, Freesync) & 2x ASUS VE248
Case Corsair Obsidian 750D
Audio Device(s) Topping D50S + THX AAA 789, TH-X00 w/ V-Moda Boompro; 7Hz Timeless
Power Supply Corsair HX1000i
Mouse Sharkoon Fireglider optical
Keyboard Corsair K95 RGB
Could be interesting, if they go with the idea. When I upgrade to BD or its sucessor I know my HTPC could sure use the stock LCS from this, and my PII X4 for a nice bump in performance.
Nah, I prefer fried potatoes to fried CPUs. Much tastier. Cheaper, too.
455 (0.09/day)
System Name ---
Processor Ryzen 1600
Motherboard ASRock Taichi X370
Cooling Noctua D15
Memory G.Skill 3200 DDR4 2x8GB
Video Card(s) EVGA 1080 TI SC
Storage 500GB Samsung Evo 970 NVMe + 860 Evo 2TB SSD + 5x 2TB HDDs
Display(s) LG CX 65"
Case Phanteks P600S (white)
Power Supply Corsair RM850x (white)
Then someone might come along and say "My 8310P doesn't need a HSF since it didn't come with one" but who knows. Even if you give someone a HSF, it's not guaranteed that they'll use it, as in the case of some guy buying an i7 975X and using it a week before his new system died, wondering what that burning smell was, and that he maybe should have used the included fan. :shadedshu
Eh no, that's what warning labels are for a big red label on the outside, and on the inside on top of the processor would be sufficient to absolve AMD of any responsibilities.
1,430 (0.29/day)
A frozen turdberg.
Processor FX 8350
bear jesus
1,534 (0.29/day)
Britland
System Name Gaming temp// HTPC
Processor AMD A6 5400k // A4 5300
Motherboard ASRock FM2A75 PRO4// ASRock FM2A55M-DGS
Cooling Xigmatek HDT-D1284 // stock phenom II HSF
Memory 4GB 1600mhz corsair vengeance // 4GB 1600mhz corsair vengeance low profile
Storage 64gb sandisk pulse SSD and 500gb HDD // 500gb HDD
Display(s) acer 22" 1680x1050
Power Supply Seasonic G-450 // Corsair CXM 430W
It almost seams like a good idea but i would only say so if it cost less than buying them separate but also only if there is an option to buy without this cooler.
Many people including myself have one of these type of coolers on both AMD and Intel chips so i can see why it could seam like a good idea to someone within the company but if/how it works out only time will tell.
967 (0.16/day)
newfellow
314 (0.06/day)
System Name ID
Processor Q9450 ~3.74Ghz
Motherboard ASUS-P5E
Cooling Air
Memory G.Skill CL4-8GB
Video Card(s) ATI/Geforce 5850/9800
Storage A-lot
Display(s) BenQ G2400WT
Case 900
Audio Device(s) Shitty ASUS FX;P
Power Supply OCZ GXS 850W
Software -
Benchmark Scores too many machines to spec
This is fine as long as I don't see a $100 jump in price.
This is fine as long the CPU still ain't 40-44c with the water cooling. Would be really nasty when you buy new hardware and notice that the CPU runs twice as hot on already high end cooling which you can't upgrade.
53 (0.01/day)
South Africa
System Name Gaming rig
Processor AMD FX-8120
Motherboard ASUS M5A99X Pro 2.0
Cooling Antec A40 Pro
Memory 4x 4gb Corsair Vengeance 1600ddr 3
Video Card(s) Gigabyte R9 280X 3gb
Storage Kingston Hyper-X 120gb SSD, Western DIgital 1tb hdd, Seagate 250gb hdd
Display(s) LG 25UM58 25" Ultra wide
Case Corsair Carbide 500R white
Power Supply Corsair TX850 modular
Keyboard Logitech G413 Silver
Software Windows 10 64-bit
i don't think it's because they'll be hot, i think it's because they are confident they'll oc like beasts.
that said roll on september :) can't wait to finish my upgrade
already got my ram and crosshair V standing by :D
T
twilyth
I admire your commitment. I might want to do that too, except I already got burned with the 1155 recall. Plus I haven't gotten the feeling that there will be any problem with the availability of motherboards. IDK.
1,430 (0.29/day)
A frozen turdberg.
Processor FX 8350
I'm waiting for the chip to release too. Besides the lack of funds, I want to make sure it's as big of a jump as I think it's going to be.
5,954 (0.82/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
Meh, considering coolers like the Antec KUHLER H2O 620, or similar Corsair CWCH60 aren’t enough to provide real strong over-clocking...
My 130W QX9650 running at a 1GHz overclock under an H50 would disagree. Temps average 35 degrees and peak at 50 on the worst summer days.
Halk
105 (0.02/day)
Processor 1090T
Either you're right and all the reviews are wrong....
The only way this will work out for AMD is if they shift enough watercoolers that they can bring the price down so far that it it's a bargain.
982 (0.19/day)
Processor 12100
Video Card(s) 1650 Super
Case Coolermaster Ammo 533
Mouse G403
Keyboard Sidewinder x4
I good air cooler would be so much better...
455 (0.09/day)
System Name ---
Cooling Noctua D15
What reviews? Every review I've ever seen for these say that they perform very well. The problem is that there tend to be cheaper less noisy air coolers.
Halk
105 (0.02/day)
Processor 1090T
Go and read them again. They're not as good, not as quiet and not as cheap as air cooling.
Edit : If it helps I'll be even clearer.
Top end air cooling is overpriced, and the performance you gain is very slight over 'reasonably' priced mid/high end. If AMD are going to come up with something here then they need to sell a massive volume of them (relative to normal aftermarket cooler sales) in order to bring the price down so that they can compete with mid end air, because if they can get the price down to a 40 dollar premium over OEM CPUs then that's the point at which I believe people will be interested.
Someone who is going to spend a relatively large amount on a self contained watercooling solution for their CPU isn't going to be happy at only getting a $10 discount, but being unable to choose the manufacturer or model.
de.das.dude
Pro Indian Modder
9,167 (1.71/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| J1nnx took Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
now only if they gave the top of the CPU a mirror chrome finish!
12,083 (1.72/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
I wish that they'd just give us the option to buy processors without heatsinks.
AMD Phenom II X6 1035T Thuban 2.6GHz 6 x 512KB L2 ...
We can. But some of these are only the low end made for custom only cooling solutions.
I actually like the Phenom heatpipe cooler, but for the same amount of money a setup like this
XIGMATEK AIO-S80DP All-in-one liquid cooling syste...
Or one with a integrated motor to run the pump and fan with magnetic coupling and temp controlled off the board would be awesome enough for most people to want.
http://images17.newegg.com/is/image/newegg/35-185-097-S01?$S300W$
Everything you just said but no heat pipes other than a couple copper or rubber pipes to carry the coolant.
2,198 (0.44/day)
So. Cal.
Really with the single stock fan? While how many other case fans?
When Frostytech (one of the most reputable data based sites I've ever come across) I trust their result and opinion.
http://www.frostytech.com/articleview.cfm?articleID=2564
http://www.legitreviews.com/article/1025/1/
http://www.tomshardware.com/reviews/corsair-h50-fort120,2370.html
http://www.xbitlabs.com/articles/coolers/display/corsair-h50.html
http://www.hardwaresecrets.com/article/Antec-Kuhler-H2O-620-CPU-Cooler-Review/1233/1
http://www.eteknix.com/cooling/antec-kuhler-h2o-620-liquid-cpu-cooler-review-1519/
http://benchmarkreviews.com/index.p...ws.net/reviews/antebaconuhler_h2o_620_review/
http://www.madshrimps.be/articles/a...Khler-H2O-620-CPU-Cooler-Review#axzz1UpTl1HPZ
Here against a Thermolab Trinity Heatsink.
http://www.hardwarelook.com/review.php?id=43&page=1
http://www.frostytech.com/articleview.cfm?articleID=2600
That's what I read. There nice but what's the MTBF for the pump? Pumps do fail!... take my word I hear many issues everyday in my line of work. Such "entry systems" are more a novelty… for those who say I’ve get a water cooler.
1,430 (0.29/day)
A frozen turdberg.
Processor FX 8350
I really don't see why they don't do that. It's not like they cant include the information on the chip on a separate piece of paper.
