AMD Contemplates Bundled Water-Cooling for Some FX-Series Processors
2,198 (0.43/day)
So. Cal.
The XIGMATEK AIO-S80DP is an interesting concept, but it ignores the best attribute of water cool which is to move the BTU's out of the chassis. It doesn’t provide anything over a decent cheap H-P cooler, while at 840g that's a lot of heft and complexity to hang on a mobo. Then it appears to have plenty of leak points, while not to mention the dissimilar metals and the corrosion effect. No OEM like AMD would sanction that.
http://www.techpowerup.com/reviews/Xigmatek/AIO_S80DP/1.html
http://www.frostytech.com/articleview.cfm?articleID=2070
de.das.dude
Pro Indian Modder
9,184 (1.71/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad | Old Monke
Case Ant Esports Tempered case | Thinkpad | NZXT Guardian 921RB
Audio Device(s) Logitech Z333 | Jabra corpo stuff | Some USB speakers
Mouse Logitech G400 | nipple | Dell
VR HMD ;_;
I really don't see why they don't do that. It's not like they cant include the information on the chip on a separate piece of paper.
why that?
if you notice, the marking now is shiny and the rest is dull.
they should just reverse it.
a little dull marking on a shiny mirror surface is nothing.
and no writing on paper wont speed up production processes where the chip is identified by computers on what is written on it :p
de.das.dude
Pro Indian Modder
9,184 (1.71/day)
VR HMD ;_;
How much you wanna bet me that I can fry a amd chip with water?
i wanna see you try. youre probably someone who is still stuck with AMDs old image.
free advise : grow up, the world is changing :D
1,430 (0.28/day)
A frozen turdberg.
System Name Runs Smooth
Processor FX 8350
Motherboard Crosshair V Formula Z
Cooling Corsair H110 with AeroCool Shark 140mm fans
Memory 16GB G-skill Trident X 1866 Cl. 8
Video Card(s) HIS 7970 IceQ X² GHZ Edition
Storage OCZ Vector 256GB SSD & 1Tb piece of crap
Display(s) acer H243H
Case NZXT Phantom 820 matte black
Audio Device(s) Nada
Power Supply NZXT Hale90 V2 850 watt
Software Windows 7 Pro
Benchmark Scores Lesbians are hot!!!
why that?
That's even better, it would even save money on whatever the dull coating is to reverse it.
4,015 (0.75/day)
UK
System Name PC
Processor AMD Ryzen 3600
Motherboard MSI B450 Mortar Max
Cooling Phanteks PH-TC12DX, 3 x NZXT FN 140mm, 1x NZXT FV V2 120mm
Memory 32gb DDR4 3200mhz
Video Card(s) ASUS R9 290 DCII-OC 4GB
Storage corsair mp600 1TB
Display(s) LG 27MB85Z 27" 1440p
Case NZXT Source 340
Power Supply Thermaltake 675w
Mouse Logitech G500S
Keyboard Logitech G510S
Software Windows 8.1 64 bit
I wish that they'd just give us the option to buy processors without heatsinks.
it's a bit late for this response but, they do
12,132 (1.72/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
I didn't mean it specifically, but a cooler that uses a common motor for the fan and pump (much like the motor drives my pumps impeller with magnetic lock on a ceramic bearing) there would be almost no friction and the only moving parts would be the sealed impeller and a fan that should be quiet based on the fact there is little to it other than a couple pieces of steel two bearings and a housing, and a tiny bearing housing instead of a motor means no dead spot.
So the pump impeller runs in the sink/block and has two hoses or copper tubes running into a 120mm radiator with a large fan and two rows in a single pass design. So 1/4" ID tubing would work, and a PWM driven motor would allow the board to change fan and pump RPM simultaneously for cooling on demand. A pull fan design would also help cool RAM, FETS and any bridge chips on the board. Having a cradle design for the motor and the fan suspended from the radiator and using copper tubes would mean no extra supports and any minor vibrations would be isolated.
I might have to design one myself if no one else will. There is that thermaltake guy around.......
Halk
105 (0.02/day)
System Name Desktop PC
Processor 1090T
Motherboard Crosshair IV Forumula
Cooling Arctic Freezer 7 pro
Memory 4x2GB OCZ Reaper
Video Card(s) DirectCU 580
Storage Vertex 2 120GB
Display(s) Dell 24 inch
Case Fractal Design R3
Audio Device(s) Asus Xonar Essence STX
Power Supply Seasonic X 650
Software Win 7 Home Premium x64
Erm. Just a bit of help for the hard of thinking. Watercooling does nothing magical.
It does two very simple things - it moves the heat somewhere else, and also spreads it out into (roughly) 700ml of water.
That's all. Nothing magic.
The very existance of watercooling by itself does nothing magical.
I'm repeating myself but I need to in order for people to understand it.
The advantages of watercooling are....
You can have a larger surface area of hot area to cool - using a radiator. Although you can do this with metal heatsinks the advantage water has is in the next sentence...
You can move the heat from inside the case to the outside edge easily. That way you can blow have cold air from outside the case go over the radiator, or you can have the air that's warmed slightly expelled straight out of the case.
You can combine the heat from multiple components and have them run through a single radiator/fan assembly. 2 120mm fans and a 120x2 radiator for example would do enough for most people, 120x3 is good and anything higher is a bit overkill.
The heat still needs to go into the room. You add pump noise and vibration. It's HUGELY more expensive.
I've been reading forums and reviews etc for around 10 years now, and I'm continually hit by the basic ignorance of people who believe that watercooling in itself is enough to bend the laws of physics.
5,614 (1.00/day)
San Diego, CA
System Name White Boy
Cooling CORSAIR H100
Display(s) 1 Dell 30U11 30"
Case BIT FENIX Prodigy
Audio Device(s) none
Does this mean they need it because they run too hot ? :twitch:
12,132 (1.72/day)
Motherboard Asus
Keyboard Razer
Software A lot.
I have 360mm radiator, I run my quad and 5870 at full all the time folding at home, and it is in fact the thermal limit of my system. A larger radiator will allow for slower fan speed with the same cooling efficiency, so magical? Nope, but quiet with a shitload of TDP dissipation and low temps? Hells yeah. 150+ watts out of my quad and 250+ out of my 5870 and they stay cool.
I appreciate your condescending post though. Thanks.
Halk
105 (0.02/day)
Processor 1090T
As should have been apparent, I was talking to people who didn't understand the concept.
Edit : Aha! My post followed yours. Sorry if it appeared I was replying to you, I was talking to the thread in general.
2,198 (0.43/day)
So. Cal.
You must mean a Laing “Danger Den pumps”… Got two different Laings’ doing work at the house right now, one for the hot water loop the other on an above ground pool very nice centrifugal pumps.
Thought the pump in that Xigmatek is what essentially and Eheim fish tank pump that’s design isn’t as robust for +60°C. You might have something in that the pump is in the radiator/fan module while just a water block on the CPU. Then the combined magnetic drive for a pump and fan has merit. Though the downside is the rpm of pump and fan are the same, so some big trade off of pump speed, size, dBa verse what the fan does relative to that same speed. Get what I’m saying… I would considery having both independent control of the pump and fan provides the best means of controling of water flow and air flow, as sometimes one over the other or both can provide optimum heat transfer, while not amplify the sound profile.
12,132 (1.72/day)
Motherboard Asus
Keyboard Razer
Software A lot.
Swiftech MCP655 12 VDC Pump Liquid Cooling System
That is what I'm running, one ceramic bearing lubricated by the coolant and magnetically driven by the motor, so one o-ring on the impeller case.
They could design a impeller and housing to meet the coolant flow needs for whatever RPM the fan is designed for also, so one motor is a simpler solution, magnetic drive simplifies the sealing of the system, but it does pose the problem of if a impeller gets hung up how do you know its turning? But with water the thermal mass you have to heat and the lower shutoff threshold you could implement would mean that you could run it without any coolant flow.
5,614 (1.00/day)
San Diego, CA
I would be okay with paying a 40-50 dollar premium on a chip for it to come with an H80 style cooling system.
2,459 (0.39/day)
System Name PC
Processor i7 9700KF
Motherboard MSI Z390 A PRO
Cooling Noctua NH-U14S
Memory 32GB Corsair Vengeance DDR4 3000mhz
Video Card(s) PALIT RTX 4070 Dual 12Gb
Storage Samsung 990 Evo 2TB, 2X Crucial MX500 2TB
Display(s) DELL C34H89x 34" Ultrawide
Case Corsair Obsidian 550D
Audio Device(s) Audioengine A5+ Speakers
Mouse Logitech G403
Software Windows 10 64bit
So basically what they saying is that theres no way a retail cooler will cool one of their top end CPU's and they need water to do it?
5,393 (0.93/day)
Carrollton, GA
System Name ODIN
Processor AMD Ryzen 7 5800X
Motherboard Gigabyte B550 Aorus Elite AX V2
Cooling Dark Rock 4
Memory G Skill RipjawsV F4 3600 Mhz C16
Video Card(s) MSI GeForce RTX 3080 Ventus 3X OC LHR
Storage Crucial 2 TB M.2 SSD :: WD Blue M.2 1TB SSD :: 1 TB WD Black VelociRaptor
Case Fractal Meshify C
Audio Device(s) Onboard Audio
Mouse Corsair M65
Keyboard Corsair K70 RGB Lux
no
5,614 (1.00/day)
San Diego, CA
43,621 (6.41/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Are you sure?
Reading the article, they talk about both AMD and Intel (SB E series) both using them. Not because they need them, but more for the enthusiast market that uses these type of CPU's.
455 (0.09/day)
System Name ---
Processor Ryzen 1600
Motherboard ASRock Taichi X370
Cooling Noctua D15
Memory G.Skill 3200 DDR4 2x8GB
Video Card(s) EVGA 1080 TI SC
Storage 500GB Samsung Evo 970 NVMe + 860 Evo 2TB SSD + 5x 2TB HDDs
Display(s) LG CX 65"
Case Phanteks P600S (white)
Power Supply Corsair RM850x (white)
I still say that Intel and AMD need to strongly consider just selling processors. A good portion of folks wont be happy no matter what they pack in. Even if it were $10 off I'm sure there'd be hordes of people who'd be thrilled just to save a bit since they're going to throw their own solution on anyway. There's also the shipping side. For every processor + heatsink they could probably fit in 4 stand alone processors.
9,252 (1.57/day)
Montreal, Canada
System Name Homelabs
OEM chips o.o They exists already
52 (0.01/day)
System Name Strider's Rig
Processor AMD FX-8350 Vishera @ 4.5GHz
Motherboard ASUS Sabertooth 990FX R2.0 Gen 3
Cooling Thermaltake Frio Processor Cooler (Push/Pull)
Memory 16GB A-Data XPG Gaming Series DDR3 1866
Video Card(s) Sapphire R9 290 Tri-X OC Edition
Storage 5 WD Black SATA III / Seagate 600 Series 240GB SSD / 3TB WD My Book Ext/ 1TB Seagate Passport Ext
Display(s) Primary Acer 23 inch HD Widescreen LCD 1920 x 1080 / Secondary HP 1920x1080 "Work" LCD Display
Case Cooler Master HAF 932 Black Steel
Audio Device(s) Sound Blaster Z 5.1 / Steel Series 9H
Power Supply Corsair HX850W Professional Modular 850W PSU
Software Windows 7 Ultimate 64
I see so many assumptions saying "it must run hot". Assumption, as just about everyone should know, is the mother of all screw-ups.
If you are going to be one of those people buying the flagship eight-core FX series processors, you're probably not going to leave it at stock. You're likely a gamer or other enthusiast who will be looking to push the processor beyond it's stock speeds.
You're going to overclock, and thus you're going to replace the stock cooler anyway. No true enthusiast of any caliber uses stock cooling on an overclock.
To me, it simply looks to me like AMD is targeting what will probably be their largest customer base when these eight-core beasts hit the market. Customers who will be tossing the stock cooler anyway in favor of either a high-end air cooler, or liquid cooling such as they are talking about here.
Though high-end air coolers perform just as well as these stand-alone self contained liquid CPU cooling kits, they are also much larger. So to me, it makes sense to include them with the flagship processors in a kit. PIB I think they are calling it, Processor In a Box.
So chances are, there will be more than one version available. The PIB that will include whatever self-contained liquid cooling they decide to go with, and another that will contain a standard air-cooler for those people who will run at stock, or enthusiasts who already have aftermarket cooling they intend to use.
I for one do not need an included liquid cooler. The Thermaltake Frio I am running on my 1090T at 4.2GHz is more than enough to keep a Bulldozer FX cool based on the fact that this cooler, and many others like it, perform just as well as the self contained liquid coolers, such as the H60.
455 (0.09/day)
System Name ---
Cooling Noctua D15
I know. I bought one for my first build, but I could not find an OEM SB chip for my current one.
T
twilyth
Not everybody who wants to overclock necessarily wants to go balls-to-the-wall on their overclock. When you consider that low-end solutions like the Hydro series does at least as well as high-end air, it makes sense for AMD and Intel to think about putting out a chip with a wc option.
After all, as was noted earlier, haven't they been providing better and better stock air coolers? Why do you think they've done this? For yuks? Probably not.
There's also the fact that really pushing an oc requires a great deal of trial and error and therefore patience. Skill is also part of the equation, but if you're trying to overclock a brand new chip, even skill isn't the primary ingredient. That means that most people are going for the sweet spot - where you get a 15-30% oc without investing a few days in reboots. But it also means that you don't need a 3 rad loop or TEC chillers.
2,459 (0.39/day)
System Name PC
Processor i7 9700KF
Mouse Logitech G403
i disagree... people who buy the fastest processor are usually people who dont overclock but want the highest speed... if you overclock you can buy a slower chip for less and get faster speeds ;)
CDdude55
Crazy 4 TPU!!!
8,178 (1.27/day)
Virginia
System Name CDdude's Rig!
Processor AMD Athlon II X4 620
Motherboard Gigabyte GA-990FXA-UD3
Cooling Corsair H70
Memory 8GB Corsair Vengence @1600mhz
Video Card(s) XFX HD 6970 2GB
Storage OCZ Agility 3 60GB SSD/WD Velociraptor 300GB
Display(s) ASUS VH232H 23" 1920x1080
Case Cooler Master CM690 (w/ side window)
Audio Device(s) Onboard (It sounds fine)
Power Supply Corsair 850TX
Software Windows 7 Home Premium 64bit SP1
Enthusiasts who can afford the best generally do buy the best and overclock.
Rarely do you have an average gamer or non enthusiasts drop thousands or hundreds of dollars for a CPU or GPU and won't overclock.
