3,062 (2.01/day)
United Kingdom
Quick update link now here (some corrections). I did some MediaFire organization, and have moved it to a folder.
112 (0.08/day)
System Name FireBreather
Processor AMD Ryzen 9 7950x
Motherboard CrossHair Extreme x670E
Cooling Asus RoG Strix LC2 360 AIO
Memory G.Skill Trident Z5 RGB Series 64GB (2 x 32GB) 288-Pin SDRAM DDR5 6000 CL30-40-40-96 1.40
Video Card(s) 7900 XTX Taichi
Storage 3x- PCI-E 4.0 Nvme 2TB 7GB/s - 2TB N7 USB-3.1 Nvme 1GB/s
Display(s) ASUS - VG259QM 2k 280hz HDR - LG-C1 4K 120hz OLED with Dobly vison
Case ROG Helios
Audio Device(s) SupremeFX ALC4082 codec, and an integrated ESS® ES9218 quad DAC
Power Supply HX1500i - 1500Watt
Mouse Corsair Dark Core
Keyboard Corsair K95 Platinum
Software Windows 11 pro
Benchmark Scores Time spy - 29000 Port Royal - 17500 Cinabench R23 - ST = 2150 MT = 40000
hey buddy im still on 6.0.9200.1 with windows 11 everything is working great i use interactive x though spidif 2.0 are there any improvments with the latest driver version to interactive that should make me want to update to latest version
3,062 (2.01/day)
United Kingdom
Not exactly, however any changes to APO4 effect Interactive. I recently switched back to Realtek SPDIF, and for me the current is perfect.
To compare it to 6.0.9200.1, I honestly cannot say, during that period I was using AMD HDMI as my main audio out.
Edit: The current package should be more responsive than 6.0.9200.1, as long as you reg clean after uninstall, I suggest CCleaner.
112 (0.08/day)
Case ROG Helios
ok great thank ill think about giving it a shot
91 (0.03/day)
Why did you decide to return to the SPDIF interface?
3,062 (2.01/day)
United Kingdom
Currently I have Z906, which only supports 2 channel PCM, DTS Surround, Dolby Digital Live!, this has nothing to do with SPDIF hardware limits.
Directly, there is no upgrade, and my Realtek SPDIF can send all encoded formats (even ones Z906 doesn't support).
I only gain multichannel PCM, and only because OEM's are still catching up to SPDIF's full potential.
HDMI audio is 37mbps max, SPDIF + TOSLink 2.0 is 125mbps max, optical is more responsive than conductive circuit, and immune to EMI RFI.
Even the distance TOSLink does 125mbps is futher than HDMI can do 37mbps, There is also optical SMI @ 250mbps.
For audio only, the video feed the GPU has to make is wasted overhead, no advantages to HDMI.
In terms of Windows, neither SPDIF nor HDMI are properly supported, and the EDID is unused mostly.
SMI Optical Interconnects | TTI, Inc.
As a side note, now that OEM's now how to implement the hardware for HDMI to do it's max 8 x 192k (1,536k), 37mbps.
They can put the same PCM hardware on SPDIF, it can even be done via HDMI + TOSLink 2.0, no SPDIF.
I suggest SPDIF, because at the lowest level (consumer), it supports 15 channels.
I can send my Z906 6 channel PCM via HDMI to TOSLink, it plays the 2 channels it was programmed to just fine.
Now in terms of Windows, my ALC supports quite a few different samples on SPDIF (not the full range though).
Windows fails to show various sample rates, and does not even have a playback test file for 192k.
Windows also has no way to configure the final number of channels on SPDIF.
The G in image 1 is a typo. Here is a slightly older spec JIS F05 cable.
@ajf64, I updated, changed the .inf files in the latest package, reducing file registrations and improving total response.
The current package has only 1 DTS bug (bass boost) for stereo, none for multichannel and Interactive.
On some devices you might get a power pop with 'Stereo Mix' after a shutdown, even when muted and volume 0.
I am using E-APO to upmix stereo, I also set 'Stereo Mix' to -80 dB, fixing the pop. This is driver related.
3,062 (2.01/day)
United Kingdom
Added SPDIF formats to the main folder. Enjoy! If you are using Win10, 'DTS:X Home Theatre' might not show.
Once you select the formats, you might need to repeat the disable-enable to refresh (EDID sort of).
If you intend to use a different format to Interactive, such as Atmos, you might need to set SPDIF to stereo.
You can use the provided 'DTS Settings' to change SPDIF to standard 2 channel PCM.
3,062 (2.01/day)
United Kingdom
@ClydeZa, The driver or the SPDIF formats? If the driver all you need is in post one, else if you still need help message me a good time to use TeamViewer, or post here.
Note to new users:
When using Interactive or multichannel mode, DTS:X Ultra will display its in multichannel mode, the buttons cannot be used, it's automatically configured to channel based processing.
When using stereo, 2 channel mode, this message will disappear and the stereo modes will become active, and usable. Sound Unbound also applies in stereo cases.
The Ultra and Headphones:X are spatial modes for stereo output, stereo headphones and stereo speakers, multichannel, again, is auto configured.
> Also note, you double click 'Install' rather than right click, following the guide in post 1.
3,062 (2.01/day)
United Kingdom
Same version as current, 1.10.1.0, still waiting for a new version, however its low urgency, only TBHDX to fix.
Something to note:
If I plug my 3.5mm jack headphones into the front port of my computer, not so great audio, from the back its ok, from the monitor terrible (DisplayPort, the monitor to blame).
Comparing 6 channel analogue (supposedly lossless) and 6 channel digital (DTS, lossy), from my ALC 889, analogue is -4 db, and a lower quality overall.
If I plug my headphones into my Logitech Z906, which uses TOSLink and with my ALC 889 using DTS Interactive, it sounds great.
My Z906 will also downmix multichannel to stereo, both from analogue and digital, even encoded audio.
Comparing my GPU (HDMI-Extractor-TOSLink) and ALC (SPDIF-TOSLink), they are very similar, but the ALC is preferred for a more direct signal.
jose_luis
9 (0.01/day)
Hola a todos, he seguido los pasos del primer mensaje pero no consigo que funcione, no se hablar ingles y uso el traductor de Google asi que supongo que algo hice mal ¿podrian ayudarme?.
Un saludo.
Translate Google
Hello everyone, I have followed the steps of the first message but I can't get it to work, I don't know how to speak English and I use Google's translator so I guess I did something wrong, could you help me?
3,062 (2.01/day)
United Kingdom
Deshabilite las actualizaciones de la tienda de Windows, luego desinstale la aplicación Sound Unbound la actualización instalada. Luego instala el que tiene licencia, el del post 1 de este hilo.
También verifique que 'DTS APO4' se esté ejecutando, usando el administrador de tareas. Pregunta si necesitas más ayuda.
Si no hay 'DTS APO4', entonces un software VPN está causando un problema o el dispositivo tiene más controladores de los que debería, y hay un problema en cuanto al controlador.
jose_luis
9 (0.01/day)
Lo hice y no funciona.
No aparece en el administrador de tareas.
jose_luis
9 (0.01/day)
Entonces ese es el problema, ¿el dispositivo de audio se muestra como 'DTS DCH', como en la imagen de arriba? Si es así, revise 'pnputil' usando el símbolo del sistema, como en la publicación 1, para ver si tiene otros controladores que causan problemas.
Tambien hice todo eso, y paso a paso quite todos los de Realtek antes de instalar el nuevo.
3,062 (2.01/day)
United Kingdom
¿Tiene tiempo para usar TeamViewer, entonces puedo ver. Envíame un mensaje al usuario y pasa.
jose_luis
9 (0.01/day)
Por supuesto, lo abro ahora mismo!!!!!
¿Por privado?
Creo que todo fue bien, no noto nada mal por ahora, y espero que sea asi :roll:.
Muchas gracias por la ayuda, sin usted no lo habria conseguido :rockout:, mil gracias por ayudarme :respect::respect:.
91 (0.03/day)
Incluso usando Google me perdi varias veces jaaaaa
Más difícil es cuando ves un vídeo guía en Youtube pero hablan en ingles y como no tienen subtítulos en español el traductor de subtítulos de YouTube no ayuda mucho
jose_luis
9 (0.01/day)
Muy cierto y te vuelves loco intentado averiguar que demonios estan diciendo ;).
91 (0.03/day)
Y peor es si la guía se trata de parchear programas usando desambladores, debug y lector de código máquina ya que te muestran un programa que también en ingles avanzado xd
48 (0.04/day)
System Name Ghost Spectre Asus ROG Z390F Gaming
Processor Intel Core i3 9100F
Motherboard ASUS ROG Z390 F Gaming
Cooling Corsair LL120 RGB LED PWM Fan's
Memory 32GB 3200er CORSAIR VENGEANCE RGB
Video Card(s) Geforce GTX ****
Storage Seagate Barracuda and Sandisk SSD combinated RAID 0 Striping
Display(s) Two Samsung Displays (1 Digital Tv and 1 older Analog 2ms gaming Monitor) + Smart Tv
Case Rare Oldschool NZXT LED Gaming Case
Audio Device(s) Creative IRoar Rock with Subwoofer & Logitech Z906
Mouse Hyrican RGB Set
Keyboard Hyrican RGB Set
Software Ghost Spectre's Modded Windows 11 & much more stuff
Benchmark Scores Not tested yet
Sorry I only speak English.
¿en español por favor?
:laugh:
_____________
Start an Privat Conversation guys @Gustavo Sicha @jose_luis
@Ferather
31/01/2022
- Update Dolby DAX API Service to 3.30205.250.0
- Update Nahimic APO 4 to 4.7.1.0
- Update DTS APO 4x Service to 1.10.7.0
- Update DTS APO 4x to 1.10.11.0
PureSoftApps: APO Driver [2.10.2] - Changelog
