System Name | Ghost Spectre Asus ROG Z390F Gaming |
Processor | Intel Core i3 9100F |
Motherboard | ASUS ROG Z390 F Gaming |
Cooling | Corsair LL120 RGB LED PWM Fan's |
Memory | 32GB 3200er CORSAIR VENGEANCE RGB |
Video Card(s) | Geforce GTX **** |
Storage | Seagate Barracuda and Sandisk SSD combinated RAID 0 Striping |
Display(s) | Two Samsung Displays (1 Digital Tv and 1 older Analog 2ms gaming Monitor) + Smart Tv |
Case | Rare Oldschool NZXT LED Gaming Case |
Audio Device(s) | Creative IRoar Rock with Subwoofer & Logitech Z906 |
Mouse | Hyrican RGB Set |
Keyboard | Hyrican RGB Set |
Software | Ghost Spectre's Modded Windows 11 & much more stuff |
Benchmark Scores | Not tested yet |
wait oh do you already use this versions?It will be easy to see if he's using my files, I would download it to find out but it contains @*£!#
To be fair its not too hard to work out what I did if you know what to do.
I came to see the spicy comments but it seems that it has calmed down xDthat's right hehe, with pleasure
System Name | FireBreather |
Processor | AMD Ryzen 9 7950x |
Motherboard | CrossHair Extreme x670E |
Cooling | Asus RoG Strix LC2 360 AIO |
Memory | G.Skill Trident Z5 RGB Series 64GB (2 x 32GB) 288-Pin SDRAM DDR5 6000 CL30-40-40-96 1.40 |
Video Card(s) | 7900 XTX Taichi |
Storage | 3x- PCI-E 4.0 Nvme 2TB 7GB/s - 2TB N7 USB-3.1 Nvme 1GB/s |
Display(s) | ASUS - VG259QM 2k 280hz HDR - LG-C1 4K 120hz OLED with Dobly vison |
Case | ROG Helios |
Audio Device(s) | SupremeFX ALC4082 codec, and an integrated ESS® ES9218 quad DAC |
Power Supply | HX1500i - 1500Watt |
Mouse | Corsair Dark Core |
Keyboard | Corsair K95 Platinum |
Software | Windows 11 pro |
Benchmark Scores | Time spy - 29000 Port Royal - 17500 Cinabench R23 - ST = 2150 MT = 40000 |
o this is cool what is the diffrence between dtsx:E1 and E2 and so DTSX:hometheater shows up but every time i select it it kicks back to interactive once i close the settings opens the store page every time i select hometheater even tho i have have the app and a licence i can test it fine it works just wont stick for some some reason might be somthing to do with sound unbound app still not seeing spdif as hdmi cuz you cant activate hometheater in the dts app only shows up in control panel you can set it test it and works great but then when you close settings it reverts back all the other formats seem to be working great and passthrough with no issuesCurrently I have Z906, which only supports 2 channel PCM, DTS Surround, Dolby Digital Live!, this has nothing to do with SPDIF hardware limits.
Directly, there is no upgrade, and my Realtek SPDIF can send all encoded formats (even ones Z906 doesn't support).
I only gain multichannel PCM, and only because OEM's are still catching up to SPDIF's full potential.
HDMI audio is 37mbps max, SPDIF + TOSLink 2.0 is 125mbps max, optical is more responsive than conductive circuit, and immune to EMI RFI.
Even the distance TOSLink does 125mbps is futher than HDMI can do 37mbps, There is also optical SMI @ 250mbps.
For audio only, the video feed the GPU has to make is wasted overhead, no advantages to HDMI.
In terms of Windows, neither SPDIF nor HDMI are properly supported, and the EDID is unused mostly.
SMI Optical Interconnects | TTI, Inc.
As a side note, now that OEM's now how to implement the hardware for HDMI to do it's max 8 x 192k (1,536k), 37mbps.
They can put the same PCM hardware on SPDIF, it can even be done via HDMI + TOSLink 2.0, no SPDIF.
I suggest SPDIF, because at the lowest level (consumer), it supports 15 channels.
I can send my Z906 6 channel PCM via HDMI to TOSLink, it plays the 2 channels it was programmed to just fine.
Now in terms of Windows, my ALC supports quite a few different samples on SPDIF (not the full range though).
Windows fails to show various sample rates, and does not even have a playback test file for 192k.
Windows also has no way to configure the final number of channels on SPDIF.
View attachment 234616View attachment 234618
The G in image 1 is a typo. Here is a slightly older spec JIS F05 cable.
@ajf64, I updated, changed the .inf files in the latest package, reducing file registrations and improving total response.
The current package has only 1 DTS bug (bass boost) for stereo, none for multichannel and Interactive.
On some devices you might get a power pop with 'Stereo Mix' after a shutdown, even when muted and volume 0.
I am using E-APO to upmix stereo, I also set 'Stereo Mix' to -80 dB, fixing the pop. This is driver related.
Case | ROG Helios |
do you have a link to that app again and ill try it now also so your saying i have to revert to stereo to get homtheater to work so is home theater true multichannel or just an upmix?You will need to switch SPDIF to stereo using 'DTS Settings', in order to remove the Interactive APO.
1. Open 'FX Config' and select SPDIF, then on the right, press copy GUID.
2. Right click 'Stereo.reg', and replace BOTH {DEVICE-ID} with the copy.
3. Disable SPDIF, via sound settings, then apply the .reg.
4. Enable SPDIF via sound settings.
Case | ROG Helios |
woops idk how i forgot that im sorry one other question so your saying i have to revert to stereo to get homtheater to work so is home theater true multichannel or just an upmix?Its inside the DTS DCH package, inside Tools. DTS Settings is in the settings folder of the driver download, post 1.
Case | ROG Helios |
ah ok where is stereo.reg i have not seen that oneWhen you select Interactive it sets SPDIF to multichannel processing, I would guess Atmos HT and DTS:X HT do the same.
Case | ROG Helios |
ok so i did all that but home theater still wont stick everytime i close it kicks back to 2 channel store page also still comes up every time i try to activate itDTS Settings
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.www.mediafire.com
Case | ROG Helios |
ya we can do that do you have discordI don't have Win11, but on Win10, on SPDIF, if I select Atmos it sticks. So there must be an issue somewhere.
Do you have time for TeamViewer? in say 20 minutes
Case | ROG Helios |
great i responedOf course, message sent.
